travis(at)tnkolbaircraft. Guest
Posted: Wed Mar 26, 2008 6:43 am Post subject: MKIIIx |
Morning Gang:
Got an early start flying this morning.
Made my first full flap landing and a dozen more. The X is a floater and nice soft gentle landings. Of course, I didn't stall it until it was almost on the turf.
It flies well with full flaps which are 45 deg. Half flaps is 20 deg. Still stalling at 30 mph IAS at 3,000 feet ASL.
Still waiting for the droop tips. Supposed to be here tomorrow.
Beautiful day in sunny, cool Kentucky.
Labhart Field, KY
Posted: Fri Mar 28, 2008 11:57 am Post subject: MKIIIx |
Hi Gang:
Weather continues to be a bit cruddy. However, was able to get a short test flight in this afternoon with the new droop tips.
Initial results are:
Stall:
Clean - 36 mph
20 deg - 30 mph
45 - 26 mph (that is not a typo)
All speeds are IAS. It was a short flight because it was flown in the rain. A problem with the long, flat, low angle X windshield is visibility in precipitation. Tomorrow morning the weather is supposed to be partly cloudy, wind 5-10 mph. I should be able to get better numbers in the morning.
Ailerons feel good. I am going to test it with the cables moved in another half inch. Maybe with the droop tips the ailerons will have increased authority. Without them, I did not feel I had enough slow speed authority. This airplane will fly slow.
Take care,
Labhart Field, KY
Posted: Fri Mar 28, 2008 12:32 pm Post subject: MKIIIx |
as Sgt Shultz said, "verrry interesting"
-now for the VGs. heh heh
BB
On 28, Mar 2008, at 4:10 PM, Travis Brown (Kolb Aircraft) wrote:
| Quote: | Hi Gang:
Stall:
Clean - 36 mph
20 deg - 30 mph
Take care,
Labhart Field, KY
Posted: Fri Mar 28, 2008 1:05 pm Post subject: MKIIIx |
Bob B:
I knew that was coming!
You know what my standard answer is for my mkIII. Well........going to be about the same for the new MKIIIx, "I really do not have a requirement for VGs."
Again, this was a very short flight. I was restricted with ceiling and visibility. Hopefully, in the morning we can get some good test weather to get a better feel for the new airplane. I am glad I got to get as much time on it as I did without the droop tips. Gives me a better feel for what the droop tips are doing. Don't forget though, this airplane has 13 feet of straight wing plus the tips. It was a slow flying airplane before addition of the tips.
Labhart Field, KY
[quote] Sgt Shultz said, "verrry interesting"
BB
russ(at)rkiphoto.com Guest
Posted: Fri Mar 28, 2008 2:37 pm Post subject: MKIIIx |
John Than x update. Just curious -- u using Rain-X?
On Mar 28, 2008, at 4:10 PM, Travis Brown (Kolb Aircraft) wrote: | Quote: | Hi Gang:
Stall:
Clean - 36 mph
20 deg - 30 mph
Take care,
Labhart Field, KY
| Quote: | http://www.matronics.com/Navigator?Kolb-List
herbgh(at)nctc.com Guest
Posted: Fri Mar 28, 2008 3:07 pm Post subject: MKIIIx |
I keep my lexan cleaned with pledge furniture polish... Wax... Takes the bugs off too.. Herb
At 05:33 PM 3/28/2008, you wrote:
[quote]John
| Quote: | Hi Gang:
Stall:
Clean - 36 mph
20 deg - 30 mph
Take care,
Labhart Field, KY
| [b]
Posted: Fri Mar 28, 2008 4:02 pm Post subject: MKIIIx |
Nope.
Rain X and Lexan are not compatible, as I under it. I have not tried it, but others have with poor success.
I use plexus on my aircraft.
This X has plexus on it.
Labhart Field, KY
[quote] From: Russ Kinne (russ(at)rkiphoto.com)
Posted: Fri Mar 28, 2008 4:18 pm Post subject: MKIIIx |
Thanx for the info! Does Plexus keep the rain drops running like RainX does?
On Mar 28, 2008, at 8:14 PM, Travis Brown (Kolb Aircraft) wrote: | Quote: | Nope.
Labhart Field, KY
| Quote: | From: Russ Kinne (russ(at)rkiphoto.com)
Posted: Fri Mar 28, 2008 5:01 pm Post subject: MKIIIx |
I don't know. Never used RainX.
jhauck
JetPilot
Posted: Fri Mar 28, 2008 6:58 pm Post subject: Re: MKIIIx |
Those are AMAZING number John, I sure wish I had that wing on my plane ! Kolb has made a good airplane quite a bit better, good for them on improving the design. There is not much else out there with anywhere near that kind of slow flight performance, that will also go fast. I'm sure that plane will impress a lot of people and generate sales for Kolb.
RainX is an incredible product for you car window... Even in the heaviest thunderstorms I dont need wipers, and in a cold climate, I wipe frost off the window with a rag, no need for a scraper. The secret is to put RainX on like Wax, rub it in real good on a dry cool window. If you just smear it on, you will get poor results.
I would not try RainX on Lexan, there is alcohol in it that could attack the Lexan. It is not for plastics. I use car wax on my Kolb Lexan, I first polish it with a plastic polisher, then put wax on it. The wax makes quite a bit of difference in its optical quality.
Mike
Kolb MK-III Xtra, 912-S |
captainron1(at)cox.net Guest
Posted: Tue Apr 08, 2008 6:14 pm Post subject: MKIIIx |
Strongly recommend against using any furniture wax (Pledge and the rest) in flight, if rain is possible. Found out about it the hard way up in Alaska (back in 1988 first time up there), it will mix with the water and make the windshield fairly opaque. Rain-X works good for flight in rain, highly recommended.
Ron Txaz
| Quote: | John
>Hi Gang:
>Stall:
>Clean - 36 mph
>20 deg - 30 mph
>Take care,
>john h
>mkIII
>Labhart Field, KY
><http://www.matronics.com/Navigator?Kolb-List>http://www.matronics.com/Navigator?Kolb-List
><http://www.matronics.com/contribution>http://www.matronics.com/contribution
kugelair.com
