bradfnp(at)msn.com Guest
Posted: Sat Feb 16, 2008 2:54 pm Post subject: Torque values |
I am getting ready to put the cabin floor back together and I am curious
about the torque values for the 3/8" nuts/bolts. Specifically for the rudder
lateral and center bearings, rudder pedal brackets, etc. My copy of the
standard aircraft handbook says that a fine thread, 3/8" nut/bolt should be
tightened to 160 to 190 inch pounds, and my beam-style torque wrench is in
foot pounds. I ASSUME then, that I would divide the 160 by 12 to get
13.3333(etc) foot/pounds, which is what I should read off the wrench.
Any thoughts?
Brad Cohen
XL/TD, slow-build kit
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Feb 16, 2008 3:18 pm Post subject: Re: Torque values |
Correct on the torque wrench conversion.
Hopefully some of the others will chime in but on things such as the hinges I don't think standard torque values would apply. I think that in such cases "snug" would be sufficient. On the hinges you are just trying to capture and hold the bearing and since it is a steel / aluminum interface I think you could easily overdo it.
Tim
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Sat Feb 16, 2008 3:20 pm Post subject: Torque values |
Your conversion is correct. But the range of your foot-pound wrench may not
be suitable to a small torque value:
"For instance, did you know that your torque wrench-freshly calibrated by
someone traceable to the National Bureau of Standards-is not accurate in the
first 1/6th and last 1/6th of its range? That's right: a 100 ft.lb torque
wrench is accurate only over the middle 2/3 of its range. So it should not
be used for anything outside of 16?84 ft?lbs! Size the wrench to the job,
and don't fool yourself into thinking that you can just figure the
conversion from in lb to ft?lb, set that 100 ft?lb torque wrench to 3 foot
pounds, and have 36 inch?pounds. No telling what you'll have, that far away
from the calibrated zone. "
http://www.vansairforce.org/articles/tips/tip_torque_bolts.html
-- Craig
jswanson(at)jamadots.com Guest
Posted: Sat Feb 16, 2008 3:37 pm Post subject: Torque values |
Posted: Sat Feb 16, 2008 3:46 pm Post subject: Torque values |
Also I believe all the nuts you are writing about (rudder pedal bearings)
use self-locking nuts which have significant drag torque. In that case what
you should measure is the total torque (drag plus desired). As it says in
the Zenith Constructions Standards:
"Drag torque: Run the nut down to near contact with the washer and check the
friction drag torque required to turn the nut. Add the drag torque to the
desired torque. This is referred to as the final torque which should
register on the indicator or setting on the torque wrench"
www.zenithair.com/pdf-doc/zenair%20construction%20standards%20draft%201-07.p
df, page 32.
If you have a copy of the Sky Ranch Engineering Manual, read the section on
torque accuracy in chapter 7 "Fasteners and Failures". I love this part at
the start of chapter 7: "What is a bolt? A bolt is a very stiff spring..."
-- Craig
Joemotis(at)aol.com Guest
Posted: Sat Feb 16, 2008 5:23 pm Post subject: Torque values |
Go buy a click/stop quality torque wrench calibrated in inch/pounds right now.
Mechanics torque is not acceptable.
Every single fastening device on your aircraft has a torque rating and a whole lotta critical ones are in inch/pounds.
Let me repeat that mechanics torque is not acceptable...
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
psm(at)ATT.NET Guest
Posted: Sun Feb 17, 2008 3:27 am Post subject: Torque values |
Hi Brad,
Yes, inch pounds are 1/12 as much as foot pounds.
I found that lighter strength torque wrenches are calibrated in inch
pounds and heavier ones in foot pounds. That means you can
(apparently) resolve the torque on smaller bolts to one half of an
inch pound and on larger bolts to one half of a foot pound. You may
find it a better choice to have one torque wrench calibrated in each unit.
Paul
XL fuselage
At 02:48 PM 2/16/2008, you wrote:
| Quote: | I am getting ready to put the cabin floor back together and I am
curious about the torque values for the 3/8" nuts/bolts.
Specifically for the rudder lateral and center bearings, rudder
pedal brackets, etc. My copy of the standard aircraft handbook says
that a fine thread, 3/8" nut/bolt should be tightened to 160 to 190
inch pounds, and my beam-style torque wrench is in foot pounds. I
ASSUME then, that I would divide the 160 by 12 to get 13.3333(etc)
Any thoughts?
