gmcjetpilot
Posted: Sat Mar 08, 2008 6:48 am Post subject: Honda Piston Engine (never happen) |
First the Lyc is perfectly adapted to
aircraft use. It's like a Alligator, may
be prehistoric but its design is made
for the mission. A "Honda" will be
heavier, more cooling drag, cost more
and in the end will NOT have better
economy or performance. True, read on.
>From: "mike humphrey"
| Quote: | Then why did Honda buy 53% of
Continental stock? I believe that is
the last % that I saw. According to
Honda's own press release they were
going to use the Continental as their
springboard. The release of the 'Honda
engine' was going to be in three phases:
>1. conventional engine based on the
| Quote: | Continental but with Honda
manufacturing techniques, ie improved
metals, air cooling, etc.
Mike no offense but your comments are
based on myth and miss information. WHAT
modern metals and materials? Really I
have to hear this? The fact is the low
production is what cost money. The
"metals" used are STATE OF THE ART. There
is nothing BETTER. Manufacturing? Well the
detailed high precision Grade class A1
castings are complicated x 100 than a car
engine. The crank materials, forgings and
QC is beyond what a car engine part
needs.
>2. was to be still Continental based but
| Quote: | with EFI, EI, better pistons,
higher TBO,
Lyc/Continental offer FULL FADEC? What are
you talking about? Higher TBO. 2000 hours is
not enough. That is like 1/2 million miles
in a car. This IDEA that there is
something OLD or inadequate with a
Lycoming and Continental is ignorance.
Car engines run around at 25% power most
of the time. A Ly or TCM can fly along at
75% for 2000 hours. A car engine can not
do that. Why do race cars rebuild there
engine ever 1/4 mile or 200 or 500 miles?
| Quote: | 3. was to be 'The Honda Engine', flat 4
and 6, all the above improvements, even
better manufacturing techniques-more
like auto engines, and the biggie, water
cooled, and VERY extended TBO, no more
air cooled engines, improved cabin
heating ability, no CO threat at all,
noise reduction, interchangeable auto
parts right off of the shelf.
Water cooling? Who wins reno air races
every year? Big air cooled radials from
the 40's and 50's. There is SOOOO much
air available and we never park and run
the engine at high power water cooling is
a JOKE JOKE JOKE. Yes IN A CAR, water
cooling makes the engine mechanical noise
quieter, yes reduces emissions due to
tighter piston/cylinder wall clearances.
COOLING DRAG = HUGE IN WATER COOLED
AIRPLANES. Look at all the Subaru's and
rotaries. There are flying R&D, test
pilots all. They are heaver, tend to go
slower AND/OR burn way more gas. Air
cooling is IDEAL for aircraft. WHY. Noise
is not an issue because with prop and
exhaust and slip stream nose the
clacking of the valves is a small part of
the noise signature. When you put water
jackets on a Lyc (Like the "cool jugs", a
Lyc sounds like a Subaru. Emission? Not
and issue. WHAT DO YOU DO WITH THE
RADIATORS? Well the P-51 was made around
the engine. The P-38 Lightning? Same
thing. Most tractor GA planes or kit
planes are a Jury RIG of stuff radiators
somewhere to make it work. Most under size
the radiator and run hot. I'll admit that
cooling on a HOT HOT day and tight cowl
with gross weight climbs to 8,000 feet
might mean you have to watch CHT, but
with time in 3 or 4 types of
experimentals and 40 GA piston planes
from C-152 to several turbo charged twins
I can tell you engine management is NOT
HARD. OH MY GOSH, THERE IS A MIXTURE
KNOB, WHAT DO I DO? Move it about 4-5
times a flight.
| Quote: | Doesn't that sound like exactly what all
of us want and have complained about
Lyco's forever?
What complaints? I have 16,000 hours and
made, most in jets now but spent 1000's
and 1000's of hours behind one or two
Lycs and they where rock solid dependable
all going to or past TBO?
>They anticipated the TBO to be in excess
| Quote: | of 10k hrs. Instead they go after an
even smaller market - The Honda Jet.Mike
H 9A/8A
Look both Honda and Bombardier tried to
come out with engines. Honda got as far
as a picture. Bombardier got as far as
pictures and some specs for a few model.
THEY WHERE HEAVY! They where expensive
and they where better? Look when these
engines are cheaper than a Lyc or Lyc
clone, where I can go out and buy a BRAND
NEW O-360 or IO-360 for $21,000 and get
and engine as light, reliable and simple
than I'll look at it.
Bottom line all the "WATER COOL" Car
based engines are at least several or all
of the following:
-heavier
-More noise
-low on power
-fuel burn same or higher than air cooling
-more cooling drag to day (except maybe P-51)
Most auto engine conversions are 100 lbs
more. The Mazda rotary is loud. The
others are spinning fast are have a higher
pitch noise and vibration. Different yes
but better? No.
