Fuel tank service bulletin
Goto page 1, 2  Next
tn3639(at)hotmail.com
PostPosted: Fri Feb 24, 2006 11:57 am    Post subject: Fuel tank service bulletin Reply with quote
Vans has just issued a service bulletin to be compled with BEFORE next
flight on all RVs. Go to there web site and check it out...
Scott
PostPosted: Fri Feb 24, 2006 12:47 pm    Post subject: Fuel tank service bulletin Reply with quote
I don't think this includes the 10s
Scott
Reply-To: rv-list(at)matronics.com
Subject: Fuel tank service bulletin Date: Fri, 24 Feb 2006
13:54:27 -0600
Scott
Tim(at)MyRV10.com
PostPosted: Fri Feb 24, 2006 12:58 pm    Post subject: Fuel tank service bulletin Reply with quote
Lucky....dodged that bullet. Let me correct you...
"All single and 2 place RV's".
RV-10's need not worry.
Scott
ronlee(at)pcisys.net
PostPosted: Fri Feb 24, 2006 12:59 pm    Post subject: Fuel tank service bulletin Reply with quote
http://www.vansaircraft.com/pdf/sb06-2-23.pdf
Ron Lee
Ed Anderson
PostPosted: Fri Feb 24, 2006 1:23 pm    Post subject: Fuel tank service bulletin Reply with quote
I had flown for 5 years and one day that flop tube did indeed back off its
fitting and I ended up doing a 12 mile glide which fortunately ended up
with an uneventful landing on an airport. So even though I have really
tighten that son of a gun, I will probably bite the bullet and safety wire
according to the bulletin. Once is more than enough.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
jsflyrv
Ron Lee
How stupid is it to keep flying an aircraft when apparently there were
indications that all was not well.
"The operator of this aircraft reported that, on
multiple occasions, fuel would not feed from the affected tank when the
level reached
approximately one third full. This would be an indication that the
associated fuel pickup
was loose or was not attached to the bulkhead fitting inside the tank."
do not archive.
Gary.A.Sobek
PostPosted: Fri Feb 24, 2006 1:42 pm    Post subject: Fuel tank service bulletin Reply with quote
PLEASE ARCHIVE this.
----Original Message Follows----
Subject: Re: Fuel tank service bulletin
Date: Fri, 24 Feb 2006 13:21:28 -0800
>Ron Lee
"The operator of this aircraft reported that, on multiple occasions, fuel
would not feed from the affected tank when the level reached approximately
one third full. This would be an indication that the associated fuel pickup
Ed Anderson
PostPosted: Fri Feb 24, 2006 2:28 pm    Post subject: Fuel tank service bulletin Reply with quote
If your flop tube falls off you have approx 3.5 gallons that you can not use
in that tank (Rv-6A). After my flop tube fell off (I initially thought that
it had hung up on something), I would fill that tank approx 1/2 full and
while flying tried to rock the wings and shake loose the "hung up" flop
tube. But, every time the fuel level got down to 3.5 gallons in that tank,
the engine would start to sputter. I agree its hard to understand why an
individual would not notice that he could not use the last 3.5 gallons and
fly depending on it. I guess if you had burnt all the fuel in your good
tank and expected to make it to the airport on the flop tube tank - it could
catch you if it were the first instance after it had falling off. While
making the flights trying to "unhang" the flop tube, I always took off and
landed using the other tank.
I finally bit the bullet and took the tank off, opened it up expecting to
find the tube hung up - but, much to my surprise it was not hung up and (I
had forgotten) I found that I had installed all the anti-hang fixes that Van
suggested. Then I reached in and picked up the flop tube - really puzzled -
until it followed my hand out the access hole. Came loose after 160 hours
of flight time.
Ed
Ed Anderson
Matthews, NC
Ed Anderson
Matthews, NC
George McNutt
PostPosted: Fri Feb 24, 2006 7:18 pm    Post subject: Fuel tank service bulletin Reply with quote
Looks to me like Van has hired a ex FAA lawyer to protect the company
from litigation!
