jpx(at)Qenesis.com Guest
Posted: Wed Jul 16, 2008 6:19 am Post subject: Z13/8 wiring correction ? |
Please look closely at the switch wiring for the E-Mag in Z13/8.
The operation of the switch as pictured is correct. That is the power
is applied to the E-Mag while the P Lead is still grounded, and the P
Lead is grounded before power is removed.
However, the pictorial diagram of the switch does not match the
diagram of the 2-10 switch shown on Page 11-18.
Assuming that page 11-18 is correct, then the V+, pin 5 of the E-Mag
should be controlled by switch connections 2-1 and the P Lead, pin 4
of the E-Mag should be controlled by switch connections 5-6.
Or am I mixed up about something ?
Jeff Page
Dream Aircraft Tundra #10
nuckolls.bob(at)cox.net Guest
Posted: Fri Jul 18, 2008 12:57 pm Post subject: Z13/8 wiring correction ? |
At 10:16 AM 7/16/2008 -0400, you wrote:
Good eye! I have to be careful when doing major edits
between various z-figures. Some of these drawings were
done 10 years ago before I discovered the differences
between Carling-Like and Microswitch-Like progressive
transfer conventions. A few drawings still have un-revised
blocks embedded in them. I've fixed the error you've
cited and published the new drawing at:
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z13-8Q.pdf
Thanks for the heads-up.
( -Thomas Paine 1776- )
Posted: Sun Jul 20, 2008 6:34 am Post subject: Z13/8 wiring correction ? |
Bob,
Although I can display the document, I cannot save it. I suspect
there is a PDF flag that was incorrectly set when you produced the PDF.
Jeff Page
Posted: Sun Jul 20, 2008 6:53 am Post subject: Z13/8 wiring correction ? |
At 10:31 AM 7/20/2008 -0400, you wrote:
It's the same settings I've used since day-one. The only
flags I have to remember to set each time I upload a file
to the server is to make them executable by all.
My ftp program doesn't do that automatically. I just
downloaded the file and saved it both through the browser
'save page as' and Adobe's file save tag.
Try right-clicking the link in your browser and telling
it where to store the file as opposed to opening directly
from the browser.