Brad Cohen
n801bh(at)netzero.com Guest
Posted: Sun Feb 17, 2008 11:14 am Post subject: Torque values |
these are pretty basic questions about torque. I read somewhere you built a "sabrina" motor... Didn't you learn the basics about bolt torque during that process???
Ben Haas
N801BH
www.haaspowerair.com
-- "Sabrina" <chicago2paris(at)msn.com> wrote:
--> Zenith-List message posted by: "Sabrina" <chicago2paris(at)msn.com>
"I am getting ready to put the cabin floor back together and I am curious
be tightened to 160 to 190 inch pounds, and my beam-style torque
wrench is in foot pounds. I ASSUME then, that I would divide the 160 by 12 to get 13.3333(etc) foot"
Am I missing something here? It is not true that the pedal bearing attach bolts are AN3 or 3/16 hardware with a 3/8" head? The torque values given by Zenith are based upon the shank size or AN number not the physical size of the socket needed to torque it. Correct?
Per Drawing 6-B-9 they are AN3-5A and AN3-15A (3/16") NOT AN6! (3/8") So too, the Central Pedal Bearing bolts have special torque values since they control the amount of "grip" or resistance encountered when operating the pedals and are adjusted after the nose gear and rigging are installed. Just snug until then.
http://forums.matronics.com/vie================================================================================================; - MATRONICS WEB F================================================nbsp; &================================================
_____________________________________________________________
Click here to compare top medical billing products, get demos, and quotes.
Posted: Sun Feb 17, 2008 12:25 pm Post subject: Torque values |
Odd that "THE NUMBER ONE problem" doesn't appear to be addressed anywhere in
the plans or assembly guide. I just checked both. Did I miss something?
Certainly the pedals were stiff on my QBK. But it didn't help that ZAC
painted the whole assembly including the section where the bearing blocks
ride. I guess they compensated for this by using bolts that were too short
through the bearing blocks. The threads didn't even engage the nylon in the
self-locking nuts.
-- Craig
bryanmmartin
Posted: Sun Feb 17, 2008 1:50 pm Post subject: Torque values |
The proper torque on a bolt is definitely based on the size of the
bolt shank, NOT the size of the head.
On Feb 17, 2008, at 12:54 PM, Sabrina wrote:
curious
the rudder
the
should
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Jeyoung65(at)aol.com Guest
Posted: Sun Feb 17, 2008 2:42 pm Post subject: Torque values |
Standard torque should be to the nut not the bolt. Also my manual list the torque for AN-365 nuts on AN-3 should be 20 inch lbs. not 160 to 190 "#. Jerry of Ga
In a message dated 2/17/2008 4:51:51 P.M. Eastern Standard Time, bryanmmartin(at)comcast.net writes:
| Quote: | --> Zenith-List message posted by: Bryan Martin <bryanmmartin(at)comcast.net>
| Quote: | --> Zenith-List message posted by: "Sabrina" <chicago2paris(at)msn.com>
curious
the rudder
the
should
Bryan Martin
N61BM, CH 601 XL,
do not nbsp; he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sun Feb 17, 2008 2:48 pm Post subject: Torque values |
I am a bit puzzled by your reply, Ben.
This question about torque was posted a day or so ago, and there were
several responses. But Sabrina was the only one who looked carefully at the
issue and realized that the bolts in question were 3/16" AN3 bolts with
3/8" hex heads (with a standard torque of 20-25 in-lbs), not 3/8" AN6 bolts
(with a standard torque of 160-190 in-lbs). When I saw her reply this
morning, I burst out laughing, and immediately told my wife about her post.
There have been several replies to the original post by our older,
experience builders addressing various aspects of the appropriate torque
wrenches to use for 190 ft-lbs of torque. But it took a very bright 16-year
young woman builder to point out that the underlying premise of the whole
question was flawed.
Sabrina, I take my hat off to you. You are super. It looks to me like you
understand not only torque, but are bright enough to realize that the wrong
question had been asked (and answered). Well done!
Terry
At 07:05 PM 2/17/2008 +0000, you wrote:
| Quote: | these are pretty basic questions about torque. I read somewhere you built
that process???
Ben Haas
N801BH
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Posted: Sun Feb 17, 2008 5:44 pm Post subject: Torque values |
Holy Crap Batman!,
I did'nt realize that I would set off such a firestorm by asking about
torque values!
