Adding an opening window on a 701
dkandle
PostPosted: Tue Jan 29, 2008 11:01 am    Post subject: Adding an opening window on a 701 Reply with quote
I have bubble doors on my 701 and would like to make doors that have a window that can be opened in flight (mostly for taking pictures).
Has anyone out there built such a door?
I was thinking of making a pair of doors to the plans for the standard ones and make the top panel (with its own aluminum tubing frame) hinge up with latches at the middle of the door.
ch701builder
PostPosted: Tue Jan 29, 2008 3:10 pm    Post subject: Adding an opening window on a 701 Reply with quote
I have flown with Rob Hunker, here in Colorado. I don't know if he tracks the list, but I think you can get an email off to him from his information on the Zenith website.
Keith
TDY away from home, here in State College, PA.
dkandle wrote:
--> Zenith-List message posted by: "dkandle" <d_kandle(at)flywild.net> (d_kandle(at)flywild.net)
http://forums.matronics.com/viewtopic.php?p=161133#161133
ics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
ronics.com">http://forums.matronics.com
ics.com/contribution">http://www.matronics.com/contribution
Keith Ashcraft
ITT Industries
Advanced Engineering & Sciences
5009 Centennial Blvd.
Colorado Springs, CO
    80919
(719) 599-1787 -- work
(719) 332-4364 -- cell
keith.ashcraft(at)itt.com (keith.ashcraft(at)itt.com)
This e-mail and any files transmitted with it may be proprietary and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT Corporation. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mail.
sonar1@cox.net
PostPosted: Tue Jan 29, 2008 10:59 pm    Post subject: Re: Adding an opening window on a 701 Reply with quote
I have just such a door, with an opening window. It is as you describe, an aluminum frame, another piano hinge at the top, and latches in the middle.
The first version was too flimsy - using 1/2 inch tubing - not continuous - and relying on the plastic to take some of the strain. When we opened it, the front of it flew up, and broke off, cutting my copilot on the arm, and hurting his shoulder.
The current version uses 3/4 inch square tubing, welded to the correct shape. It opens easily, and pretty much stays open on its own. My photographer has a much better view than from the Cessna 172 that we used to use.
Fred Sanford..Santa Barbara, Ca....N9701...100 hours
kmccune
PostPosted: Thu Feb 14, 2008 3:37 am    Post subject: Re: Adding an opening window on a 701 Reply with quote
Could you post pictures of this set up. I assume from your comment regarding your photographer that you open it during flight?
Kevin
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
