		Colin K.
				 Posted: Wed Jan 30, 2008 6:52 pm    Post subject: Builders - Inboard Aileron Hinge |
				Section 16 Wing Final Assembly and  Installation says:
  "5. With the  aileron attached, place the aileron at full up deflection, this is measured at  the tip and must be 3.5 inches."
  So there is the up  range. What's the down range?
   Colin K.
  OK
  http://www.mykitlog.com/cojaken
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
  _________________ Colin K.
OK |
		Colin K.
				 Posted: Wed Jan 30, 2008 7:20 pm    Post subject: Builders - Inboard Aileron Hinge |
				Section 13 of the  manual says:
  "Clamp the hinge bracket in place and move the aileron through its  operating range."
  My question is, what  is the operating range? Degrees up and down or trailing edge inches up and down,  without contacting the wing? The neutral point being where the aileron trailing  edge is aligned with the flap trailing edge.
  Colin K.
  OK
OK |
		vettin74(at)yahoo.com Guest
				 Posted: Thu Jan 31, 2008 5:59 am    Post subject: Builders - Inboard Aileron Hinge |
				Aileron neutral point is the flap than move about 3.5" up and about 2" down and check clearances...
   nick
 "Colin J. Kennedy" <cjk129(at)cox.net> wrote:
   [quote]    Section 13 of the manual says:
   My question is, what is the operating range? Degrees up and down or [quote][b]