Auto engines advertise the peak HP as
at near red line, but in airplanes operate
will below peak HP. Most of the car
engines do not get any better fuel
consumption than a Lyc or TCM. Well
because Lycs/TCM have a mixture control
and usually EGT gauges. Some even run
LOP. The AUTO engine EFI with O2 sensor
(which last a few hours with avgas) and
open/closed loop does nothing at high
power settings. I'd rather have manual
mixture control.
The Lyc has:
two cables - Mixtures and Throttle
One fuel line and a mechanical pump
Two P-leads to self powered mags
So two push-pull cables, two single wires
and one fuel line is all that is needed
and NON requires electrical power. The
MODERN engine needs computers and has
one spark plug & needs dual electric pumps,
two batteries and blaa blaa blaa.
There is something elegant in a simple
air cooled engine independant engine.
Honda bought TCM because it was cheap.
Honda engines are just 4 stroke piston
reciprocal "otto cycle" engines just like
a Lycoming. THERE IS NOTHING NEW.
4 valves per cylinder or water cooling is
NOT NEW. It has been around since the
20's. The Lyc does not use any of this
because its NOT NEEDED or desirable.
mike109g6(at)insideconnec Guest
Posted: Sat Mar 08, 2008 11:08 am Post subject: Honda Piston Engine (never happen) |
So was the Model T Ford. It's called - Progress. When is the production of 100LL supposed to be stopped? Another US manufacturer that can't keep up with times-like the auto industry. What kind of car do you drive? Where is it built? Not US, is it, I bet? The 'issues' pointed out as to reasons against, are simply based in conjecture. There is absolutely no data to support: heavier, more drag, increase cost and not better economy or performance. Zip, Nada. Those are not constructive arguments, only opinions.
With regards to that rant following, the person has never built/flown a Full Fadec IO Lyco-it needs everything that he states that it doesn't.
Everyone is entitled to their opinion. But one should leave the emotional outburst for the pulpit. What I was trying to point out is that if US A/C engine manufacturers don't look past today, tomorrow will make them extinct.
I'd be the first to admit that I hate change. But sometimes it's necessary for survival.
Enough on this subject, it's like beating a dead horse,
Mike H
rv7(at)b4.ca Guest
Posted: Sat Mar 08, 2008 6:03 pm Post subject: Honda Piston Engine (never happen) |
On 6:45 2008-03-08 <gmcjetpilot(at)yahoo.com> wrote:
| Quote: | Lyc/Continental offer FULL FADEC? What are
in a car.
1/2 million miles in 2000 hours is 250 mph. That's a pretty fast car that
you're driving for 2000 hours. Unless you really meant "1 to 2 million
miles," in which case you're only talking 60-120mph, average, for 2000
hours. Most cars on the road today would do well to average 40mph, let
alone 60.
| Quote: | Water cooling? Who wins reno air races
the 40's and 50's.
For many years Strega and Dago Red (both P-51's) traded the checkered flag,
while Rare Bear (Bearcat), Dreadnought (Sea Fury), etc. trickled in behind.
| Quote: | COOLING DRAG = HUGE IN WATER COOLED
AIRPLANES.
Cooling drag is huge in all airplanes. The challenge is minimizing it.
The P-51 was able to get *thrust* from the cooling system at certain power
settings. Surely there's a way to realize similar gains with an automotive
conversion.
-Rob
tracy(at)rotaryaviation.c Guest
Posted: Sun Mar 09, 2008 6:52 am Post subject: Honda Piston Engine (never happen) |
On Sat, Mar 8, 2008 at 10:45 AM, <gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)> wrote:
| Quote: | Bottom line all the "WATER COOL" Car
of the following:
-heavier
-More noise
-low on power
I've already confessed that alternative engines are a mistake for most builders but couldn't let this go unchallenged :>)
-Heavier
Not necessarily. My Mazda powered RV-4 empty weight (but including engine oil) is 948 lbs. This is at the light end of the spectrum.
-More noise
True, but only when not running a muffler. Measured with a sound pressure instrument, my muffled rotary was a couple of db less than a Lyc on fly-by at same airspeed.
-Low on power
My rate of climb solo with 1/2 tanks on a standard day is 2650 fpm with a fixed pitch prop. This was measured back when I was running an early 13B rated at 160 HP. No documentation to support that, just my word. That same engine turned in a standing start average speed of 209.2 MPH in 2003 and 217.56 MPH in 2004 Sun 100 air races. These are numbers you can verify.
After all the agony of installing an alternative engine (and there was a lot), it was all worth it for that radio call - "Race 25, Race 29 is passing high and outside" for the first place win in Category 8. Life is defined by moments like that!
- Fuel burn higher
Sometimes yes. At low altitude, it looks like I burn about 5% more than an agressively leaned Lycoming. The guys that run ROP Lycs burn slightly more than I do. My fuel numbers look best at high altitude. At 15,500 ft. throttled back to 172 mph TAS it burns 6 GPH. Most RV drivers think this is fantastic but a lot of Lyc powered RVs could show similar numbers if they throttled back a bit.
