sarg314(at)comcast.net Guest
Posted: Mon Jan 21, 2008 3:28 pm Post subject: nose gear + 3 blade prop |
I have a Catto 3-blade and am trying to put it on an RV-6A. It hadn't
occurred to me when I ordered the prop that it would make removing the
lower cowl more difficult. At the moment I'm reluctant to drain the
preservative oil out of my engine, so I haven't yet rotated the
crankshaft at all in order to put the prop in the optimal position for
cowl removal.
Can those that have a 6A + a 3-blade prop advise me if they had to do to
anything special to make the lower cowl removable? I have enlarged the
nose gear slot in the air scoop about as far forward as possible. (Well,
up to the forward plate nut that holds on the upper gear intersection
fairing. Maybe there shouldn't BE a nut plate there?)
Can the cowl be removed with the nose gear leg fairing in place, or does
that have to be removed first?
Tom S., RV-6A
Posted: Mon Jan 21, 2008 3:46 pm Post subject: nose gear + 3 blade prop |
Tom,
What I've done so far is to make mine easily removable without the nose gear
fairing in place. I have already templated a bottom cover to hide my
extended slot and my intersections fairing will probably attach to that.
I have a three-blade MT and it is a bugger to get off carefully enough to
keep from touching the prop. I take the single blade straight up (like you
probably will!).
I am contemplating making a lowering platform like I've seen posted
somewhere
I will be getting some prop blade covers soon too.
Ralph
Painless
Joined: 10 Jan 2006 Posts: 40 Location: Peshtigo, Wisconsin
Posted: Mon Jan 21, 2008 4:09 pm Post subject: nose gear + 3 blade prop |
Hi Tom: I have a 6A with a Catto. Removing the lower cowl is more of a
challenge than with a two blade, but still doable. I can take mine off
without removing the nosegear fairing. I put a couple layers of wide
masking tape on the forward edge to protect it while taking off/put on the
lower cowl. I have been thinking of making a velcoed sleeve for the same
purpose.
I have the Fairings Etc nosegear fairing, and it covers the required deeper
slot perfectly.
You will learn that there is a certain angle/removal path that works best to
remove the bottom cowl. Once you get that down, removal is no big deal. I
would advise to have a helper for the first few tries so you don't scratch
any paint.
Jeff Orear
RV6A N782P
Peshtigo, WI
_________________ Jeff Orear
RV6A N782P
Peshtigo, WI |
ronlee(at)pcisys.net Guest
Posted: Mon Jan 21, 2008 4:31 pm Post subject: nose gear + 3 blade prop |
I tape (painters tape) both bottom blades of the prop and the upper
forward portions of the lower cowl. As you lower the cowl you have to
move one side of the cowl to one side, maybe move the prop a little,
move that side of the cowl forwardand down then move the other prop blade
away
a little and it comes out. It is more difficult and I almost have to
redicover
the process each time.
Ron Lee
lifeofreiley2003(at)yahoo Guest
Posted: Mon Jan 21, 2008 4:49 pm Post subject: nose gear + 3 blade prop |
It really depends on your cowl attach method. I have
offset (shimmed) cowl mounts to the firewall with
nutplates. With this setup, it is not required to pull
forward on the cowl to drop and remove. Front comes
down and slide forward.
Darrell
I can take mine off
purpose.
slot perfectly.
any paint.
Jeff Orear
RV6A N782P
Peshtigo, WI
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon Jan 21, 2008 8:44 pm Post subject: nose gear + 3 blade prop |
In a message dated 01/21/2008 5:29:53 PM Central Standard Time, sarg314(at)comcast.net writes:
that have to be removed first? |
I always pull the nose leg fairing before dropping the cowl- you'll scratch that lovely paint otherwise- you mention that you've slotted it forward to a nutplate (I assume is used to attach the upper fairing). Is this a fairings-etc piece? (nice part, BTW!) If so, mayhaps you could remove the platenut at the front and install one on either side of the slot?
Mark - RV-6A "Mojo" with O-320, Catto 3-blade
http://websites.expercraft.com/n51pw/
Start the year off right. Easy ways to stay in shape in the new year.
_________________ From The PossumWorks... |
Mark Phillips in TN
Posted: Mon Jan 21, 2008 8:50 pm Post subject: nose gear + 3 blade prop |
In a message dated 01/21/2008 5:49:08 PM Central Standard Time, recapen(at)earthlink.net writes:
| Quote: | | I will be getting some prop blade covers soon too. |
Hi Ralph- I took some of the leftover outdoor deck carpeting I used for my floors and cut some pieces long enough to wrap around the prop blades- a wrap of duct tape around each end and you wind up with nifty slip-on blade protectors! I made 2 of these and have used them many times- quite handy and super-cheep!
Mark
Posted: Tue Jan 22, 2008 6:05 am Post subject: nose gear + 3 blade prop |
Mark:
Yes, the nose gear upper intersection fairing is one I made myself.
Not thinking about the prop, I put 2 nut plates on each side and one
forward to hold it on. If I remove that forward one and put one to each
side of it, I could extend the slot only another 3/4 inch forward before
it would extend out past the margin of the fairing. I might need more
mods in this area. Ugh! Fiberglass.
Fiveonepw(at)aol.com wrote:
| Quote: | In a message dated 01/21/2008 5:29:53 PM Central Standard Time,
does
