cgbrt(at)mondenet.com Guest
Posted: Sun Jan 27, 2008 8:49 am Post subject: Lift sling for the CH-701 |
I would like to use a sling to lift my a/c to removal and inspect the main gear spring. I have seen slings for other high wing a/c that attach to the fuselage wing attach point and they look very functional.
Has anyone done this? Has Chris H approved lifting the 701 this way? Any help appreciated. Please reply on this list.
Carl
lgold(at)quantum-associat Guest
Posted: Sun Jan 27, 2008 11:50 am Post subject: Lift sling for the CH-701 |
Carl,
Paul Reinders, a very experienced (35,000 hour) Alaskan pilot who has a 701 ski/float plane, attached tangs to the plane for picking it up to change skis and floats. The tangs need to be placed facing upward and running parallel with the air flow on both forward wing root attachment points at the place where the wing is bolted to the fus.
My 701 does not have any main gear spring (although the gear probably has some spring in it). Does your 701 have some new or specially designed gear?
Les
[quote] From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Carl
Sent: Sunday, January 27, 2008 8:11 AM
Subject: Lift sling for the CH-701
Carl
Quote: |
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
Posted: Wed Jan 30, 2008 6:52 pm Post subject: Lift sling for the CH-701 |
Les.
Thanks for the info.
Ref your question on gear spring, I use the original ZAC gear spring with 950 amphib floats. In my humble opinion this configuration is superior to some new floats I have seen for the following reason:
1. Config change from floats to wheel/skis and back is simple using the same spring.
2. Retain nose wheel steering.
3. Low centre of gravity for better cross-wind capability on land or water..
4. Spring reduces shock to fuselage during TO/landing on land or choppy water.
5. Lower access for entry/exit.
6. One of the lightest amphib gears for the 701. My floats weigh less than 60# each and that is with steel wheels and hyd brakes, water rudder and air actuator.
The most important feature for those of us that are fallible, if you forget to retract the wheels and land on water the a/c will very likely remain upright. If for some reason you plan a water landing with the gear down and do it as per ZAC procedure, the gear will not cause an upset and the landing is very near normal.
It is possible that the lower config will accelerate prop erosion. in my case with a WarpDride three bade and 500 hrs on the water erosion has been insignificant.
Carl
davids601xl(at)yahoo.com Guest
Posted: Thu Jan 31, 2008 11:08 am Post subject: Lift sling for the CH-701 |
Hi Carl.
I would certainly recommend that you do NOT lift your
aircraft by the wing root attach points. The vertical
forces on the attach points nearly cancel themselves
out to zero in normal flight conditions. They are not
designed to take any appreciable vertical loads.
Mostly they handle the horizontal loads created by the
lift struts. Just take a look at the number of rivets
holding the cromoly frame to the fuselage.
I have seen this done but it was certainly NOT
designed to take such loads and the rivets may have
been overstressed. At the very least you may break
your windscreen as happened in this case.
Just my 2 cents.
David
--- Carl <cgbrt(at)mondenet.com> wrote:
[quote] Les.
actuator.
very near normal.
insignificant.
Carl
victorbravo(at)sbcglobal. Guest
Posted: Thu Jan 31, 2008 12:30 pm Post subject: Lift sling for the CH-701 |
IMHO, it will be very safe to use a three point sling under the
fuselage. Wrap one loop of nylon strap around the upper engine mount(s)
AT the firewall for the front lift point, one nylon strap looped around
the fuselage just in front of the wing, and one nylon strap looped
around the fuselage just behind the wing. Tie thin rope between each of
the straps on both sides of the fuselage so the straps do not slide back
and forth relative to each other.Join the straps to a steel tube or
"load leveler" device under the crane or winch. This will divide the
weight between three points and not put any loads on any of your lifting
structure or fittings. It would seem that the issue of where to lift the
aircraft is a perfect question to pose to Chris Heintz, because he knows
more than anyone which points are loaded which way and how much.
Quote: |
Hi Carl.
Posted: Fri Feb 01, 2008 7:15 pm Post subject: Lift sling for the CH-701 |
To Les, David and Bill
Thanks for the info and advice. I will talk to Chris H..
Carl
Do nor archive
Posted: Sat Feb 02, 2008 11:11 am Post subject: Lift sling for the CH-701 |
Carl,
I suggest you contact Paul Reinders. He has a 701 that he changes from floats to skies by lifting the plane from these attachment points. I trust Paul. He has 35000 flight hours to his credit.
I'm an engineer and see no apparent reason why you should not lift the plane from the wing root attach points and, as I said, Paul has been doing this for some time now.
For more information email Paul at paaual(at)juno.com (paaual(at)juno.com)
Les
[quote] --