One question for you Ed, did you switch to the other tank, seems to me
that should re-establish fuel flow.
George in Langley BC
Ed Anderson wrote:
snip ---- one day that flop tube did indeed back off its
Ed Anderson
khorton01(at)rogers.com
PostPosted: Fri Feb 24, 2006 7:58 pm    Post subject: Fuel tank service bulletin Reply with quote
Well, there have been at least two events. Maybe more. So there are
good odds that this failure will happen again. I'm not sure the
"perform SB before next flight" is warranted, but it would be prudent
to operate as if this failure could occur on one tank on the next
flight until both fuel pickups are safetied. I.e. increase the
assumed unusable fuel to allow a safe landing even if one fuel pickup
becomes undone. The hard part is knowing how much extra unusable
fuel to assume - Ed's data suggests 3.5 USG is the value for an
inverted tank pickup, but we don't know how much error this
measurement has, nor do we know what unusable fuel to assume for a
regular fuel pickup, if it becomes undone.
I'm a bit torqued as I just put one of my access covers back on last
week, after fixing a tank leak. But I'll pull them and do the SB
before first flight.
Kevin Horton
from litigation!
Ed Anderson wrote:
> <eanderson(at)carolina.rr.com>
> ended up
George McNutt
PostPosted: Fri Feb 24, 2006 8:04 pm    Post subject: Fuel tank service bulletin Reply with quote
Re; Vans Mandatory Fuel Tank Service Bulletin
I have just read this Mandatory Service Bulletin and I think it is going
way overboard, someone at Vans has made a big Boo-Boo as far as customer
relations goes.
It seems to me that the Time of Compliance - "Before further flight" is
extremely harsh for all aircraft that have properly functioning fuel
system(s).
(1) The MSB does not make any provision to ferry your aircraft back to
your home airport or to a maintenance base.
(2) What about alternate compliance?? - seems to me if I drain all the
fuel out of the tanks, then add one gallon back into each tank and do a
engine run-up using each tank I would soon know if the fuel pick-up
sucking air, loose or missing. If I pass this test seems the MSB could
wait for the next annual inspection.
My insurance and/or CofA may not be valid if I fly my aircraft this
weekend, thank you Van, and you can bet I will e-mail and telephone
Van's first thing Monday morning, and I would encourage everyone who is
effected by the MSB to call Van about this heavy handed MSB.
6A - 400 hrs
7A cowlings
Kellym
PostPosted: Fri Feb 24, 2006 8:18 pm    Post subject: Fuel tank service bulletin Reply with quote
Well, I don't know in the experimental homebuilt world just how
mandatory a service bulletin can be made by a kit manufacturer.
Afterall, you are the aircraft manufacturer, not Vans.
In the certified world, so called mandatory service bulletins are
meaningless to Part 91 operations, unless there is a financial
incentive(such as Hartzell is offering big discounts on their hub SB
that is expected to become and AD, but only for the next 3 months). You
can simply ignore them, unless the FAA issues an AD to enforce the SB. I
don't know if that is true for homebuilt, but would be surprised if it
isn't.
relations goes.
system(s).
6A - 400 hrs
7A cowlings
Kelly McMullen
KCHD
Ed Anderson
No, George, I remain a bit embarrassed to say I talked my self out of doing
just that. My poor rationale was that I knew I had 3.5 gallons left in that
tank and therefore the problem must be something else other than the lack of
fuel. Of course, it turns out I DID have 3.5 gallons left - just couldn't
use it. Having been talking with another pilot the day before about cases
of the slosh compound peeling off and plugging fuel filters, I convinced
myself that my fuel filter had plugged and therefore switching tanks would
not do any good. Of course, if I had done what ever instructor I ever flew
with told me to do and switched tanks - it would not have been an event. I
tell folks sometimes absolute knowledge is not necessarily a good thing.