None of this was accomplished by spending cubic dollars, fancy airframe mods or ultra precise building. The RV-4 was built on a $20k budget (1994 dollars) and most pilots would describe it as 'rough around the edges'. I do think it was built with a good understanding of how cooling drag is minimized in a liquid cooled installation. I'm sure Honda could do better but true, there ain't no money in it for them.
Tracy Crook
Bubblehead
Joined: 26 Oct 2007 Posts: 48 Location: N. Richland Hills, TX
Posted: Sun Mar 09, 2008 7:20 am Post subject: Re: Honda Piston Engine (never happen) |
in a car.
alone 60.
Someone needs to check their math!
1/2 million miles/2000 hrs = 250 mph
1 million miles/2000 hrs = 500 mph
2 million miles/2000 hrs = 1000 mph ----- not 60-120!
_________________ John
Keller, TX
RV-8 N247TD |
gmcjetpilot
Posted: Sun Mar 09, 2008 10:46 am Post subject: Honda Piston Engine (never happen) |
| Quote: | Progress. When is the
stopped?
We will eventually go to 96UL or 98UL
like Europe and 80% of all aircraft will
run nicely on that, including my O-360 Lyc.
| Quote: | Another US manufacturer that can't keep
You got me two Acuras, and a '67
Camano.
| Quote: | The 'issues' pointed out as to reasons
You just don't know what you are talking
about. All the EAA cross country races
are won by TCM/Lyc. All the Reno racers
in the top gold ultimate class are P&W
radials, with a few V12 merlins as also
ran. The sport class is mostly TCM/Lyc
with occasionally falcon V12 water cooled
race engine. Put up or shut up. There is
lots of talk but no proof on your part.
Van did a fly of on Power Sport Rotaries.
We are talking 200HP rotaries (alleged)
with $9,000 electric MT props and all
they could do was match or slightly beat
a 180 Lyc, at the cost of an extra 4 or 5
gal and hour and lots of noise. Van
tested an Eggenfellner RV-9A against a
320 Lyc factory RV-9A. Again OK but
nothing better. In fact the Egg ran hot,
slower and gas mileage was not better. It
also made not less noise or vibration,
just different buzzy high Freq noise and
vibration (because the engine is spinning
fast).
Conjecture? Negative Mike, I have been in
EAA since 1985 and followed alternative
engines carefully. I have a masters in
engineering, 9 FAA ratings and 12,000
hours, 1,500 hours in RV's. It is true.
Cooling drag with most (not all) water
cooled adaptations are higher than air-
cooled engines. To be fair air-cooling
has 70 years of R&D with millions if not
billions spend on optimizing it.
| Quote: | that he states that it doesn't.
I have no idea what that means? However
if you are running a freight or corporate
business with some C421's or Aerostars or
Rockwell commanders (piston) I can see
where FADEC would be worth it. However
for GA and 100-150 hours a year, FADEC is
a lot to do about nothing. You need all
these sensors to work and all you get is
one less knob. I love the mixture control
on my plane and the work load of moving
it 4 times a flight is well, a no
brainier. The EFI on car engines don't
work well. Real World Solution and SDS
have EFI or ECU's for car to airplane
conversions. The RWS even give the pilot
a mixture control. My point is EFI is
great for a car going from idle to
acceleration and idle to acceleration
over and over. In a plane at one power
setting 90% of the time, other wise its
wide open or coasting, EFI or ECU's or
FADEC has little value for way more
complication and a million extra failure
modes.
| Quote: | But one should leave the
There is no emotion. I am an airline
pilot and have an engineering degree.
It's all fact and science. You on the
other hand WANT so badly for something
NEW and better and you believe all the
hype. The Lyc/TCM are brilliant pieces of
engineering. Any short coming is a
planned compromise not some hair brained
screw up. They are indeed state of the
art. Physics and the laws of
thermodynamics have not changed in the
last 1000 years, as far as I know. You
can't compare CAR duty to an airplane's.
| Quote: | that if US A/C engine manufacturers
That is a fair point. So the new
DeltaHawk Diesel, where is that? The
Thielert Diesel had a dual flame out
because the ECU died because the
batteries where low or something? The new
Diamond twin crashed. People using the
engine are having terribly short TBO.
You can't make a "LIGHT" diesel PROGRESS!
Look if I was starting a new engine from
scratch in the 180 HP range, it would be
a horizontally opposed, air cooled direct
drive, hyd prop, engine. Hummmm what
would that look like? Oh yea it would
look like a Lycoming or TCM.
There is something to be said for a Lyc
with dual mags (self powered) and a
mechanical fuel injection or carb. They
are dead simple, reliable even if they
are "farm tractor" technology they don't
stop flying EVER, unless you run out
of gas or something really big lets loose.
Electrical independence is GOLDEN.
Most of the car improvements has been
in the electronics, which is a milestone
for cars, but not so much needed in a
piston plane.
| Quote: | change. But sometimes it's necessary
for survival. Enough on this subject,
it's like beating a dead horse, Mike H
Yes Mike you beat the horse, burned it,
ate it, **** it out and than threw it on
the wall, ha ha.
