professor71(at)hotmail.co Guest
Posted: Thu Mar 16, 2006 8:01 pm Post subject: CAS was Sport pilot |
Since the subject of CAS was brought up, I was wondering how to determine
this. I know you use true airspeed, density altitude, and temp. Is TAS the
same as the average groundspeed in 3 different directions with a GPS? My
601HD IAS is normally around 110 to 115 with GPS showing 98-104. So does
this mean my IAS is reading high so CAS would be actually lower?
John
bryanmmartin
Posted: Fri Mar 17, 2006 1:26 pm Post subject: CAS was Sport pilot |
It's not the same as the average groundspeed from three different runs, it's
a vector calculation. The following website contains a link to an Excel file
that will handle the calculations for you.
http://together.net/~billvt/True%20Air%20Speed/true_airspeed_calculator.htm
You just have to fly three GPS tracks and record the track and ground speed
and the file will calculate the true airspeed. Also record the OAT and
pressure altitude for your test runs so you can convert TAS to CAS with an
E6B. This is a backwards calculation in that normally you use the E6B to
find TAS from CAS.
If your GPS determined TAS is reading lower than your IAS that usually means
that your airspeed indicator is reading high. This is common with CH 601s
that have the static source in in the cockpit, since the cockpit is at a
lower pressure than ambient in flight. At very low speeds the ASI will read
much lower than CAS because the air is hitting the pitot tube at an angle
rather than straight on. To get an IAS that accurately reflects CAS, you
need a proper static source and the pitot tube must be aligned directly into
the airstream in relatively undisturbed air.
Bryan Martin
John
_________________ --
Bryan Martin
do not archive. |
