sonexpilot(at)gmail.com Guest
Posted: Sun Jul 20, 2008 6:44 am Post subject: Newbie Z-21A question |
Hi. I'm new to this list and am no electrical expert. I am about to get started on the electrical system for my Jabiru 3300 Sonex, and I've been studying all of the material in the Connection web site. I have the following questions about the Z-21A diagram. In the diagram the wires out of the alternator are wired to a Diode Bridge but nothing is wired to the Power Load (+). What is this Diode Bridge for? Also the Voltage Rectifier/Regulator in my jabiru engine has an extra positive (yellow) wire. Where in this diagram can I connect this wire? In a couple of places I see squigully lines with labeles like 1K, 3w and 3K, 3W, are these resistors? Are they really needed? What for?
Thank you all for any help.
Jorge Rodriguez
nuckolls.bob(at)cox.net Guest
Posted: Sun Jul 20, 2008 7:07 am Post subject: Newbie Z-21A question |
At 10:41 AM 7/20/2008 -0400, you wrote:
| Quote: | Hi. I'm new to this list and am no electrical expert. I am about to get
Note 25 of
http://aeroelectric.com/articles/Rev11/AppZ_R11M.pdf
speaks to this question:
Note 25. Making the SD-8 Come-Alive without a
battery:
Subsequent to some excellent 'skunk werks' efforts
on the part of Jim McCulley, the 'Connection is pleased to
offer a work-around to older SD-8 alternator installations
that encourages this useful product to come on line without
benefit of a battery. Adding a pair of diodes and a start-up
bias resistor as shown in Z-25, the SD-8 will come up and
run as soon as the engine is started.
I've suggested the diode bridge rectifier for this application
but you can use wired-leaded devices like 1N5400 series
devices from Radio Shack and others. The advantage of the
diode-bridge is that splices between dynamo and regulator
lead wires can happen in the same PIDG terminals used to
wire the rectifier.
Suitable parts include the following Digikey catalog
numbers:
1 each 1GBPC1204/1 Diode Bridge
1 each ALSR3F1.0K 1,000 Ohm/3W
1 each ALSR3F3.0K 3,000 Ohm/3W
2 each 1N5400 3A, 50V Diode Rectifier
These parts are chosen more for their mechanical
configuration and robustness than for electrical ratings.
Many other styles of parts may be substituted. With these
added parts, one may connect a voltmeter across the 22,000
uFd filter capacitor. A few seconds after the engine is
started, one should observe that the voltage across the
capacitor jumps up to about 6 volts at engine idle. The
voltage rises with RPM until the regulator takes over to
maintain output at about 14.2 volts at cruise RPM.
I don't recall now the rationale for applying this
technique to the Jabiru drawings. The ability of the
PM alternator to come on line without a battery is
a function of RECTIFIER/REGULATOR design. We know
that regulators supplied with the SD-8 have not
exhibit this ability in the past and adding the
resistors and diodes cited above are a reasonable
approach to making the system work without a
battery.
However, I don't recall if we had specific information
about the rectifier/regulator supplied/recommended
for use with Jabiru's PM alternators. For now, leave
the parts cited off. See how your particular alternator-
rectifier/regulator behaves and then get back with us
on the List if you determine that it will not come
up without a battery and you would like for it to
have that feature.
This is not a big deal worthy of your concerns right
now, let's take this up in the future after you've
slain all the dragons.
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Sun Jul 20, 2008 4:11 pm Post subject: Re: Newbie Z-21A question |
Jorge,
The yellow wire is a voltage sense line. Tie it in with your red output wire. It needs to see what the output voltage of that line is in order for the regulator to do its job.
Good Luck,
_________________ David Gallagher
Cincinnati, OH area |
Posted: Sun Jul 20, 2008 5:18 pm Post subject: Newbie Z-21A question |
At 05:11 PM 7/20/2008 -0700, you wrote:
<david.m.gallagher(at)ge.com>
Jorge,
Dave, the last wiring diagram I saw for the 3300
was this thing gleaned from the installation/instruction
manual.
http://aeroelectric.com/Pictures/Schematics/Jabiru_3300_Alternator_Wiring.jpg
Is there something more up to date available? This
first cut at it was exceedingly unhelpful and doesn't
have a yellow wire.