I know you want something better but when
you fly Lycs like I did everyday for
years and years as a CFI and Freight
pilot and corporate pilot, you will
appreciate them more than have fear and
loathing out of ignorance. You are
listing to the kool-aid drinkers who
think automotive engines are the best
thing in the world. The thing that kills
aircraft engines is sitting for weeks and
months and years at a time. You fly every
day and keep the engine within limits
(which is easy) and change the oil, it
will last to TBO. If your car sat for
weeks and weeks and years than you jumped
in and started it, and got on the free
way and drove 120 mph for 4 hours, than
parked it for a few months and did that
again, with out changing the oil and
running it as hot as you can get it. I
guarantee your car engine would not last
very long. Stop believing all the bad
things you hear about Lycs and TCM.
TCM/Lycs are out there flying 1000's and
1000's of hours every day/wk world wide.
Yes stuff happens and a lot of it has to do
with abuse and poor maintenance. When it
comes to the design and QC of the parts
and materials they are SECOND TO NONE.
Yes TCM and LYC both went through their
own crank shaft QC disaster in the early
90's for TCM and lat 90's for Lyc. There
is no excuse and they are embarrassed
(and sued). Stuff happens. However the
cranks made for 4 decades before and the
decade since are fine. Cheers
On last note about other countries are
taking or stealing Americas markets,
ie, "I drink your milkshake".
Yep it can and does and will happen. I do
like Japan car companies and the USA
ones are floundering. I hate that in all
trade agreements such as NAFTA,
trade with Euro and China, screws the
USA. They cheat and we let them.
Enough. We still have the best scientest
and engineers. They just steal, copy than
improve, while using slave labor to
undercut our market.
The LSA market
is dominated by foreign manufactures
and engine maker. Why did we make
laws (FAR's) to benefit them and exclude
American planes. Our planes are bigger
and heavier because they need to be.
Two adult men and fuel in a LSA will
be over the 600kg gross. Rotax? Is
an overpriced piece of junk. Hard to
maintain, over rated power wise, they
just had a "gear box failure". So over
weight, under powered planes for the
US market, Progress? America is a
big country with big people (sorry fat)
and little LSA's WILL BE FLOWN
over gross with two people. We need
more range and gross in America than
they do in Europe.
It is a joke and the gross should have
been raised to 1,500 or 1,600 lbs gross
so more US planes and engines could
comply. I would rather a O200 or O235
than a Rotax any day. At least TCM
is making a light O200 for the LSA
market for the Cessna LSA, which by
the way is MADE IN CHINA!
Goodgreef, yea let them drink our
milkshake, but bad mouthing Lyc is
anti-American. The Japanese, eruo
and Chinese are not brilliant, better or
smarter; they just exploit our market
while cutting off our products. Even
the US Air Force bought AIRBUS!
I can't believe it. The A300 is a piece
of junk. I KNOW! I fly the B767 and
it is way better than an Airbus, Why
do you think there are still 707's flying
as AWACS and tankers? They where
designed and built well. Northrop and
Airbus are just undercutting their price,
but they will have problems with them
and they will not last. The B52 is still
flying? Why? because its a Boeing.
I know America hating is in fashion
but not with me.
Ollie Washburn
Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
Posted: Sun Mar 09, 2008 11:30 am Post subject: Honda Piston Engine (never happen) |
Are you done now---
Ollie
On Sun, Mar 9, 2008 at 1:43 PM, <gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)> wrote:
[quote] >From: "mike humphrey"
stopped?
Camano.
| Quote: | constructive arguments, only opinions.
fast).
modes.
piston plane.
the wall, ha ha.
The LSA market
they do in Europe.
but not with me.
_________________ Ollie RV6-A & Rans S7S
Central FL |
rv7(at)b4.ca Guest
Posted: Sun Mar 09, 2008 12:02 pm Post subject: Honda Piston Engine (never happen) |
On 8:20 2008-03-09 "Bubblehead" <jdalman2000(at)yahoo.com> wrote:
| Quote: | Someone needs to check their math!
Whoops, you're right! I did that quickly late at night, and erroneously
thought that doubling the distance would halve the speed.
Still, my original point stands. Most automobiles would be lucky to
average 30-40 mph over their lives, let alone 250 or more.
-Rob
gmcjetpilot
Posted: Sun Mar 09, 2008 12:31 pm Post subject: Honda Piston Engine (never happen) |
| Quote: | From: "Rob Prior" <rv7(at)b4.ca (rv7(at)b4.ca)>
Subject: Re: Re: Honda Piston Engine (never happen)
> in a car.
| Quote: | That's a pretty fast car that you're driving
to 2 million miles," in which case you're
do well to average 40mph, let alone 60.
NO you missed the point an AIRPLANE doing
200kts for 2000 hours. That is a lot of
miles (460,000 statute miles). How far does
a car go in its life, on a good day? 1/2 that.
