XL canopy open
Goto page 1, 2  Next
chris Sinfield
PostPosted: Wed Jul 16, 2008 5:44 am    Post subject: XL canopy open Reply with quote
Guys and Girls,
Just writing my emergency procedures for my XL flight manual. This is to those that are up and flying..
1. If the canopy comes unlatched on one side or open on both sides, can you slow down and close it again? I guess it would rise up a bit.
2. If the canopy breaks or somehow comes off, will the aircraft still fly with all the drag from the fwd turtle deck. I know there are some photos showing open cockpit / sports models but they appear to have a closed turtle deck.
I know that someone in a HDS once wrote that he lost his canopy and still did a slower circuit and landed again without much problems, I wonder if thats the same as the XL??
Chris..
Building and writing
XL 6337
amyvega2005(at)earthlink.
PostPosted: Wed Jul 16, 2008 6:02 am    Post subject: XL canopy open Reply with quote
the procedure i tested are as follows:
1- in event of canopy unlatch or falure, slow the plane down to below 80 mph. Fly the plane
2- in event of cabin opening, slow the plane at altitude enough to relatch, when relatched resume normal flight, if not relatchable, Land.
3- in event of canopy complete failure, slow to below 80 mph, fly the plane, decend and land. Keep power at landing as plane will slow down much quicker due to drag.
In all possible events, don't panic, fly the plane.
Juan
jaybannist(at)cs.com
PostPosted: Wed Jul 16, 2008 6:11 am    Post subject: XL canopy open Reply with quote
Chris,
If I'm not mistaken the canopy that departed in flight was one of the early side opening types. It would open from either side, so if both latches failed, the canopy could depart. The XL canopy is securely fastened to the airframe, even when open. I just can't imagine one simply coming off. Obviously, it could be destroyed by a large bird strike or a mid-air collision, in which case you wouldn't be worrying about whether the turtle deck was open or closed.
Jay in Dallas
jmaynard
PostPosted: Wed Jul 16, 2008 6:33 am    Post subject: XL canopy open Reply with quote
The AMD POH says to slow to 60 knots, fly the airplane, make a normal
landing, and close it on the ground. It specifically says not to attempt to
close it in flight.
turtle deck.
Again, I'd expect to fly it at slower speed, and probably have to use more
power than normal, but it should fly well enough to make a normal landing.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (got it!)
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
jonathan(at)entry.co.za
PostPosted: Wed Jul 16, 2008 6:50 am    Post subject: XL canopy open Reply with quote
Chris wrote....
rise up a bit.
I am afraid you will NOT be able to re-latch the canopy, I have tried.
The canopy has a 'double' latch, and I once took off with the one side having
been latched on the firt latch one, well with all my considerable weight on the
window sill, I could NOT latch the canopy further. I could barely move the
canopy down, that even when I slowed to 70mph
I only realised the latch was on only the first click, was when the wind started
tugging at my left hand shirt sleeve. I have dual sticks, so my left arm rests
on the sill.
Jonathan
601XL 140+ hrs
craig(at)craigandjean.com
PostPosted: Wed Jul 16, 2008 8:35 am    Post subject: XL canopy open Reply with quote
This is what I have written in the past:
Back in December Clive Richards sent out the attached report from the UK PFA
magazine of an anonymous pilot testing his (pre-XL?) 601 with an open
canopy. He attached a safety cord and intentionally unlatched his canopy.
Quoting:
"I commenced the test at 3500 ft and 80 knots cruise. I secured the safety
cord to the cleat at my elbow with about 1 ft of slack and released the
catch. The canopy rapidly popped up about 1 ft at the trailing edge as
expected. I then slowly paid out the cord from the cleat and allowed the
canopy to rise to a steady state. The canopy adopted a position where the
base of the canopy settled to an angle of about 35 degrees to the airflow.
Full lateral and pitch control could be maintained but forward speed dropped
to about 60 knots and despite increase to full throttle descent was about
300 ft/min. An unexpected problem now presented itself. I was descending
quickly and all the strength I could muster with my right arm was only just
sufficient to pull the cord down and cleat it progressively. Possibly the
slot effect at the front of the canopy open at the front increased the lift
(and additionally the gas struts require a cord load of 15 lbs static). I
finally, exhausted, got it down to about 6 inches and returned to."