Thanks to all that chimed in, this has been an exciting, and at times, very
frustrating experience (But who would have it any other way?)
I am a first time builder and unfortunetly don't have a lifetime of
experience in aircraft maintenance, So some things I am learning as I build-
and as Shirley at ZAC can affirm, I have bought lots of replacement parts in
the process!
Thanks again to all, and to Ben, I have no idea what a sabrina motor is, and
torque values were not part of my E.R. nursing curriculum!
-Brad
XL/TD
| Quote: | From: Terry Phillips <ttp44(at)rkymtn.net>
Reply-To: zenith-list(at)matronics.com
Subject: Re: Re: Torque values
Date: Sun, 17 Feb 2008 15:43:38 -0700
Terry
>that process???
>do not archive
>Ben Haas
>N801BH
>rudder
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Posted: Sun Feb 17, 2008 6:05 pm Post subject: Torque values |
Hi Sabrina. It has been a few years since I worked through that part of my 801 but if I remember correctly I torqued it to the proper spec but there was a little too much drag on the pedals. Since I have a complete machine shop I set up the bearing in my milling machine and took out .0006" or so to give it a slight bit more clearance. I am guessing the 601 uses the same green Delrin material for the bearing block...?
As for the other question, I LOVE my 801, The V-8 Ford in it is most impressive.... Thank god for experimentals.!!!!!!!!!
Ben Haas
N801BH
Haas International Airstrip (2WY3)
4 Miles North of Merna, Wyoming
Owner: Ben Haas
Do not confuse the airstrip with a nearby paved, lighted runway that is over 6,000 in length.
I wish I owned an International Airport! Ben, how does your 801 fly? What torque value would YOU recommend the for the "central pedal bearing?
If Roger had not said this exact issue is THE NUMBER ONE problem, I would not have replied.
Sabrina
http://forums.matronic========================================================================bsp; - MATRON================================================; - List Contribution Web Site sp; &nb===================================================
Prepare for the unexpected. Click now to prepare a living trust.
Posted: Sun Feb 17, 2008 6:42 pm Post subject: Torque values |
I might be behind the power curve here because it takes 2-4 weeks for a posting on Matronics to make it to Wyoming where I live.... I didn't see the earlier posts reguarding the torque issue. { .. Don't get me wrong, Sabrina is on the way to a great life with her knowledge and zest. Her parents should VERY proud. !!!!!!!!!!!!!!!!!!
Ben Haas
N801BH
-- Terry Phillips <ttp44(at)rkymtn.net> wrote:
--> Zenith-List message posted by: Terry Phillips <ttp44(at)rkymtn.net>
Terry
that process???
Ben Haas
N801BH
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
http://www.mykitlog.com/N47TP/ ========================bsp; - The Zenith-List Email Forum -<========================;  ========================bsp; - List Contrib ========================================================
Best selection of Bibles. Click Now
txpilot
Posted: Wed Feb 20, 2008 7:48 am Post subject: Re: Torque values |
Brad,
Getting back to the original subject, page 7-301 of AC 43.13-1B shows proper torque values. Yes, they are based on shank size, not wrench size. I have this page posted on my workbench as I seem to refer to it almost every day.
As opposed to a torque wrench you'd find at Home Depot, I strongly recommend taking the plunge and buying a quality torque wrench. I have one from US Tool - model TP349 and it's great. If you're planning on installing a Rotax, You'll definitely use the metric (Newton-meter) side for your engine work. I know it's expensive, but IMHO it is a must-have. Here is their website:
http://www.ustool.com/
That's my two cents.
Dan Ginty
N787DG
90% complete
715.5 KB |
763 Time(s) |
planecrazydld(at)yahoo.co Guest
Posted: Wed Feb 20, 2008 7:12 pm Post subject: Torque values |
don't forget that you need a calibration check at least once a year. Before the flames start to bloom, a simple fixture with a crank arm in a bearing and a tared bucket with water in it (pure water is 1 gram/cc; 453.6 grams/pound) is a good functional check.
txpilot <djg7(at)comcast.net> wrote:[quote] --> Zenith-List message posted by: "txpilot"
Brad,
As opposed to a torque wrench you'd find at Home Depot, I strongly recommend taking the plunge and buying a quality torque wrench. I have one from US Tool - model TP349 and it's great. If you're planning on installing a Rotax, [quote][b]
