		wb2ssj(at)earthlink.net Guest
				 Posted: Sat Apr 19, 2008 2:23 am    Post subject: Gear legs |
				I have had my gear legs on and off and have a very  nice fit. I was wondering at final assembly if some type of lube should be used?  The different type of metals between the leg and the mounting hole in the spar  box could create  some corrosion. Any comments?
    TEX
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		Colin K.
				 Posted: Sun Apr 20, 2008 6:36 am    Post subject: Gear legs |
				I  agree with your thinking Tex, although I also think the dissimilar metal  corrosion would not be very active provided the area was kept  dry.
  Due to  the close fit, anything as thick as paint would not work. I am sure that WD40 or  oil would help, but I wonder for how long?
  I  might try a product called Waxoyl I used to use to prevent rust on classic  cars. Just because I have a tin left over from years ago! When warm/hot, it  is fluid, but it cools to a waxy substance.
  Colin K.
 OK
 Lightning #  52 under construction.
 http://www.mykitlog.com/cojaken
  _________________ Colin K.
OK |
		Clive J
				 Posted: Mon Apr 21, 2008 12:57 am    Post subject: Gear legs |
				I use some stuff called PBC, PolyButylCuprosil, or commonly known as
 Coppergrease, great for stemming corrosion and to aid stripping down
 anything after a period of time. PBC, if you can get it, is entirely
 synthetic so it doesn't dry out like Coppergrease does.
 CJ
		allanmaxe(at)yahoo.com Guest
				 Posted: Mon Apr 21, 2008 5:03 pm    Post subject: Gear legs |
				Hi Clive wanted to know if you started to fly the esqual yet let me know how its going. I have 175hrs now. Allan
 "James, Clive R" <clive.james(at)uk.bp.com> wrote:  [quote]--> Lightning-List message posted by: "James, Clive R"
 CJ
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
