bandit362
Posted: Fri Jul 25, 2008 4:53 am Post subject: 51% Rule |
Hello Everyone,
Been lurking here for the last several months, listening to the chat. Retired from the AF last year (flew F-4s, F-117s and F-16s) and was hired by a defense contractor here in Tucson. Took a demo ride in Greg Hobbs Lightning last Nov and have been looking at my finances to try to squeeze money from the budget (just sold a house in Hawaii and am looking to buy here in Tucson.)
Anyway, enough about me. What do you think the 51% ruling is going to do for/against the Lightning? (I am hoping for!!)
Tim Veeder
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
_________________ T Veeder |
N1BZRich(at)aol.com Guest
Posted: Fri Jul 25, 2008 6:19 am Post subject: 51% Rule |
Tim,
From one retired AF fighter pilot to another - welcome aboard. The answer to your 51% rule question is still a bit "up in the air" but we should have a better understanding of the new FAA proposal after Oshkosh (I am there now). But reading their proposal, I think the Lightning should be OK. Below is a summary of what the AOPA has to say about the new proposal. We will get the EAA's take in several forums during the convention.
Blue Skies,
Buz Rich
The FAA is scrutinizing “fast build� homebuilt aircraft programs and with that may come policy changes that affect future kit designs.
The FAA has released several draft documents to clarify the regulation of the homebuilt aircraft segment. The biggest potential change is to the definition of the so-called 51-percent rule. The FAA’s original intention was that the individual would fabricate more than 50 percent and assemble more than 50 percent of the aircraft.
The FAA became concerned when fast-build kits entered the market where an aircraft owner’s contribution resulted in 51 percent of the assembly only. The agency felt that this did not meet the intent of building “solely for their own education or recreation.�
The FAA now defines 51 percent as the builder completing, at a minimum, 20 percent of the assembly and 20 percent of the fabrication with the remaining 11 percent made up from either additional assembly or fabrication. The FAA now states that the commercial assistance or “for hire� building programs will not count toward 20 percent of the assembly by the individual.
The policy changes would not affect those flying traditionally certified aircraft or already completed amateur-built aircraft. Existing kit designs essentially would be grandfathered, while new models, after the rules go into effect, would get the extra scrutiny.
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Fri Jul 25, 2008 9:44 am Post subject: 51% Rule |
You know Buz, the part of this proposal that is rough on glass kit builders is the fabrication. Think about how most glass kits come, mostly prefabricated fuse, flying surfaces, spar box, etc. I wonder what that would add up to in total?
There are however, quite a lot of things to do from the fabrication side. If you compare a Lightning kit to say, a quickbuilt RV, they then begin to look pretty close. So, if the RV quickbuilt qualifys under the proposal, then the Lightning should also?
Jim!
On 7/25/08, N1BZRich(at)aol.com (N1BZRich(at)aol.com) <N1BZRich(at)aol.com (N1BZRich(at)aol.com)> wrote: [quote] Tim,
Blue Skies,
Buz Rich
The FAA is scrutinizing "fast build" homebuilt aircraft programs and with that may come policy changes that affect future kit designs.
The FAA has released several draft documents to clarify the regulation of the homebuilt aircraft segment. The biggest potential change is to the definition of the so-called 51-percent rule. The FAA's original intention was that the individual would fabricate more than 50 percent and assemble more than 50 percent of the aircraft.
The FAA became concerned when fast-build kits entered the market where an aircraft owner's contribution resulted in 51 percent of the assembly only. The agency felt that this did not meet the intent of building "solely for their own education or recreation."
The FAA now defines 51 percent as the builder completing, at a minimum, 20 percent of the assembly and 20 percent of the fabrication with the remaining 11 percent made up from either additional assembly or fabrication. The FAA now states that the commercial assistance or "for hire" building programs will not count toward 20 percent of the assembly by the individual.
Kayberg(at)aol.com Guest
Posted: Fri Jul 25, 2008 11:12 am Post subject: 51% Rule |
In a message dated 7/25/2008 1:45:27 P.M. Eastern Daylight Time, pequeajim(at)gmail.com writes:
| Quote: | You know Buz, the part of this proposal that is rough on glass kit builders is the fabrication. Think about how most glass kits come, mostly prefabricated fuse, flying surfaces, spar box, etc. I wonder what that would add up to in total?
Jim!
I have only read parts of the NPRM but I think the age-old question is How much do you have to fabricate to be a fabricator?
I would think that if you had to add a tad of glass somewhere it would count as a fabrication (!!?!)
Likewise an assembly. If you had to assemble the last rivet in the flap, you would still be the assembler.
Somewhere between an aluminum smelter and a rivet lies the answer.
I will try to think about it more, but we should all give it some thought.
Doug Koenigsberg
n5pb(at)aol.com Guest
Posted: Fri Jul 25, 2008 2:12 pm Post subject: 51% Rule |
Buz,
This is good to know, especially since I begin my build in September at SYI!
"Bear"
Colin K.
Posted: Fri Jul 25, 2008 3:06 pm Post subject: 51% Rule |
Buz,
I understand you have quoted the AOPA here, but are you getting the impression that "Existing kit designs essentially would be grandfathered" or that "Existing kit designs, already on the FAA's 51% list, essentially would be grandfathered"?
In this case the difference could be critical because the Lightning is not already on the FAA's 51% list.
Colin K.
