wrice(at)omnicityusa.com Guest
Posted: Sun Apr 06, 2008 8:20 am Post subject: EAB to ELSA |
Bob: Is there any process to convert a EAB to the ELSA in order for the owner/pilot can take the 16 hour course and be able to inspect is own plane?? Thanks fpr your input. Bill Rice
[quote] To: Kolb-list(at)matronics.com (Kolb-list(at)matronics.com)
Sent: Saturday, April 05, 2008 3:59 PM
Subject: FAA advice
I cobbed this off FLY-UL :
This message was posted to another group (Sport_aircraft)
Re: ex-planes?
OK, folks, I'm new to the group and have been "lurking" in the
background reading this (sometimes painful) thread on certificating
existing or new light-sport aircraft. Now I think it's time to jump in
and clarify some of the confusion.
I am an FAA DAR who certificates light-sport and amateur-built
aircraft. I also provide FAA-accepted 16-hour ELSA repairman courses--
more that 40 courses all over the eastern half of the U.S. I've also
been building experimental airplanes for 40 years.
So, I deal with these questions every day. Here are the facts.
There are only five conceivable ways to certificate a light-sport
aircraft: 1) standard category, 2) special light-sport aircraft
(SLSA), 3) experimental light-sport aircraft (ELSA), 4) experimental
amateur-built (EAB) aircraft, and 5) experimental exhibition aircraft.
Although these are all conceivable ways, some of them are not
practical. Let's talk about each one.
STANDARD CATEGORY
These are the type certificated Cessnas, Pipers, Beech's, etc. Nobody
is going to certify a light-sport aircraft in standard category because
it is a multi-million-dollar process to do so and would result in an
aircraft that nobody could afford. 'Nuff said.
SPECIAL LIGHT SPORT AIRCRAFT (SLSA)
These are the 70-odd ready-to-fly new aircraft designs that have come
on the scene in the last 3 years. Although not the multi-million-
dollar process that would be required for type certification, SLSA
manufacturers must create aircraft designs and implement inhouse
procedures to meet ASTM light-sport aircraft standards. With each such
aircraft manufactured, they must certify that they have met all
applicable standards.
EXPERIMENTAL LIGHT SPORT (ELSA)
In the words of FAR 21.191(i), there are three kinds of ELSAs:
1. Existing "ultralight-like vehicles" certificated prior to January
31, 2008 per 21.191(i)(1). Note that the EAA and ASC have gotten
exemptions to allow the certification deadline to be extended for
aircraft that were REGISTERED before the deadline. That means that if
your existing ultralight was not FAA-registered before the deadline, it
can NEVER be certificated according to this paragraph. It also means
that manufacturers of ultralights are essentially out of business
unless they want to get their design certificated as SLSA.
2. ELSAs built from a SLSA kit per 21.191(i)(2). The manufacturer
must have gotten SLSA certification on the aircraft prior to offering
it in kit form. The kit does not have to meet the 51% rule, but the
manufacturer must certify that the kit meets the ASTM standards and the
builder must certify that he has completed the kit EXACTLY as the
manufacturer specifies. There is no registration or certification
deadline on this type of ELSA.
3. ELSAs that were converted from SLSA per 21.191(i)(3). Let's say
a guy buys an SLSA, but wants to do his own annual condition inspection
after attending a 16-hour ELSA repairman course (such as the ones I
offer). He can ask the FAA to change his certification from SLSA to
ELSA. There is no deadline on making such a conversion.
EXPERIMENTAL AMATEUR-BUILT (EAB)
In the words of FAR 21.191(g), to qualify for certification as an EAB,
the major portion must have been "fabricated and assembled by persons
who undertook the construction project solely for their own education
or recreation" (note the word "fabricated" in addition to the
word "assembled).
In the olden days when I was a pup, before there were EAB kits, we
simply bought plans and materials, built the entire aircraft, and
documented the construction process in a builder's log. Also, in those
days, an FAA inspector (there were no DARs) had to perform an interim
inspection of any portion of the aircraft that would be "closed out"
and would not be visible at the final inspection. Because of that,
there was generally no question that the "major portion" requirement
was met, even in the case where one individual began the construction
and then sold the project to another individual.
