LarryM
Posted: Wed Feb 06, 2008 6:46 am Post subject: Fuel Tank Sealing? |
Hi,
Given the properties below, would you think that this would be an effective barrier/sealant to apply to the inside of a fiberglass tank that will contain auto gas with ethanol?
Thanks for your experience.
larry
JEFFCO 9700FCR CHEMICAL RESISTANCE GUIDE
(3 WEEK IMMERSION)
Reagent % weight gain (loss)
Xylene 0.0
Toluene 2.3
1,1,1 Trichloroethane 0.0
MEK 2.3
EB (Ethylene Glycol Monobutyl Ether) 2.4
Ethyl Alcohol 6.9
Water (deionized) 1.2
5% Detergent Solution 0.0
10% Sodium Hydroxide 0.0
50% Sodium Hydroxide (0.2)
10% Sulfuric Acid 0.0
70% Sulfuric Acid 0.2
10% Hydrochloric Acid 0.1
5% Acetic Acid 2.6
10% Acetic Acid 5.4
Skydrol (0.03)
Synthetic Gasohol 0.0
Mogas, Diesel 0.0
JP-4, JP-5, JP-7, JP-8 0.0
Diethylene Glycol Monomethyl Ether 0.0