Had I been less certain about the fuel in that tank ( I have a fuel
totalizer) then I may have switched.
I am happy to say that the decisions make after that bad one were
considerably better {:>)
Ed
Ed Anderson
Matthews, NC
Ed Anderson
Matthews, NC
dreel(at)cox.net
PostPosted: Sat Feb 25, 2006 2:34 pm    Post subject: Fuel tank service bulletin Reply with quote
There are a lot of flared tubing connections on an RV. Why safety only this one?
Dave Reel - RV8A
Gary.A.Sobek
PostPosted: Sat Feb 25, 2006 2:50 pm    Post subject: Fuel tank service bulletin Reply with quote
These are the only fittings that CANNOT be inspected during a normal
condition inspection. There was ONE know ACCIDENT from this connection being
loose.
Van knows more about RV airplanes that I do.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,841 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
To: "rvlist" <rv-list(at)matronics.com>
Date: Sat, 25 Feb 2006 17:32:16 -0500
one?
Dave Reel - RV8A
seiders(at)bellsouth.net
PostPosted: Sat Feb 25, 2006 2:52 pm    Post subject: Fuel tank service bulletin Reply with quote
Probably because it's one we don't have easy access to, or even see when
changing oil etc. I like to put a wrench on the available nuts each time
the cowl, wing root fairings, wheel pants etc are off. Makes me feel better.
Dick RV6A 400hrs
this one?
Dave Reel - RV8A
lifeofreiley2003(at)yahoo
PostPosted: Sat Feb 25, 2006 2:55 pm    Post subject: Fuel tank service bulletin Reply with quote
It's the only connection that Van's attorney is concerned with at this time. Wink
Darrell
Dave Reel - RV8A
Bring photos to life! New PhotoMail makes sharing a breeze.
Mark Phillips in TN
PostPosted: Sat Feb 25, 2006 7:28 pm    Post subject: Fuel tank service bulletin Reply with quote
In a message dated 02/25/2006 4:35:38 PM Central Standard Time, dreel(at)cox.net
writes:
My thoughts exactly. Gee- ain't the fuel lines FWF the same thing? Losing a
tank pickup absolutely SHOULD be a non-event, unless undiestains are
considered. You lose a fitting at the carb, fuel pump, fuel pressure line or bulkhead
fitting and................
(Uh oh- will have to check Van's website tomorrow to see if there are some
more MSBs posted)
I know a couple of good, decent lawyers, but also a $hitload of 'em that
would sell their grandmothers for a buck (or several million, if at all possible)-
what a sorry comment on our society that Vans had to resort to this pitiful
action. We haven't heard from the insurance folks yet- J.T. are you
listening? Sure would appreciate your take on this (at your leisure and after you get
out of conference with the attorneys!)
Do not archive - Mark Phillips
From The PossumWorks...
pblake(at)epix.net
PostPosted: Mon Feb 27, 2006 1:51 pm    Post subject: Fuel tank service bulletin Reply with quote
Here's the letter and e-mail I sent to Van.
February 27, 2006
Dear Van,
I was very surprised and disappointed on seeing your Mandatory Service
Bulletin requiring fuel tank changes. In my case, I have capacitive probes
for fuel quantity measurement, and no inspection plate to remove. Even if I
did have plates, theres less than a 2 gap between the wing skins and
fuselage of my RV6. I wont whine about tearing up very expensive paint, or
removing the wings to get at the tank, or even that this may cause an
insurance problem if I fail to do it. Instead, I question your logic and
your process of issuing this bulletin.
Im wondering why you didnt at least have a comment period so you could
gather input from the fleet, before issuing this bulletin. The FAA finds
public comment useful; Im surprised you dont as well.
I have heard of two incidents involving alleged (your term) fuel pick-up
tube problems. In one, there was plenty of warning that something was
amiss, yet the plane was flown anyway (rather than ground tested), without
determining and rectifying root cause. Even then, it seems that simply
switching tanks would have prevented the accident. In the second instance,
switching tanks would have prevented the accident as well. How many times
have we heard of fuel starvation accidents where the pilot failed to switch
tanks, even though plenty of fuel was available in the other? It seems to
me that pilot error was a major contributing factor in these accidents.
