Guy Buchanan
Posted: Tue Jul 08, 2008 9:18 am Post subject: Carb vent line install - Rotax 2 cycleCarb vent line insta |
At 04:42 AM 7/8/2008, you wrote:
| Quote: | If this was originally for a HACman system, would it be wise to look
into getting one of those systems? The regular vent lines seem
pretty basic, are they just something that you field fabricate? If
so, does anybody know the dimensions; length, hole pattern/diameters, etc?
Ryan,
I would look into the HACman
system.(http://www.greenskyadventures.com/bing/HACmandetails.htm) I
use it and love it. You could easily fabricate your own Rotax vent
lines. Just size a line that goes comfortably around the bottom of
the carb, from one side vent to the other, and melt/drill a 3/32"
hole in the bottom situated so any fluid in the line will drain out.
I'm quite sure the exact length is irrelevant, just that the vent is
near the carb.
Guy Buchanan
San Diego, CA
K-IV/1200 w/ 582 C-box & Warp 3 blade
100% and flying thanks mostly to Bob Ducar
Deceased K-IV 1200
A glider pilot too. |
