		jeynon2
  Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
				 Posted: Mon Jan 28, 2008 10:16 am    Post subject: Upper Rudder Hinge |
				Hi all,
 I've been lurking on this list for a while now, and although Colin outed me earlier, I thought I'd finally introduce myself with a question.  I'm located in Southern Illinois (Carbondale) and building Lightning #53 at home in my garage.
 My question is how does one bolt the upper rudder hinge to the vertical tail.  I have cut the hole beneath the hinge, but it seems I would have to be E.T. with magnetic fingers to get the nut and washer on the upper bolts.  Then there is the question of how to get a wrench on the nuts to tighten.  I've considered drilling an access hole in the top of the tail, but wanted to see how others have solved this problem.
 Thanks for any input, and I look forward to participating in the discussions in the future.
 John Eynon
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		jeynon2
				 Posted: Mon Jan 28, 2008 2:06 pm    Post subject: Re: Upper Rudder Hinge |
				Clive just emailed me a description and a very helpful picture to solve my problem. So I'm giving up training the small squirrel to hold a wrench, and I am off to the hardware store for tools.  Back to the build.
 Thanks Clive.
 John E.
		sales(at)billandruth.net Guest
				 Posted: Mon Jan 28, 2008 5:05 pm    Post subject: Upper Rudder Hinge |
				Hi Jeynon,
  I'm building #49 in my hangar.  I was able to get the nut and washer on by putting some masking tape tacky side out around my finger and putting the parts on that taped finger.  That worked super!  I tied some string to my wrench and pushed it into the access hole and pulled it up and was able to get the wrench on as well.  Hopes this helps.  Bill in Tucson.
  jeynon wrote:
  [quote]    	  | Quote: | 	 		  --> Lightning-List message posted by: "jeynon" <jeynon2(at)verizon.net> (jeynon2(at)verizon.net)
 Thanks Clive.
 John E.
 http://forums.matronics.com/viewtopic.php?p=160909#160909
    | 	   [b]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
