msm_9949(at)yahoo.com Guest
Posted: Tue Feb 26, 2008 1:16 pm Post subject: OT: Wind turbine, WAS Shortest STOL record ever? |
Are we sure the prop on that machine was facing into the wind? Don't vane-less wind generators usually have the generator/gearbox nacelle on the up-wind side and the prop turning on the down wind side? That would make the break-up slightly more mysterious as blades would then tend to be pushed away from the tower structure.
Michel Verheughe <michel(at)online.no> wrote:
[quote]"Tom Jones" wrote:
| Quote: | Michel, in the case of the wind generator the wind is turning the prop which is
facing into the wind. Think about it.
Hum ... do you want me to think, Tom? I guess, you're probably right ... if I compare to a helicopter rotor.
John Alexander wrote:
[quote] I flew gyroplanes for some years, and similar things happen when a
rotorblade Be a better friend, newshound, and [quote][b]
