davedawe(at)msn.com Guest
Posted: Thu Mar 27, 2008 3:20 am Post subject: Wanted Starting motor |
for rotax 532
I understand some sea doos have same rotax starter???
appreciate your help
> From: noelloveys(at)yahoo.ca
[quote] To: kitfox-list(at)matronics.com
Subject: RE: Re: Tricycle Kitfox II
Date: Thu, 27 Mar 2008 00:31:00 -0230
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
How did you contact Dan Denney? I have a model II that was supposed to be
upgraded to model III and would like his views on upgrading the gross weight
to 1050 on floats when registration is amended this spring.
Noel
john beirne
patreilly43(at)hotmail.co Guest
Posted: Fri Mar 28, 2008 1:34 pm Post subject: Wanted Starting motor |
John, What engine did you replace the starter on?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
john beirne
Posted: Sat Mar 29, 2008 12:28 pm Post subject: Re: Wanted Starting motor |
Rotax 582.
dave
Posted: Mon Mar 31, 2008 1:12 pm Post subject: Re: Wanted Starting motor |
John, Have you tried this starter yet ? looks like it rotates CCW , Rotax requires Clockwise. Good price if it works.
What is wrong with starter ? parts are usually available
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
akflyerbob
Joined: 06 Jan 2008 Posts: 30 Location: Soldotna, Alaska
Posted: Sun Apr 06, 2008 7:58 pm Post subject: Re: Wanted Starting motor |
I purchased on of these starters to check it out
and Dave is correct, the rotation is opposite.
The bendix is also different.
dave
Posted: Mon Apr 07, 2008 12:32 am Post subject: Re: Wanted Starting motor |
| Quote: | I purchased on of these starters to check it out
Hope you can get a refund.
Unless your starter has broken parts it is likely you can repair or take to a local electric shop for a cheap over haul. Brushes and a turning of the armature it not very labour intensive.
Dave