However, over the ensuing 20-30 years, kits began to be available.
First, they were simply raw material kits, but they gradually advanced
into having more and more of the aircraft fabrication completed by the
kit manufacturer. So, to assure that the "major portion" requirement
was being met, the FAA began evaluating kits and approving them as
meeting the so-called "51% rule." Therefore, if I bought an approved
51% kit, finished it myself and maintained a construction log, FAA
inspectors (and DARs, which had come on the scene by then) would accept
it as meeting the "major portion" requirement. This held true even if
I bought such a kit from someone else who had done some of the
fabrication and assembly work, as long as that person was able to
provide me with the original bill of sale for the kit and a
construction log for his efforts.
Of course, then people started abusing the system, by getting other
people to finish the kits for them. That situation has gotten so bad
that the FAA is now revamping their entire system for evaluating kits
and evaluating EABs submitted for certification. Some of the current
quick-build kits may be disqualified.
So, how does that affect the ability to certificate an existing
ultralight as an EAB? I hear guys who have missed the ELSA
registration deadline say, "I'll just take my ultralight apart and
reassemble it, take a few pictures, create a construction log, and get
it certificated as EAB." Unfortunately, that is not legal. First,
most ultralights do not meet the "major portion" requirement--either
they were purchased ready to fly or as a kit that was not evaluated by
the FAA. Second, FAR 191(g) requires that the major portion be
FABRICATED and assembled by the applicant-- just reassembling it would
not qualify.
I'm not saying that no ultralight is ever going to be certificated as
an EAB, because DARs and FAA inspectors vary in strictness by which
they interpret the requirements. I know if I tried to vary from the
requirements, I would be in trouble with my FAA supervisor!
EXPERIMENTAL EXHIBITION AIRCRAFT
This certification category is for aircraft that are intended to be
used only for "exhibition" purposes, such as performing in air shows,
performing in aerobatic competitions, competing in air races, display a
certain kinds of aviation events, etc.
When certificating an aircraft as experimental exhibition, the FAA
issues "operating limitations" that severely limit where and when the
aircraft can be flown. Generally that means the aircraft may be flown
only 1) while performing or competing at an aviation event, 2) to
travel to and from such an event, and 3) to practice for such an event.
Experimental exhibition is "the bottom of the barrel"--the least
desirable way to certificate an aircraft because of the restrictions it
imposes. Do people sometimes ignore those restrictions?--sure, but if
they are caught, they are in trouble.
CONCLUSIONS
1. If you have missed the January 31, 2008 ELSA registration deadline,
a. You MIGHT be able to get it certificated as an EAB, but it is
not likely.
b. You can probably get it certificated as experimental exhibition,
but that would be very restrictive as to where and when you could fly.
c. Otherwise, you have an expensive lawn ornament on your hands.
Thus, if you are tempted to buy an existing ultralight off eBay or
somewhere else, it is critical to determine that it has already been
certificated as an ELSA (unless of course it meets FAA 103, which very
few ultralights do).
2. Any ELSA manufactured, registered, and certificated after January
31, 2008 must be based on an SLSA kit, as explained above.
If you have other questions about this, feel free to post them and I'll
do my best to answer them. Also, I invite you to visit my website
listed below--it has lots of good information on this topic and much
more.
Hope this clarifies some of the confusion!
Mike
regards,
Bob N. FireFly 070 Old Kolb
| [b]
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Sun Apr 06, 2008 7:13 pm Post subject: Re: EAB to ELSA |
Bill,
I'm not Bob, but I took Mike Huffman's LS-I repairman course last week. It's a great course and he's a great teacher. He talked about this (what you asked) in his class. Probably NOT what you want to hear, but there is no way to certificate a plane as E-LSA when it has already been certificated as E-AB.
Mike's web site - http://www.sportaviationspecialties.com/Articles.htm
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