>> Water cooling? Who wins Reno air races
| Quote: | > every year? Big air cooled radials from
> the 40's and 50's.
| Quote: | 51's) traded the checkered flag,
Well not any more my friend, they can't even
come close with out blowing up. Also in WWII
the air cooled radials would get jugs shot
off and they would fly home with the
connecting rod flopping about. The P-51 got
one shot in the wrong place, it was toast.
Water hoses, radiators, pumps all things to
fail. True!
| Quote: | > COOLING DRAG = HUGE IN WATER COOLED
> AIRPLANES.
| Quote: | challenge is minimizing it.
Yea but we cracked the code with
horizontally air cooled tractor driven planes.
With the NASA research done in the early
70's, people like LoPresti & Barnard have
adapted the data; we have way way lower
cooling drag. Look at an RV with a Sam James
Cowl. About 25 sq inch of inlet. Now look at
what Eggenfellner has for his latest cowl,
two huge square scoops dumping into
radiators with little pressure recovery and
lots of drag, of all kinds. The stagnant
point is out side the cowl and there is all
kinds of external drag and internal loss. It
sucks. But he had to put these big scoops
to get enough air to go through those two
little heat exchangers to avoid overheating.
Now add a turbo and altitude to the
Eggenfellner engine. They will run hot, trust
me. Water cooling is not a panacea.
Car's can afford to have a radiator the size
of a large flat screen TV when they are
only going 70 mph and are in front of a
vehicle with a large flat plate area, so
fit and drag are not issues. A plane, going
200 mph, there is no room for a radiator in
the front of a small cowl.
You are minimizing frontal area and yes it's
a challenge, you are right. However with
air cooled horz AIRCRAFT ENGINES,
you have all the heads and cylinders, plus
oil cooler to shed heat. Because the whole
engine is a heat exchanger, its easy to duct
air to and through those fins, well not easy
but well understood. Now if like in WWII
billions in today's money was put into an
all new airframe and water cooled piston
engine, yea they could do something. But
just adapting a car engine with a PSRU
and throwing in some too small heat
exchangers where they fit is not optimal.
ITS JUST NOT A QUANTUM LEAP IN
TECHNOLOGY OR PERFORMANCE.
Sorry.
ON THE OTHER HAND, the Lycoming is
ONE BIG HUGE HEAT EXCHANGER.
However instead of going from air to liquid
and engine, it's just AIR & ENGINE. No
middle man, hoses, pumps or radiators.
Also Lycoming is LIQUID COOLED!!!!!!
Yes! What I'm talking about. Lycs have
OIL COOLERS, so they are actually air
AND oil cooled just like a BMW boxer
motorcycle and Porsche 911.
Yes the liquid cooled guys have a challenge but
the problem is they are using airframes
optimized for air cooled engines. So every
thing is a jury rig make do, make it work
adapt it fit it, not optimal. There is a RV-
10 going together with a P-51 belly scoop. I
am eager to see that fly and hope for the
best. Remember the P-51 sucked unless it was
going 400 mph. It over heated on the ground.
| Quote: | The P-51 was able to get *thrust* from the
cooling system at certain power settings.
gains with an automotive conversion.
-Rob
Yea I hear they shut the engine down and
flew on cooling thrust? ha-ha, Look there is no
such thing. It takes WORK or ENERGY to cool.
Yes I have heard the rumor but there is NO FREE
LUNCH in life, aviation or physics. Some where
you write out all the equations of P-51
aerodynamics and thermodynamics; you will
find a loss. Just having that scoop on the
belly with the flap open or closed is drag,
even if just parasitic drag. There is no
doubt cooling drag on reciprocating engines
is a large part of total drag. All the best.
Myths and legend does not make me think
water cooling is some panacea for GA
aircraft. P-51 does not = GA plane.
Water cooling has been around since
the Wright brothers. It is NOT new or
novel. It is in fact for all its pros has
cons, the net of which is a bit of a
negative in a GA plane, where simplicity,
lightness and low drag are king. Sorry to
burst peoples bubbles.
Lycoming and Wright, P&W and
Continental all knew what they where
doing when they made air cooled engines.
It was a choice not because of lack of
technology. It was there. It was just
not desirable.
I'll admit water cooling is "better". Meaning
it has more thermal capacity and is more
uniform and controllable (to get engines
warm faster), but water cooling can overheat.
Porsche 911 was air cooled up to 1998,
when they went to a water cooled version.
Why? Well laws on noise and pollution.
Water cooling dampens mechanical clacking
of valves and lifters. However in a plane
there is slip stream wind noise, prop noise
and exhaust noise. The difference is very
small, except on the ground to observers
outside while you taxi. Also water cooling
allows tighter piston/cyl wall clearance
which does lower pollution. Yes a Lyc
needs oil changes ever 25 hours because
it gets dirty. BTW the myth that Lycs use
oil, well they do, I go through about 1 qrt
per 16 to 18 hours. Many people get
well over 10 hrs/qt. So water cooling does
have that advantage. However I love changing
my planes oil and looking under the cowl.