Craig again. I had a similar experience in an Evektor SportStar. This LSA
resembles the 601XL: low wing, front-hinged bubble canopy. One difference is
that the canopy is split behind the seats. There is a cross-bar behind the
seats:
www.evektoramerica.com/SportStarPlus.htm
I was flying left-seat with my instructor. The canopy popped while we were
in the pattern. I would estimate that the gap was well over a foot. While
the instructor flew I tried to close the canopy. I wrapped my arm around the
cross-bar and used all my weight and strength and could not close the
canopy. At best I think I got the gap down to 6-8 inches. Evektor redesigned
the latch the next year.
I believe the upward force was generated by lift and not wind under the
canopy as it did not decrease as I closed the gap.
-- Craig
canopyopening.pdf
 Filename:  canopyopening.pdf
 Filesize:  99.01 KB
 Downloaded:  446 Time(s)
PostPosted: Wed Jul 16, 2008 11:48 am    Post subject: XL canopy open Reply with quote
Jonathon and Friends:
I agree it is difficult to relatch but not impossible,since I relatched mine at 8,000 ft. hence my response earlier was based on what I did during that incident. Basically ,stall the airplane and at apex, seal the latch. I think where Jonathon's situation came in is everyone job sealing tightness is differnt on each plane , which I found in trying 3 different planes.
Jonathon is correct though in the safest option is.. just land then fix. Since I was high up, 8,000 ft, I cut the flow of air over the canopy to the point where it relatched, basically yanking back on the yoke to stall. Not the safest, but I was comfortable with myself.
If both sides release, all bets are off.
safety first, just land.
Juan
bryanmmartin
PostPosted: Wed Jul 16, 2008 2:51 pm    Post subject: XL canopy open Reply with quote
I have had one side come unlatched in flight a few times, always just
after takeoff. I believe that all cases were caused by my failure to
fully latch the canopy before takeoff. In the first instance, I was
able to re-latch it after climbing to a safe, throttling back to idle
and slowing down to near stall speed. Later, I installed some foam
weather strip under the canopy rail. Unfortunately, this foam got
pretty stiff in cold weather and made it difficult to close the canopy
fully, which led to a couple more instances. With the weather strip in
place, I found it impossible to re-latch the canopy in flight and had
to land to do it. I have since removed the foam and am trying out a
different method of sealing the gap.
I have never had both sides come unlatched in flight and don't think
it's very likely, The design of the canopy pretty much assures that at
least one side will fully latch, so both sides are not likely to come
unlatched unless someone turns the release handle either accidently or
intentionally.
On Jul 16, 2008, at 9:44 AM, chris Sinfield wrote:
Guys and Girls,
Chris..
XL 6337
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
japhillipsga(at)aol.com
PostPosted: Thu Jul 17, 2008 6:36 am    Post subject: XL canopy open Reply with quote
I had the right side unlatch on take off. It probably was not latched properly to begin with. I had installed metal handles just forward on the latch mechanisms on each side so I could guide the arms into the lugs and also to pull down. I have dual sticks so I continued the climb with my left hand on the controls. I have very strong hands and arms but I must admit I could not relatch the right side. I could get it down nearly latched, but not the last little bit. At TOC I flew with my knees, held the canopy down with my right hand and routed the right side seat belt through the handle and sinched it down snug. I went on and completed my flight test program. I too was surprised I could not relatch the side. Best regards, Bill of Georgia
A.F.Rupp(at)att.net
PostPosted: Thu Jul 17, 2008 8:13 am    Post subject: XL canopy open Reply with quote
A.F.Rupp(at)att.net
PostPosted: Thu Jul 17, 2008 2:48 pm    Post subject: XL canopy open Reply with quote
A.F.Rupp(at)att.net
PostPosted: Thu Jul 17, 2008 3:14 pm    Post subject: XL canopy open Reply with quote
A while back, I believe it was Jay Maynard, posted some pictures of the new canopy for 601's and that had what looked to be a very good latching mechanism with the lock handle being on the seat back between the two seats and torque tubes out to the sides. It also appeared to be a pull down latch. Be interesting to see it when it comes out.
