bj.hussey(at)ns.sympatico Guest
Posted: Thu Jun 05, 2008 5:25 pm Post subject: Kitfox Suber EA81 (2nd message) |
Plane had TT 329hr. A friend coached me on the tailwheel and other traits of the Kitfox and I finished the year with 20 hours total. The previous owner stated he checked the compression in Jan 07 cold at 142,151,140 and 132. There was no work done on the plane from time of purchase until I drained the oil Tuesday past. I removed the filter today and when checking it the oil seemed to have a different smell and was very thin. Seems like gas may have got into it. I was not told to shut the fuel supply off and it was on until it was noted when going through the manual during the winter. Did anyone ever hear of the Ellison
Fox5flyer Guest
Posted: Thu Jun 05, 2008 5:43 pm Post subject: Kitfox Suber EA81 (2nd message) |
Barrie, yes the Ellison having a very small needle and seat can sometimes leak gas into the intake manifold that can migrate down into the engine oil pan. The manual specifically states to use the fuel shut off valve to kill the engine and leave it off until next engine start.
It's possible that's what happened in your case.
If you have the normally aspirated EA81, those compression numbers seem a bit low. Try a complete oil change, warm the engine up to at least 150 degrees, shut it down, then do another compression check using a good quality tester. Ensure that ignitions are off, all plugs removed, and use wide open throttle with at least ten prop blades per cylinder. Let us know what numbers you get.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 375+ TT
- Joseph Joubert
Lynn Matteson
Posted: Fri Jun 06, 2008 6:56 am Post subject: Kitfox Suber EA81 (2nd message) |
Just for my curiosity, Deke, is there only one plug per cylinder on
the EA81?
Lynn
On Jun 5, 2008, at 9:38 PM, fox5flyer wrote:
[quote] Barrie, yes the Ellison having a very small needle and seat can
engine start.
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Fri Jun 06, 2008 7:15 am Post subject: Kitfox Suber EA81 (2nd message) |
Yes. Dual ignition, single plug.
Deke
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Wed Jun 11, 2008 4:14 pm Post subject: Re: Kitfox Suber EA81 (2nd message) |
To the two of you who are flying EA81s, how do you like them? I am considering one as an option for my plane and it is hard to find testimonials for some reason. Thanks for the help.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
avtar412
Posted: Thu Jun 26, 2008 12:28 am Post subject: Re: Kitfox Suber EA81 (2nd message) |
I'm running an EA 81 T in my Series 5 and very pleased with it. 2.2:1 PSRU and performs very well. 72" WD prop and intercooler.
