mountain4don
Posted: Tue Jan 22, 2008 6:34 pm Post subject: 601 Front Wheel Instructions |
I am about finished with my fuselage on my 601 XL, and getting ready to start installing the landing gear. I copied the Gear/Brake Lines section 6-G down from Zenith's builders web site. But I couldn't find a section of the instruction manual for installation of the front landing gear. Is there one? Or do you just build it from the plans? Or is it complete enough from the factory to just put it in? I have the factory complete kit.
Don Mountain
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Zenith 601XL, tail done, working on wings |
Posted: Tue Jan 22, 2008 9:35 pm Post subject: 601 Front Wheel Instructions |
I didn’t find anything in the photo assembly guide on the front gear and just followed the plans. Lance Gingell suggests following the CH801 guide on this (although it lacks the reinforcing “U”):
http://www.zenithair.com/stolch801/data/gear-nose-s1.pdf
http://www.zenithair.com/stolch801/data/gear-nose-s2.pdf
There is a little in the HomebuiltHELP Quick-build kit DVD.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Don Mountain
Sent: Tuesday, January 22, 2008 7:31 PM
To: Zenith
Subject: 601 Front Wheel Instructions
Don Mountain
Quote: | http://www.matronics.com/Navigator?Zenith-List | 0123456789
psm(at)ATT.NET Guest
Posted: Fri Jan 25, 2008 5:59 am Post subject: 601 Front Wheel Instructions |
Hi Don,
I am sorry it is so late for a first response to your message on nose
gear. I just got the email dated 1/22 and today is 1/25. There
seems to be some backup (at least for me) in the email delivery system.
I don't recall finding any instructions for doing the nose gear. I
found the drawings pretty straight forward, but there are a few areas
of special challenge.
I painted the main nose gear column before installation and found the
bottom plastic bearing to be tighter than I thought was good. I used
a Dremel tool with sanding drum to take a bit off the inside of the bearing.
I posted a solution to the challenge of stretching the bungee cord
into position with pictures a while back. The tool I invented was a
piece of PVC pipe with one end cut an a angle. This makes a nice
tool for slipping the bungee in place. If you need a new picture,
just send me an email.
The biggest challenge is the treatment of the slots where the tie
rods pass through the firewall. My version of the drawings leaves
huge holes in the firewall that don't even allow the steering to work
properly. There are several solutions already posted for this area,
and I have my own (which I am not proud enough of to post since it is
outrageously complicated to build).
Good luck,
Paul
XL fuselage
At 06:30 PM 1/22/2008, you wrote:
Quote: | I am about finished with my fuselage on my 601 XL, and getting ready
Don Mountain
