tdawson-townsend(at)auror Guest
Posted: Fri Mar 21, 2008 5:06 am Post subject: Batteries |
Tim wrote: “Most EFIS systems won't stay running while you crank an engine”
I say, any EFIS that’s worth its salt will!
TDT
Tim Dawson-Townsend
40025 Firewall Forward
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
jim(at)CombsFive.Com Guest
Posted: Fri Mar 21, 2008 6:01 am Post subject: Batteries |
I agree!
I have the Advanced Flight Systems 3500EE and it works great during cranking.
Any EFIS that will not function during cranking is not worth having. Thats a required feature in my opinion.
Jim Combs
40192
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Date: 2008/03/21 Fri AM 08:03:37 EST
Subject: Batteries
Tim wrote: "Most EFIS systems won't stay running while you crank an
engine"
I say, any EFIS that's worth its salt will!
TDT
Tim Dawson-Townsend
tdt(at)aurora.aero
rene(at)felker.com Guest
Posted: Fri Mar 21, 2008 6:37 am Post subject: Batteries |
Jim are you just trying to start an EFIS war?
I made no provision for keeping my GRT Horizon 1 on line during cranking. I
knew it would not stay on line, and with other electronics I have on board,
I don't want it on line during cranking. I use the EIS for engine start,
and it works great. Here is my startup procedure.
Battery on line
Check EIS for warnings, make sure nothing unexpected is showing
Crank engine, monitoring EIS
With engine start, wait for oil pressure, check for alarms
Bring alternator on line
Start up GRT EFIS, A/P and other avionics
Wait a minute or so for EFIS and 430 to settle down, taxi and go.
Use paper checklist unit EFIS is on line. It was just yesterday that I got
the checklist loaded in the GRT, was using the BM lite. It was real nice to
have the parameters and data available in the check list.
I have been thinking about a second battery, but based on my mission
requirements just don't see a need.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
speckter(at)comcast.net Guest
Posted: Fri Mar 21, 2008 12:36 pm Post subject: Batteries |
It's the engine monitor that reboots for me when I crank. So I needed to
add a second battery even though I have 2 alternators.
Gary
40274
DAR inspection scheduled
coop85(at)cableone.net Guest
Posted: Fri Mar 21, 2008 2:15 pm Post subject: Batteries |
FWIW, I have the same basic setup and do the same procedures (GRT EIS only
during start, then power everything else up). Works great and I have all
the info I need on the engine during and post start.
Marcus
jump2(at)sbcglobal.net Guest
Posted: Fri Mar 21, 2008 5:49 pm Post subject: Batteries |
Did you go with the rg25 battery?
Pat Thyssen
gary <speckter(at)comcast.net> wrote:
[quote]--> RV10-List message posted by: "gary"
Gary
40274
Posted: Fri Mar 21, 2008 5:52 pm Post subject: Batteries |
Not! No EFIS wars please.
I believe that most if not all of the EFIS technology available to us as experimental aircraft manufacturers is without a doubt the single best thing from a safety standpoint. We have systems that rival or surpass the best systems flying commercially. With the availability of on screen weather, synthetic terrain, moving map technology, audible alerts, highway in the sky to name just a few. All of these contribute to safer flying. I don't think anyone should be building in todays world without glass of some sort in the panel. Cost is not an issue.
It's all very good!
Still working on getting my first flight in a RV. (Hopefully mid April with Alex in Texas!) Wonder how that compares with a C-182? That has to got to be an apples to oranges comparison.
Jim C
40192
Posted: Sat Mar 22, 2008 11:45 am Post subject: Batteries |
No I went with two small ones like Tim Olson did.
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen
Sent: Friday, March 21, 2008 9:46 PM
Subject: RE: Batteries
Pat Thyssen
Gary
40274
