psm(at)att.net Guest
Posted: Tue Mar 11, 2008 8:15 am Post subject: Accident in Spain was a Zodiac 601XL and there is a pictur |
Hi Andy,
This is a good question - what could cause an explosion. Indeed, I
remember another report of an explosion that seemed to just precede a
structural failure. I also remember a report of an engine revving
irregularly just before the explosion. Perhaps I am mixing and
matching different incidents, but I remember both reports.
I would guess the most likely ingredient for an accidental explosion
would be loose fuel in the cabin. There really isn't a way you could
get a lot of loose fuel in the wing structure since the fuel is
stored on the front side of the mostly solid wing spar.
I can envision a fuel leak combined with a wing mounted fuel pump
that forces a lot of fuel into the cabin. This isn't as likely if
the normal fuel pump arrangement is used because a leak would give
the pump in the engine compartment just air to suck on rather than
fuel. A cabin full of fuel vapor and air combined with a spark of
some sort might give a big fuel-air explosion.
Please note that the theoretical explosion described above has no
basis at all in a structural design or construction issue. It is
based on a simple failure in the fuel system combined with an
ill-advised arrangement of fuel pumps.
As far as I know, there has been no proven wing design problem. I
don't know where that idea came from. There have been wing
separations, but I can't remember any confirmed explanation as to why
that separation occurred. Since Chris Heintz has reexamined and
retested the wing structure since the first few structural failures I
think it would be foolish to make a major wing design change with the
hope of solving a problem. Any major change, like adding ribs, would
be just as likely to cause new problems as to solve any old ones.
I personally feel there is no point in trying to come up with some
mathematical explanation of the accidents with the hope of computing
odds of failure of any new plane. This might help you sleep at
night, but I don't think it is a valid analysis technique for this
kind of problem. There have been several airplane designs in the
past that had horrible accident records and structural
failures. None of these were random in nature. They were
expressions of latent design problems that were eventually identified
and fixed. The planes I am thinking of for this point are the V-tail
Bonanza and the Lockheed Electra.
As for personal decisions, I think everyone considering flying a
Zodiac XL (like me) should come to terms with the notion that this is
a dangerous activity that could end in disaster. If you can't live
with that then you shouldn't be flying this or any other experimental
airplane. To pretend that experimental airplanes are anything other
than dangerous is just kidding yourself.
Paul
XL fuselage
At 08:16 AM 3/11/2008, you wrote:
| Quote: | What would cause an explosion, leaking fuel tank into the wing
structure? Empty tank that for some reason exploded?
skyguynca
Posted: Tue Mar 11, 2008 8:53 am Post subject: Accident in Spain was a Zodiac 601XL and there is a pictur |
While the loud bang was heard and a falling twisting mass was see does not
necessarily mean something exploded. Has anyone here see a wing tested to
failure? I have see a 747, 727, Cessna 310, 210 and 150 wing tested to
failure......when they finaly failed, it was a very surpisingly loud bang.
What the witnesses heard could have just been the structual failure......The
one thing I never saw in the reports were evidence of a fire in the air or
witnesses seeing a smoke trail to the ground.
David Mikesell
Cloverdale, CA 95425
