robertrv607(at)yahoo.com Guest
Posted: Mon Feb 18, 2008 9:52 am Post subject: Control Vision Exp2Buss Service |
Hello:
Hope some one can help,,, only those with the Exp2Buss, I haves tried to contact some one at
Control Vission sent E mails, nothing... terrible service...
I recently found, that after flying a few minutes, I get a complete electrical failure... ;no good..
As I said I have the exp2 buss unit from "Control Vision", I had sent the unit before to be checked, which
cost me money. they return it saying is was OK>..
Once I reset the master switch, everything goes to normal...
Everything has been installed as per Manual,.....
Any one has any idea, what to check or why? how is your Installation works for you....
bert
Be a better friend, newshound, and [quote][b]
pbesing(at)yahoo.com Guest
Posted: Mon Feb 18, 2008 12:03 pm Post subject: Control Vision Exp2Buss Service |
To me, I never understood the benefit of a solid state unit like that. My opinion is that if an electrical system works great with good old fashioned breakers and buss bars, go with it. I would never trust an entire electrical system to one unit. I say if you have the means to put in a buss bar and breakers or even better, switch/breaker combos, I so go for it and ditch the expbus.
Paul Besing
deanpichon(at)msn.com Guest
Posted: Mon Feb 18, 2008 12:34 pm Post subject: Control Vision Exp2Buss Service |
I can't speak to Control Vision customer service, but I have been very satisfied with the Exp2Bus. I have 400hrs on mine with no problems to date. Does complete electrical failure meet no power to the Exp or no power from the Exp. The former suggests a problem other than the Exp, while the latter suggest either the primary relay is bad, or every resettable fuse is tripping which seems rather unlikely.
Good luck,
| Quote: | Date: Mon, 18 Feb 2008 09:49:46 -0800
Subject: Control Vision Exp2Buss Service
To: rv-list(at)matronics.com
.ExternalClass DIV {;} Hello:
bert
Be a better friend, newshound, and | Quote: |
t=_blank>http://www.matronics.com/Navigator?RV-List
p://forums.matronics.com
| Connect and share in new ways with Windows Live. Get it now! [quote][b]
Dale Ensing
Posted: Mon Feb 18, 2008 1:35 pm Post subject: Control Vision Exp2Buss Service |
Bert,
It sounds like the master relay on your EXP buss may be opening after a few minutes. This could be because of a poor connection in the energizing wiring circuit to the circuit board mounted relay since Control Vision said the unit checked out OK. Suggest you check out all the crimp connectors in the circuit and the master switch.
I have been flying for three years with the EXP bus in my 6A with no problems but I have an external master relay and did not use the EXP circuit board mounted relay.
Paul,
I agree with you...Knowing what I know now about designing and installing 'a good old fashioned buss bar and breakers' I would not use the EXP but it has served me well so far. Doing it again I would probably go with auto type blade fuses.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
