a.s.elliott(at)cox.net Guest
Posted: Sun Mar 23, 2008 12:27 am Post subject: XL forward fuselage top thickness |
Looking for experience & opinions - I have made a pattern and am ready to cut the forward fuselage top skin (6C1-4). I find that the while the plans show it to be .020, some of the kits and factory built aircraft have it as .025.
I do plan to modify the sheet as many have, so that the section between the panel side angles, firewall and instrument panel is removable via lots of #8 screws, and the section where the canopy rail goes is riveted in place.
Estimating the area as 4 sq.ft., the weight difference between the .020 skin and the .025 skin would be ~103.5 gms, which is less than 4 ounces.
SO... Anyone have any comments about whether to use the .020 or the .025 material, especially in terms of holding up in use and maintenance?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD, Corvair, building...
Jaybannist(at)cs.com Guest
Posted: Sun Mar 23, 2008 5:49 am Post subject: XL forward fuselage top thickness |
Andy,
My kit came with .025 top forward skin. When I cut a great bid access hole, I surrounded the hole with .032 angles and added a brace at the top. See my drawing on www.ch601.org. One change I made from that drawing is the sealing material. I actually used a rubber electrical joint tape on the inside edges of the reinforcing angles.
Jay in Dallas
"Dr. Andrew Elliott" <a.s.elliott(at)cox.net> wrote:
Quote: | Looking for experience & opinions - I have made a pattern and am ready to cut the forward fuselage top skin (6C1-4). I find that the while the plans show it to be .020, some of the kits and factory built aircraft have it as .025.
N601GE (reserved)
Posted: Sun Mar 23, 2008 6:43 am Post subject: XL forward fuselage top thickness |
Hi Andy,
I'd recommend you go with .025 and use 6-32 screws in U-clips that fit
.025 to .040.
See McMaster Carr 94809A102
Part Number: 94809A102
<http://www.mcmaster.com/itm/find.ASP?tab=find&context=psrchDtlLink&fasttrack=False&searchstring=94809A102>
$13.53 per Pack of 50
Nut Type
Speed Nuts
Applications
For Machine Screws
Speed Nut Type
J-Style Clip-On Nuts
J-Style Clip-On Nuts Style
Shape 2
Material Type
Steel
Finish
Black
Grade/Class
Not Rated
Steel Type
Plain Steel
System of Measurement
Inch
Inch Thread Size
6-32
For Panel Thickness
.025"-.04"
Center of Hole to Panel Edge
.468"
Thread Direction
Right-Hand Thread
Thread Type
Standard Threads
Specifications Met
Not Rated
These are a great fastener, they're easily replaced and make the removal
and install painless.
I have about 80 of these holding the forward top skin on my 601HDS.
http://www.macsmachine.com/images/canopy/full/uclips.gif
http://www.macsmachine.com/images/canopy/full/cnpyrailcover.gif
ounces.
N601GE (reserved)
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Aerolitellc(at)aol.com Guest
Posted: Sun Mar 23, 2008 11:57 am Post subject: XL forward fuselage top thickness |
Use .025 I have zenith make every skin on my kits .025 and all control surfaces .020. It gives you a much better airframe.
Jeff
Create a Home Theater Like the Pros. Watch the video on AOL Home.
