selwyn
Posted: Mon Jul 21, 2008 1:47 am Post subject: Wig Wag and LED's |
I'm planning the set up of a wig wag flash system on my forward lights using the B&C SSF1 unit. I notice that this unit will switch up to 150 W and that it requires a load on each leg to function. I am wondering what the minimum value for the load is as I am planning on using LEDs of around 4 or 5 W for each light. Will this unit function correctly with loads such as this?
Cheers, Selwyn.
nuckolls.bob(at)cox.net Guest
Posted: Mon Jul 21, 2008 6:02 am Post subject: Wig Wag and LED's |
At 02:47 AM 7/21/2008 -0700, you wrote:
such as this?
Cheers, Selwyn.
That's a damned good question my friend . . . and I
don't know. Those electronic automotive flashers are
certainly much less sensitive to load changes than
their thermo-mechanical ancestors but I've never
explored the necessary minimum load to not affect
functionality.
Leds are very different than incandescent lamps.
An LED biased up with microamps across it drops
voltage almost the same as when running full bright.
I'm fairly sure that the electronics in that flasher
are looking for "nearly ground" through an un-energized
filament to function properly.
When push comes to shove, you can probably parallel
one of the lamps with a resistor that might need to
be on the order of 30 ohms (about 3 watts of 'wasted'
power) to keep the flasher happy. You can experiment
with this on the bench. In any case, the final configuration
will still be MUCH less energy needy in spite of the
idiosyncrasies of the automotive electronic flasher.
( -Thomas Paine 1776- )
