Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Mar 19, 2008 5:26 pm Post subject: Painting XL nose strut |
I'm going to want to hang my nose strut before too long and are looking for recommendations as to a paint / finish. I'll be painting the plane later with a catalyzed paint of some kind but I need to put something on the strut prior to installation.
From checking the archives I found:
Chrome - danger of embrittlement
Powder Coat - too thick, peels, doesn't wear as well a you might expect.
So what did the rest of you go with? I was considering rattle can enamel, perhaps baking it at low heat in an oven.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Wed Mar 19, 2008 5:42 pm Post subject: Painting XL nose strut |
I don't have a recommendation on a coating. But I do recommend that you mask
off the top and middle where the tube slides through the upper bearing and V
block. Anything else will scrape off and keeping it clean from the start
makes it slide better.
-- Craig
Jaybannist(at)cs.com Guest
Posted: Thu Mar 20, 2008 4:24 am Post subject: Painting XL nose strut |
Tim,
I primed my strut with SEM self-etching primer and topped it with Rust-oleum from a rattle can. I just didn't paint the part that will be swept by the bearings. I used a special grease on that. I think it was "Lubriplate", but I'm not sure about that.
Jay in Dallas
______________
CFII
Champ L16A flying
Working on fuselage
http://forums.matronics.com/viewtopic.php?p=171129#171129
cookwithgas
Posted: Thu Mar 20, 2008 6:44 am Post subject: Painting XL nose strut |
Tim,
You probably should use something out of a rattle can. I sprayed black
because zinc chromate primer was worn off at the bearing slides.
It's a least-effort for the occasional refurb and it seems to hold as
well as anything.
______________
CFII
Champ L16A flying
Working on fuselage
Gig Giacona
Posted: Thu Mar 20, 2008 6:51 am Post subject: Re: Painting XL nose strut |
I used Rust-oleum industrial primer and industrial paint both out of a rattle can on all the steel parts. Those things started getting surface rust on them before I took them out of the box.
601XL Under Construction
s.c.richards(at)homecall. Guest
Posted: Thu Mar 20, 2008 1:02 pm Post subject: Painting XL nose strut |
Scott
You possibly should be worried about chroming your nose strut
as I understand this causes hydrogen embrittlement and it could be prone to
cracking. Their should be some information in the archives.
I will ask Ray what he used.
Ray Lasniers CH601HD 190 hrs he has 701 kit on order Clive
swater6
Joined: 16 Dec 2006 Posts: 52 Location: Minnesota-KMIC/KANE
Posted: Thu Mar 20, 2008 1:34 pm Post subject: Re: Painting XL nose strut |
Hi gang,
I recently had all of my steel parts powdercoated at a local shop that specializes in small jobs. They do a lot of motorcycle, car and some aircraft parts.
I'm very pleased with the results as the coating is more durable and consistent than I could have achieved on my own. I did all internal parts in flat black and all external parts in metallic silver since I'm going to polish my plane. The finish isn't any thicker than spray paint, and possibly less think since it's more uniformly applied. Also, this company did the proper cleaning and pre-treating too. Cost was only $160 since I used two colors and would have only been $80 if one color. Seemed like a bargain to me.
I am interested in finding out how to best lubricate the gear and rudder pedal bearings. I'd rather not have something oily that will attract dirt. Perhaps some graphite or something.
Anyway, if any of you are near the Twin Cities, here is the shop I used. http://www.powdercoatingtech.com (The site is weak but has the address and phone number.)
PS. remember to mask the threaded areas!!
_________________ 601 XL kit N596SW reserved
Tail, control surfaces and both wings complete. Now working on fuselage
www.scottwaters.com |
Posted: Thu Mar 20, 2008 2:09 pm Post subject: Painting XL nose strut |
The top front gear tube bearing from the factory (6B8-6) is made of Nyloil
(the plans call it "Nyoil"). The bottom V block 6G2-1 is also called out as
"Nyoil" but all the ones I have ever seen look like plain gray Nylon
(although it could be the "Gray NYLOIL-MDX " mentioned in the link below).
Anyway Nyloil is impregnated with lubricant so it isn't clear that it needs
additional lubrication:
http://www.alro.com/DIVPlastics/plastic_product_nyloil.htm
-- Craig
av8or(at)cox.net Guest
Posted: Thu Mar 20, 2008 4:18 pm Post subject: Painting XL nose strut |
I'd recommend using a white or light gray for internal parts so you can easily see any cracks during an annual inspection.