It looks like a good retrofit. Maybe Jay could elaborate.
Al Rupp
601XL 6-5765 done less engine
From A.F.RUPP(at)ATT.NET
Gig Giacona
PostPosted: Fri Jul 18, 2008 5:24 am    Post subject: Re: XL canopy open Reply with quote
I got to see Jay plane when he visited KELD. To say the latching system is different is an understatement. I liked it and it would have several fewer failure modes. I could see the inside of the mechanism but I did like the outcome.
As far as retro fitting the system, I'd really like to see plans available for it.
Al Rupp
W.R. "Gig" Giacona
601XL Under Construction
jmaynard
PostPosted: Sat Jul 19, 2008 1:53 pm    Post subject: XL canopy open Reply with quote
outcome.
What Gig didn't mention, but a quick look at my airplane will tell you, is
that mine has the old-style canopy but the new-style canopy latch. I like it
a heck of a lot: as Gig says, it has a lot fewer failure modes.
The latch consists of a hook sticking up through the top cabin side
longeron that engages a bolt installed such that the head sticks out a ways
from the side of the canopy bow. There's one hook on each side, and they're
attached to a rod that runs across the top of the seat back. The outside
canopy latch handle is attached to the left end of the rod; the inside latch
handle is attached to the center of the rod and sticks out between the
seats.
It's easy to close securely. What I do is lower the canopy so the bolt necks
are sitting on top of the hook (on my airplane, this usually takes a little
of pushing to one side), pulling the handle up just enough to allow the
canopy to lower to where the hooks can engage the bolts, then pushing the
handle back down fully to engage. Because of the open design, it's easy to
verify that the hooks are fully and properly engaged, either by sight or
feel.
I think it's a major improvement over the previous system, which has just a
hint of overengineering about it.
for it.
It should be possible, but I don't know how much rework would be needed on
the canopy frame. The cabin side should be dead simple. Next time I'm out at
the airport with not much to do, I'll try to get pictures, especially of the
rod mounting.
Jay Maynard, K5ZC
chris Sinfield
PostPosted: Sat Jul 19, 2008 11:16 pm    Post subject: Re: XL canopy open Reply with quote
Thanks Jay for the update.
Well yes I spoke to the Factory 2 days ago and asked about the new canopy latching system and there should be Mod kits available after next month.
I suggested to them that they make the plans available for free as a good will gesture as the canopy locking system appears to have been troublesome since concept.
People can still buy the parts from Zenith if they want to.. bit of give and take..
We will see what happens.. if enough people suggest that to them at the BBQ or air show it may just happen.
Chris..
just building the canopy now..
PostPosted: Sun Jul 20, 2008 9:51 am    Post subject: XL canopy open Reply with quote
Chris,
Its a nice idea to recommend that they offer the new latch, however some of us builders have had no issues with the existing latch system, and it is contrary to your statement that the latch has been troublesome since concept. I think if it is built and operated correctly, it does the jopb well. If it is an item that I forgot to check before take off, or did a hurried job in building the plane, I have no one to blame but myself.
The new system gives options to those that want the option.
Juan
jmaynard
PostPosted: Sun Jul 20, 2008 2:14 pm    Post subject: XL canopy open Reply with quote
For the curious, I just posted pictures to
http://www.conmicro.com/amd-v2-latch/ .
Jay Maynard, K5ZC
bryanmmartin
PostPosted: Sun Jul 20, 2008 2:25 pm    Post subject: XL canopy open Reply with quote
What's all that hardware made of? It must be a whole lot heavier than
the old latching system.
> you, is
> I like it
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive.
jmaynard
PostPosted: Sun Jul 20, 2008 2:56 pm    Post subject: XL canopy open Reply with quote
Good question, and I'm not the right guy to ask. My guess would be steel; it
feels heavier than aluminum, and you'd want steel at least on the hook and
bolt for wear resistance.
Jay Maynard, K5ZC
Ron Lendon
PostPosted: Sun Jul 20, 2008 3:13 pm    Post subject: Re: XL canopy open Reply with quote
Thanks for the pictures Jay.
Use a magnet to determine what is steel. High grade stainless won't hold a magnet and neither will aluminum.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Goto page 1, 2  Next
Page 1 of 2
