jbowerman(at)fastspot.net Guest
Posted: Tue May 13, 2008 11:23 am Post subject: Avionics |
I have been told by the local avionics guru that my Russian comm radio is
not repairable (more than likely he doesn't know how). What types of
radios can successfully be placed into the Yak52 instrument panel in place
of the Russian one?
Jim
dsavarese(at)elmore.rr.co Guest
Posted: Tue May 13, 2008 12:04 pm Post subject: Avionics |
A very functional radio that will fit well in the original VHF radio control
panel slot (with an adapter plate of course) is the XCom round VHF radio.
It is a 2 1/4" round (57mm) digital flip-flop radio with the capability to
monitor the standby frequency and with a built in VOX key intercom should
you wish to use the capability. Very cost effective.
http://www.xcom760.com/ You will need a voltage converter (28V to 14V) for
this and most other small, compact VHF radios.
Dennis
Posted: Tue May 13, 2008 1:04 pm Post subject: Avionics |
The Becker radio also works. Has a flip flop function with an internal
intercom. Also needs a 24 to 12 V converter.
Doc
jan.mevis(at)informavia.b Guest
Posted: Tue May 13, 2008 11:05 pm Post subject: Avionics |
Indeed, we have an XCOM too in a Yak 52, but it's our second one. Our first
XCOM, brandnew, did not work properly. It took months before it came back
from the factory (probably a firmware problem, not electronics).
Meanwhile we ordered another one that worked perfectly. So we have a spare
now. The reason why we bought it in the first place, is for the built-in
intercom possibility. It is definitely a good choice.
Jan
scott.glaser(at)thedefian Guest
Posted: Fri May 16, 2008 6:35 am Post subject: Avionics |
I put a garmin SL-30 on a subpanel. Works outstanding. I actually still
have the Russian Com as well as a back-up. No audio panel just a simple
switch in each cockpit. Both switch's have to be on the same side for the
respective intercom to work (obviously).
S
Best Regards,
Scott T. Glaser
Proprietor
The Defiant Company
661-816-9041
1045 Drexel Avenue
Drexel Hill, PA 19026
www.thedefiantcompany.com