JT
[quote] "I recently had all of my steel parts powdercoated....
I did all internal parts in flat black..."
swater6
Posted: Thu Mar 20, 2008 4:56 pm Post subject: Re: Painting XL nose strut |
Craig,
Thanks for the info on Nyloil. That's good to know.
And Av8or, you're right. I knew that's why the motor mounts should be white but didn't really consider that for the other parts for some reason. Good advice.
Scott
planecrazydld(at)yahoo.co Guest
Posted: Thu Mar 20, 2008 5:26 pm Post subject: Painting XL nose strut |
The hydrogen embrittlement resulting from chrome plating a 4130 structure can, I believe I remember, be removed by baking the chromed structure at something like 400 or 450F for 4 hours...
I am sure that someone on here can give you the exact recipe - if not maybe I can ask the metals guys at work.
LarryMcFarland <larry(at)macsmachine.com> wrote:[quote] --> Zenith-List message posted by: LarryMcFarland
Tim,
well as anything.
Tim Juhl wrote:
[quote] --> Zenith-List message posted by: "Tim Juhl"
______________
CFII
Champ L16A flying
Working on fuselage
Jon(at)joncroke.com Guest
Posted: Thu Mar 20, 2008 6:01 pm Post subject: Painting XL nose strut |
Take this for what it is worth, as I am no expert in this field...
but - a friend of mine that has designed and repaired lots of industrial equipment over the years told me that chroming for purposes of decoration has NO danger of hyd embrittlement as we are talking only a few thou of chrome penetration. Completely different: Chroming is apparently a common procedure for the purpose of hardening metals (shafts, bearings, etc) (which has no goal to enhance appearance!) and when done for this reason -- this goes much, much deeper into the material... and then hyd embrittlement can become an issue... and yes - a visit to an oven is an easy cure for this problem.
He sounded pretty convincing to me.. so Im just passing it along... FWIW. I got an interesting explanation of the chroming process... which is not as simple as plating using other familiar metals....
Jon
Posted: Fri Mar 21, 2008 3:36 am Post subject: Painting XL nose strut |
I am not a metals expert either - my area is advanced composites, but... I spoke with the manager of the metals lab this AM and he clarified the details somewhat.
Hydrogen embrittlement is a concern regardless if the plating is decorative or thin dense chrome.
The primary driver for hydrogen embrittlement is the strength/temper/heat treat of the steel, and to a lessor degree, the alloy. In cases above 180KSI, the application almost always requires a bake; in many cases below 180KSI many of our suppliers do the bake for comfort. A typical bake here is 23 hours at 375±25°F - and the time between the plate and start of the bake is critical - not more than 4 hours and preferably within 1 hour. The bake soak temperature can not be above the tempering temperature for the part.
As always, the devil is in the details and this information is generic to a fault.
Jon Croke <Jon(at)joncroke.com> wrote:[quote] Take this for what it is worth, as I am no expert in this field...
Jon
backstagelive(at)gmail.co Guest
Posted: Fri Mar 21, 2008 7:27 am Post subject: Painting XL nose strut |
Tim,
The chroming looks great!What did it cost?
Joe in Oshkosh
Posted: Fri Mar 21, 2008 8:36 am Post subject: Painting XL nose strut |
i would recommend powder coating it. the major landing gear guys PC their struts. it is tough against chipping.
psm(at)ATT.NET Guest
Posted: Sat Mar 22, 2008 2:52 am Post subject: Painting XL nose strut |
Hi Tim,
I went to my local "Professional" auto paint store and selected an
acrylic enamel top coat and compatible epoxy primer for my
plane. This is the same stuff the commercial airplane and auto paint
shops use for lower end paint jobs. I have been painting some of my
fuselage parts as I assemble them. Paint cost is around $100 per
gallon including catalysts.
The epoxy primer is a really wonderful material that can be used
without a top coat for parts that will not be readily visible like
the nose gear strut. It forms a very smooth and hard surface. I
have been using it on all the steel parts.
In the nose strut case, I adjusted the bearing inside diameter with a
Dremel tool and sanding drum after painting the strut. Without such
adjustment, the strut would not move through the lower bearing.
Good luck,
Paul
XL fuselage
ashontz
Posted: Sat Mar 22, 2008 4:31 am Post subject: Re: Painting XL nose strut |
Looks good Scott. I was going to recommend stainless steel. Not sure how much more that would weigh, if any. Just thinking of Cessnas, they're either chromed or stainless.