Perhaps an article on the importance of proper emergency procedures for
engine-out emergencies would have been appropriate, since that would address
prevention of such fuel starvation accidents.
Given a fleet of approximately 4500 aircraft, 2 incidents (both of which
could have been prevented by appropriate pilot action) represents an
accident rate of 0.044 %. This level of risk doesnt seem sufficient to
warrant the draconian nature of your service bulletin especially
unilaterally, without comment.
Further, it seems to me that a vanishingly small probability exists that one
tank would be dry while the fuel pick-up tube malfunctioned in the other, or
that both tubes malfunctioned at the same time. These seem to me to be the
only conditions under which an engine stoppage due to fuel pick-up tube
malfunction could not be rectified by appropriate pilot action e.g.,
switching tanks.
Many will say that you did this to protect yourself from liability a
completely understandable motive. It seems to me however, that mandating
the opening of 9000 fuel tanks by amateurs, drilling of holes in sensitive
areas, resealing etc. (and in the case of those of us with capacitance
senders and no removable end plate, creating and sealing a large hole), not
to mention the obvious danger of fire when working around aviation gasoline
and fumes, is a case of the cure being worse than the disease. It seems to
me that you expose your company to much more liability in the case of
accidents that will be construed as directly or indirectly caused by or
related to these repairs.
It seems to me that a more rational approach would be to mandate a bore
scope inspection of the fuel pick-up tubes, which could be accomplished with
minimum fuss through the fuel drain plug hole. This would identify any
problems, go a long way toward protecting you from fuel pick-up tube
liability, and avoid entirely the liability of causing 9000 fuel tanks to be
drained (and not flushed with water), opened, modified and reclosed.
I encourage you to consider all the ramifications of your actions, first and
foremost with regard to safety. Secondly, with regard to the thousands of
hours (and dollars) required for fleet compliance, and thirdly, with regard
to your reputation for pragmatism, concern for costs, and generally doing
the right thing.
Please rescind this bulletin, and issue another, more appropriate to the
actual risk-benefit relationships in this issue.
Sincerely,
Peter Blake
RV6
e-Mail: pblake(at)epix.net
DO NOT ARCHIVE
Peter H. Blake, Ph.D.
PrcisTrial LLC
60 Beverly Drive
Kintnersville, PA 18930
Office +01.610.847.8478
Cell +01.215.519.4603
Fax +01.610.847.8160
e-Mail PHB(at)PrcisTrial.com
dbentley(at)fuse.net
PostPosted: Mon Feb 27, 2006 5:12 pm    Post subject: Fuel tank service bulletin Reply with quote
Peter Blake - well worded letter!
There is a process whereby issues like this are addressed with respect
to propulsion systems for transport category aircraft, and accepted by
the FAA. A Weibull Failure Rate can be easily generated with just the
data of the individual events and the flight hours at the time of
failure. That Weibull is then used to generate a risk assessment of the
potential of a Category 3, 4, or 5 event, against the CAAM (Continued
Airworthiness Assessment Methodology) Guidelines. It's a fairly simple
statistical assessment used to determine when an unsafe condition
exists, and if there is a reasonable, excessive, or high (ground the
fleet) risk. As you have suggested, and is frequently used in the
transport world, if action is required, a recurring inspection is often
sufficient to significantly reduce the risk to acceptable levels until
the final corrective action is accomplished.
I'm extremely disappointed that Van apparently did not consider any of
this first, or at least failed to inform the 4000 of us flying that he
had made this assessment and this kind of extreme action was
statistically merited.
Duane Bentley
RV6
Home: 513-777-5491
GE Aircraft Engines
Office: 513-552-6051
DO NOT ARCHIVE
Goto page 1, 2  Next
Page 1 of 2