On the other hand dirt bikes have mostly
all gone to water cooling, but than many
use titanium and magnesium in their engines.
A good new high tech dirt bike can cost as
much as some new econo cars.
To over take the Lyc and Continental it will take
a totally new technology with vastly better specs,
lighter, more hp per fuel burned, less expensive
and less cooling drag. Turbines fill many of these
but are vastly more expensive and burn more
fuel per HP. However after about 400-500 hp,
turbines start to earn their keep, at least for
applications that are going to be flown more
than a personal plane. Most of us only need
about 150-250 hp. Most auto engine conversions
are hard pressed to make this HP and still
be lighter. simpler more efficient. In the 100hp
and under class, car conversions are more
attractive and practical in my opinion. Still
in the 100HP range the O200 or O235 are
hard to beat.
Water cooling has little use in a plane.
If you want modern get a jet. Now a jets
for a plane that fly's 150 hrs a year by
a VFR pilot is a waste and not efficient.
Jets earn their keep in reliability and
speed, which is more for commercial
applications. Fuel burn of turbines, hp
per hp is beyond most individuals
budget.
In conclusion you should worship the
Continental & Lycoming, not vilify them.
They are engineering marvels and the grey
hairs, no doubt long retired, knew their
stuff. It comes after WWII development
that brought piston engines to their
pinnacle. Sodium filed valves than, now
roller cams, composite sumps, electronic
ignition, FADEC and so on. The Lyc and
TCM's are still evolving and getting better
and even CHEAPER. We now have not
one but THREE manufacturers of the engine
and countless others making accessories
and props for them.
They are in fact AIRCRAFT ENGINES
made for AIRCRAFT OPERATIONS, no
frill no fluff. What is great in a car commercial
like overhead cam's, 300hp (at 6 grand) or 4valve
per cyl. is not needed in a plane engine turning
2,500 rpm. If you want gear boxes and 6,000 rpm
engines, fine, go for it. Rotary? Sure but poor fuel
econ and noise are draw backs. Eggenfellner?
PSRU issues? may be? I don't know.
Go out, buy a new Lyc $21k, warranty & huge
network of support & large corporation behind
it, or go do unpaid test pilot duties for a
one man show, mom-pop business. I am cool
with either, it's your choice. Me? My engine
conversion involved converting about $12,000
into a used O360 Lyc & full overhaul. It bolted
right up to my RV-7 with factory engine mount,
cowl and a Hartzell prop. I know how fast it will
go and burn and what to expect. Done. Just
one mans opinion.
Notice I am not bashing Alt engines. I don't have to.
However notice that many alternative engine
proponents BASH Lycomings to make their self
feel better about their choice. If alternative engines
are so much better, than they could stand on
their own merits, not negative comments of Lycs.
I am just pointing to the many positive facts
about Lycs and TCM's and busting some myths
and urban legends.
Be a better friend, newshound, and [quote][b]
gmcjetpilot
Posted: Mon Mar 10, 2008 5:08 pm Post subject: Honda Piston Engine (never happen) |
Tracy I respect you and AGREE 100% with you. I never put
down alternative engines. I stated fact. Now how long have
you worked on you plane in hours? How many hours of
R&D and tweaking have you done? The answer is it does
not matter, because you are having fun. But bolt a Lyc on
it will give you known performance and less tinkering.
It is just a fact. Of ALL the alternative engines, the Mazda
conversion is the lightest and one of the best performers.
However the gas milage, noise and even oil use are not
trivial, and it's almost impossible to do anything about; it's
just inherent in the desgin. I have had Rotary Mazda's
since the 70's: RX2, RX3, RX7 and my friend has a
RV8. She gets terrible gas milage, has to use special
oil and needs to put oil in between oil changes. That
is a fact. That is how rotaries work. Even compared
to other sport cars with the same performance as the
RX8, like the Z car, the Mazda is a gas hog, and that
is in a car, "city millage", "highway milage". An aircraft
engine operates at very high power settings like 75%.
Car engines, are usually using less than 1/3 of rated
power. What does it take to do 65mph, 60-80hp?
I'll leave it to this article on the Power Sport rotaries
which by all account where some of the most beautify
highly mod 13B's and PSRU's. Van's aircraft had a fly
off between two Identical RV-8's with Power Sport
rotaries (no longer avaiable) and two factory RV-8's with
Lycs, 180HP & one 200 HP.
http://img325.imageshack.us/img325/3117/rotary22ms.jpg
http://img282.imageshack.us/img282/4323/rotary14wv.jpg
For some reason the 200hp RV-8 was slower than the
180HP RV-8? (May be tired from being a demo plane?)
Still the Power Sports DID VERY well. I want to point that
out. They had the same or few more mph or fpm more
speed & climb than the 180HP Lyc. The PS RV's did weigh
more than even the heavier 200HP lyc engine and
significantly more than the 180hp RV. They did burn
copious amounts of fuel above beyond the Lycs,
not trivial, like 4 gal/hr !
