TheSchultzFamily(at)comca Guest
Posted: Mon Jan 28, 2008 9:22 pm Post subject: Throttle Cables sticking |
I am looking to see what others have done to prevent throttle cable bowing
of the twisted wire used in most throttle cables. I have a 914 installed on
a Europa and am having problems with one of the cables wanting to bow in the
throttle box and not allowing me to get full power. The throttle springs are
not strong enough to pull the cable and keep it in tension all the time. On
the Europa form others have talked about going to a solid cable .055 or .078
SS piano wire. I have some concerns about the carburetor attachment point
producing a stress crack and failing under the vibration. I am interested to
hear what others have done?
jack.kuehn(at)gmail.com Guest
Posted: Tue Jan 29, 2008 8:10 am Post subject: Throttle Cables sticking |
Not sure if I am using the same type of twisted cable as you are, but
when the cables were new I took the cable out of the housing and
sprayed it down with a silicone lubricant and made sure it was clean.
I inspect them now every 50 hours and no problems. Could your bowing
cable just be sticky?
Jack
On Jan 28, 2008 9:53 PM, Rich & Sandy Schultz
<TheSchultzFamily(at)comcast.net> wrote:
Roger Lee
Posted: Tue Jan 29, 2008 9:13 am Post subject: Re: Throttle Cables sticking |
Here are a couple of things to do.
1. Use cable housing that has the plastic lining in it and not just plain steel lining. It allows the cable to move within the sheath smoothly and doesn't rust or develop rough spots.
2. Do like Jack said and remove the cable and use some cable lube
3. Step down a cable size to allow more room in the cable housing to move and not bind. On many planes trying to use 1/16" cable size is too big depending on the routing and turns that are made with the throttle cable. My cable in my CT is only 3/64" or 1.2mm. This is because it goes around a 1 1/4" size pulley and needs to be able to make the bend and be very flexible. Using the smaller size cable will allow your carb springs to work better and do their job. Use 7x7 or 7x19 cable. 7x19 is a little more flexible than 7x7.
4. Lube the throttle quadrant if you have one and make sure it moves freely.
If it were me I would do all the above and then the throttle should be very smooth in its operation.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
daberti(at)sbcglobal.net Guest
Posted: Tue Jan 29, 2008 7:16 pm Post subject: Throttle Cables sticking |
Keep the cables as short as possible too, just long enough to make smooth a
radius if they have to change direction in your installation.
Posted: Wed Jan 30, 2008 5:39 am Post subject: Throttle Cables sticking |
Rich & Sandy Schultz a écrit :
| Quote: | others have talked about going to a solid cable .055 or .078
SS piano wire.
Relieving only on the carb throttle springs to overcome the cable
friction may prove troublesome. There have been cases of flexible cables
binding between trhottles and cable outer case, leaving the pilot with
no option when additional power is needed, despite a perfectly running
engine.
One needs a positive actuation of the carb throttle arms towards the
full throttle position.
This is why our project has piano wires, works great. To date 400+ MCR
kitplanes are flying with piano wires in place of stranded cables making
them a real push-pull device, with no reported problem whatsoever.
Some of them have logged more than 1000 flight hours to date.
| Quote: | I have some concerns about the carburetor attachment point
Not sure what you fear. The throttle arm cable attachment is of the
swivel type. No bending there.
Best regards,
Gilles
http://contrails.free.fr
hagargs(at)earthlink.net Guest
Posted: Wed Jan 30, 2008 6:10 pm Post subject: Throttle Cables sticking |
I have installed a Cessna Push pull vernier type throttle single cable up
into the engine compartment. Once there, it is split into two where the
normal motorcycle type cable that comes with the plane is used. Each
length of these is 18 inches or less long and is easily overcome by the
carberator springs.
Steve Hagar
A143
Mesa, AZ
| Quote: | [Original Message]
From: Rich & Sandy Schultz <TheSchultzFamily(at)comcast.net>
To: <rotaxengines-list(at)matronics.com>
Date: 1/28/2008 10:49:46 PM
Subject: Throttle Cables sticking
on
| Quote: | a Europa and am having problems with one of the cables wanting to bow in
the
| Quote: | throttle box and not allowing me to get full power. The throttle springs
are
| Quote: | not strong enough to pull the cable and keep it in tension all the time.
On
| Quote: | the Europa form others have talked about going to a solid cable .055 or
.078
| Quote: | SS piano wire. I have some concerns about the carburetor attachment point
to
| Quote: | hear what others have done?
ami(at)MCFADYEAN.FREESERV Guest
Posted: Thu Jan 31, 2008 3:49 am Post subject: Throttle Cables sticking |
I did something similar, but had the two Bowden cables connected directly to
the vernier via a slider arrangement.
This worked OK with two fuel injection throttle bodies, which are extremely
difficult to balance accurately (far more difficult than carbs, even without
a balance tube).
For the ROtax, I have teflon lined stainless Bowden cable which works OK,
and at reduced tension on carb springs. Has to be stainless with teflon, for
best effect. And same length of cable for each carb, irrespective of actual
requirement.
For nylon/acetyl lined cables, the possibility of the liner softening and
welding the throttle open on a long cruise (if the cable is routed near to
under-cowl hotspots such as exhausts) needs to be considered.
Duncan McF.
