Trimming cowl inlets
ricksked(at)embarqmail.co
PostPosted: Tue Mar 25, 2008 3:59 pm    Post subject: Trimming cowl inlets Reply with quote
[quote]Since the cowl is all fitted, the only thing left to do is trim the cowl inlets to the 2" depth Vans specifies in the plans...now for the question. Does the entire inlet get trimmed two inches from the front edge? The plans seem vague and lean towards only the outer edge...which doesn't make sense.And while I have everyone's undivided attention...I assume it is from the face of the inlet they are telling us to measure back two inches? Rick Sked40185[b]
speckter(at)comcast.net
PostPosted: Wed Mar 26, 2008 4:47 am    Post subject: Trimming cowl inlets Reply with quote
I would wait with the trimming until you have your baffling in place. Then trim to 2” or even less to make for a smooth transition with your baffle ramp. It is not a hard dimension so keep trimming until you like the result and can get your baffle material to lay flat.
Gary
40274
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
Sent: Tuesday, March 25, 2008 7:55 PM
Subject: Trimming cowl inlets
Since the cowl is all fitted, the only thing left to do is trim the cowl inlets to the 2" depth Vans specifies in the plans...now for the question. Does the entire inlet get trimmed two inches from the front edge? The plans seem vague and lean towards only the outer edge...which doesn't make sense.And while I have everyone's undivided attention...I assume it is from the face of the inlet they are telling us to measure back two inches? Rick Sked40185 Does the entire inlet get trimmed two inches from the front edge? The plans seem vague and lean towards only the outer edge...which doesn't make sense.
5
6
7
8
9
5
PostPosted: Wed Mar 26, 2008 5:32 am    Post subject: Trimming cowl inlets Reply with quote
Thamks Gary,
Does that 2" remain pretty constant all the way arounfd the inside. It looks like the area by the spinner needs to be deeper than 2".
Rick Sked
40185
Tim Olson
PostPosted: Wed Mar 26, 2008 6:05 am    Post subject: Trimming cowl inlets Reply with quote
It's definitely not consistent. I don't remember exactly how I
started, but Gary's right...you want to get the baffling where you
think it should be and then basically do the cutout to blend
with the baffling and provide good laydown for the rubber seals.
It really isn't too bad of a project once you get going.
Rick Sked wrote:
[quote] Thamks Gary,
Rick Sked
40185
PostPosted: Wed Mar 26, 2008 6:20 am    Post subject: Trimming cowl inlets Reply with quote
Just make it look pretty. Mine varies all the way around.
Gary
40274
Sent: Wednesday, March 26, 2008 9:30 AM
Subject: Re: Trimming cowl inlets
Thamks Gary,
Rick Sked
40185