Also ground test showed the noise to be noticeably higher,
even bringing people out side to listen.
These are just facts Tracy not put downs. I am tired of
one thing. Alternative engines NEED to stand on their
own merits. I understand the Lyc being attack or used
as the gold standard. I know YOU don't do that. You
stand on your own feet and tell the truth good bad or
ugly. You don't sugar coat problems. However you are
the keeper of the flame and are a proponent and
enthusiast for the engine. Nothing wrong with that.
How many races have you or other Alt engines won?
Well you won the 160HP class sun and fun race one
year. I consider you to be a total straight shooter no BS,
but I'll point out, why did you run in the 160 HP class?
I mean really if you are getting 180HP performance
than you should have ran in that class. In the 180HP
class you would have been an also ran. Not a put down
just numbers and facts. Races can be a good benchmark
or not. The best test is by side by side flights as Van
did above, with unbiased observers. of course the test
needs to be repeatable.
I'll say, if I was going to do a non Lyc RV it wont be
a RWS, rotary with your PSRU and probably be
turbo (to keep noise down and get some more
efficiency).
Any one wanting to do a rotary, there is one place
you need to go, Tracy and RWS, the nicest people
and honest with smart designs. However be realistic,
you are not going to be BETTER than a Lycoming.
You just are not, it will be a tad heavier (I know I
track RV weights), it will not be as fast (unless it's
turbo and you fly high with O2) and it will always
burn more gas. It is true of the RX8 Mazda automobile
and it is true of a rotary in a plane.
Also if you DIY and roll your own Mazda with RWS
you can beat most Lycs in cost. However I have
$12,000 in an overhauled Lyc and $2,500 in an
OH Hartzell I bought for a prop shop. Not bad.
Granted a new fixed pitch prop Lyc (160 or 180hp)
is going to be about $25k. The numbers on most
Mazda conversions can be done in the $16k ball
park with fixed wood prop.
All the best to you Tracy, I am big fan, I just fly a Lycoming and GE and P&W.
>>From: "Tracy Crook" <tracy(at)rotaryaviation.com>
| Quote: | >Subject: Re: Re: Honda Piston Engine (never happen)
| Quote: | > based engines are at least several or all
> of the following:
> -heavier
> -More noise
> -low on power
| Quote: | I've already confessed that alternative engines are a mistake for most
gmcjetpilot
Posted: Mon Mar 10, 2008 5:15 pm Post subject: Honda Piston Engine (never happen) |
Right that is my point, car engines are not worked as hard or long as a plane engine so there is no comparison, at least millage or speed wise or even continuous higher power output for an aircraft engine. It is just a totally different mission and the engines reflect that. People are amazed at there Lexus. I get it, but its a car not a plane. You also have all this steel and insulation and long tail pipes.....big radiator...etc.....Can you imagine every time you drove your car, you had to start off climbing "Pikes Peak" at 100 mph, just to get going, than drive down the freeway at 120 mph, every trip.
erroneously
-Rob
n801bh(at)netzero.com Guest
Posted: Mon Mar 10, 2008 5:52 pm Post subject: Honda Piston Engine (never happen) |
A couple of tmes a year I have to chime in to straighten out the facts.
Alot of auto / truck engines are run hard... Take for example a Uhaul / Ryder rental truck. They are underpowered from the get go. People rent them and overload them till the tires blow out. They start them up, never let them warm up and hit the interstate, hold the throttle wide open till they get to the other side of the country, unload it, return it to the local dealer. A few days later the truck heads back across the country, doing it all over again. Week after week. month after month... ya think this isn't a torture test ?????????????
Take the marine applications. They use automotive blocks, heads cranks, yada, yada. Most boaters hit the boat ramp, dump it off the trailer, start it, don't let it warm up and spend the day on the lake running wide open. Sometimes running it through rough water making the boat jump out of the water, this causes the motor to overrev alot and then when it hits the water again it instantly loads the drivetrain. A plane cannot create that kind of abuse, but day after day, week after week boats do this to engines and ya know what... They live to run another summer, and summers after that... So your theory is suspect at best and BS at worst...
Ben Haas
A true auto engine conversion addict.
www.haaspowerair.com
Ben Haas
N801BH
erroneously
-Rob
_____________________________________________________________
Garage overflowing? Click for steel buildings that are durable and easy to install.
ronlee(at)pcisys.net Guest
Posted: Mon Mar 10, 2008 6:18 pm Post subject: Honda Piston Engine (never happen) |
"A true auto engine conversion addict."
Sometimes people ask if scuba diving is good in Cancun Mexico.
My response is that if it were, dive shops would make trips there
instead of (or in addition to) Cozumel Mexico. So I have to reach
the conclusion that scuba diving in Cancun does not compare to
Cozumel.
I see the auto conversion in aircraft the same way. If auto conversions
were so great then they would have become very prevalent. Since
they have not, I reach the conclusion that they are inferior.
Do as you wish but if you ever try to sell your airplane the reality
of your choice will become obvious.
Ron Lee
Posted: Mon Mar 10, 2008 8:26 pm Post subject: Honda Piston Engine (never happen) |
Absolutely, the Lycoming IS the Gold Standard. It is very hard to beat a purpose built engine with that many years of development.
I do think you over state the fuel economy issue when used in aircraft applications. The disadvantage of the rotary is much less when run at higher percentages of power. BTW, If anything, I think your estimate of power used in a car is high by a factor of 3 at 65 mph. This is the main reason the rotary makes such a lousy car engine and partly why I bought a Z3 instead of an RX-8 <g> At low power settings the quench areas are huge and unburned fuel is really bad. With higher loading, the flame front travels farther into that ill-shaped combustion chamber and the losses are not as bad. The lack of valve train losses help as well. As I said, it still has about a 5% BSFC disadvantage even when well tweaked.
The PowerSport comparison was flawed for two reasons. 1. The artificial fixing of prop rpm during the economy test. The Powersport should have been run at lower rpm and higher manifold pressure for best economy. 2. The ECU used by Powersport was tragically flawed in it's fuel mapping. To take best advantage of the rotary, it should have been run well below LOP in cruise (I cruise as much as 150 deg LOP). There are valid engineering reasons why the rotary can be run leaner than the piston engine but that's a long discussion. Short version: There is a stratification of mixture in the chamber of the rotary with richest mix out near the plugs, but only above 4500 rpm. That makes it of no advantage in a car where you don't cruise that high.
I could say that my engine does not use any oil between changes (75 hrs) but that would be a deception. For several reasons, I don't use the factory oil injection. Instead, I premix 2 stroke oil in the fuel (4 oz per 6 gal of fuel). The factory injection will make it past warranty period (usually) but engine life is at least tripled using premix. Yes, it's a hassle sometimes but no big disadvantage in the big picture. This eliminates the need for special oil in the crankcase. I use Mobile 1. I have yet to wear one out so I don't know what TBO is.
Ultimately you are right. The only reason to install an alternative is for the fun of it. There are NO other good reasons. But the fun of being your own aircraft propulsion engineer is not to be underestimated <G>
Always a pleasure to debate this stuff with knowledgeable guys like you.
All the best,
Tracy
On Mon, Mar 10, 2008 at 9:05 PM, <gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)> wrote:
[quote] Tracy I respect you and AGREE 100% with you. I never put
efficiency).
> of the following:
> -heavier
> -More noise
> -low on power
| Quote: | > -more cooling drag to day (except maybe P-51)
tedd(at)vansairforce.org Guest
Posted: Fri Mar 21, 2008 4:08 pm Post subject: Honda Piston Engine (never happen) |
A couple of misconceptions need to be addresses here.
First, it's ridiculous to compare lifespan of car engines and airplane engines
in miles, since they're installed in different vehicles. You might as well try
to compare miles in an airplane to kWh in an APU. The only reasonable basis of
comparison is hours, but to do that you need to match the duty cycles.
Fortunately, information exists that will help us do that. Auto manufacturer
accelerated-life tests typically involve cycling between peak torque and peak
power for a period of around a thousand hours (the specifics vary from company
to company and from intended-use to intended-use). It's done that way to save
development time and dyno-time cost, and over the years manufactureres have
learned to correlate these accelerated tests to real-world conditions very
accurately. People who say auto engines aren't designed for the kind of duty
cycle seen in airplanes simply don't know what they're talking about. The
tests they are designed to pass are very much like the duty cycle in an
airplane. We can be very confident that the engine will have a lifespan at
least equal to the duration of the test if operated similarly, whether in an
aiplane, a boat, or a stationary application. (And assuming the installation
is properly designed.)
Of course, once there is enough field experience (as there is getting to be
with rotaries and Eggenfellners) it will become possible to have a more
accurate prediction of life expectancy. The preliminary evidence seems to
suggest that the "TBO" will be much higher than 1,000 hours. I've been told by
boat builders running Mazda rotaries that they go well over 3,000 hours, and
the duty cycle is similar to an airplane's.
I'm not anti-Lycoming by any stretch of the imagination. I plan to put one in
my RV (and I've already bought it). And I agree with Ed, Tracy, and other
alternative-engine advocates that an auto conversion -- especially a "roll your
own" -- is not the right way to go for most building. But, in their zeal to
critique auto engines or defend Lycomings, some people have made statements
that are incorrect or misleading.
As for Reno: 3,347 CI verses 1,710 CI -- duh!
Tedd McHenry
Surrey, BC, Canada
Posted: Fri Mar 21, 2008 4:47 pm Post subject: Honda Piston Engine (never happen) |
Tedd McHenry
Surrey, BC, Canada
I was wonder'n if sombody was gonna say that! <G> |
Tracy Crook (RV-4 w/ 80 CI engine : )
OK, 160 CI for you SCCA rule guys out there.