OK
Lightning # 52 under construction.
http://www.mykitlog.com/cojaken
_________________ Colin K.
OK |
dashvii(at)hotmail.com Guest
Posted: Fri Jul 25, 2008 3:37 pm Post subject: 51% Rule |
Hey Tim C
Good to have you onboard. I think that you'll find a lot of fellow air force and/or government contract workers on here. Too bad that you sold the house in Hawaii C but if you can get a house in Tucson and a Lightning that'd be pretty nice. Brian W.
| Quote: | Subject: 51% Rule
Date: Fri C 25 Jul 2008 05:53:54 -0700
To: lightning-list(at)matronics.com
--> Lightning-List message posted by: "bandit362" <t_veeder(at)yahoo.com>
Hello Everyone C
Been lurking here for the last several months C listening to the chat. Retired from the AF last year (flew F-4s C F-117s and F-16s) and was hired by a defense contractor here in Tucson. Took a demo ride in Greg Hobbs Lightning last Nov and have been looking at my finances to try to squeeze money from the budget (just sold a house in Hawaii and am looking to buy here in Tucson.)
Anyway C enough about me. What do you think the 51% ruling is going to do for/against the Lightning? (I am hoping for!!)
Regards C
Tim Veeder
T Veeder
http://forums.matronics.com/viewtopic.php?p=194865#194865
With Windows Live for mobile C your contacts travel with you. Connect on the go. [quote][b]
flying(at)qdea.com Guest
Posted: Fri Jul 25, 2008 5:34 pm Post subject: 51% Rule |
I suspect "grandfathering" is more likely to apply to aircraft on the
FAA's list, not to any kit currently being produces.
I looked through that list, and I was surprised at how few aircraft
were on it, and how many were aircraft that no one would build today,
like the Cirrus VK-30.
The part that I've always had trouble sorting out is what the
percentage refers to.
It could be that a tail is considered to be 30% of the aircraft, so
if you "fabricated" the tail, you'd be done with the fabrication
requirement.
Is it percent of time, and if so, what time? A fuselage for a
Lightning takes only a very few hours to "fabricate" at the factory
once the molds have been built, so maybe it only contributes a few
hours to the total "fabrication and assembly time" for the aircraft.
If that's the case, the lower the total number of hours needed to
fabricate and assemble the factory-supplied parts, the fewer the
hours the amateur builder needs to put into the aircraft to meet the
51% rule.
That may be the saving grace for the Lightning, in that the nature of
an airplane built from composite molds is such that there aren't that
many total hours.
Hugh Sontag
[quote]Buz,
Colin K.
OK
<http://www.mykitlog.com/cojaken>http://www.mykitlog.com/cojaken
Colin K.
jhausch
Posted: Wed Jul 30, 2008 9:00 am Post subject: Re: 51% Rule |
I shared these comments in the EAA tent at Osh yesterday, but I want to repeat here for the comment of others:
It looks like the level of completion and lack of overall builder performed glass/composite work on the Lightning might be a problem with the latest interpretation of the 51% rule.
I would suggest, as an alternative to providing components of the kit in a "less complete" format, that the FAA allow a builder to demonstrate glass/composite construction skills on a part which does not become part of the final aircraft.
I'd gladly build a small and simple mold; lay in gelcoat, glass, resin, etc; remove and trim; attach a bracket; etc etc.
This would demonstrate to the FAA that I had the experience to work on this glass kit, but it would not require me to have large molds to do so.
sales(at)billandruth.net Guest
Posted: Wed Jul 30, 2008 4:34 pm Post subject: 51% Rule |
Hello All,
I just reviewed Van's quick build kits and I see very little difference between their state of completion and that of the delivered Arion Kit. It seems to me the Lightning should have little difficulty in demonstrating that we indeed built "51%" of our kit.
However, what if the FAA says that the kit does not meet the "51%" intent of the rule, what then?????
Bill Applegate, Tucson, AZ with kit #49.
jhausch wrote: [quote] | Quote: | --> Lightning-List message posted by: "jhausch" <jhausch(at)charter.net> (jhausch(at)charter.net)
http://forums.matronics.com/viewtopic.php?p=195758#195758
| [b]
IFLYSMODEL(at)aol.com Guest
Posted: Thu Jul 31, 2008 1:39 am Post subject: 51% Rule |
Hey Bill: I agree that we may have a problem. With all the changes in fabrication techniques between glass and aluminum, it is difficult to prove the 51% rule. I must admit that I could not believe how easy it was to work with fiberglass, compared to aluminum. I think the real effort must be shown in the difference in the materials and applications. IF, and I think that is a big IF, the FAA (I use that term loosely because it all depends on the individual doing the evaluation) can be shown the ease of operation/application I think it can be shown that the completion of the kit will fall within the 20% indicated in their press release.
>> To ensure consistency and standardization concerning amateur-built
kit aircraft evaluations, the FAA proposes to clarify how much
fabrication and assembly must be performed by the amateur builder. The
FAA is proposing that an amateur builder fabricate a minimum of 20
percent of an aircraft and assemble a minimum of 20 percent of the
aircraft. The FAA also clarifies the role of commercial assistance,
which includes both the pre-fabrication of parts and direct assistance
to the builder, as part of the remaining 49 percent (manufacturer and
commercial assistance). <<
Lynn Nelsen
info(at)flylightning.net Guest
Posted: Tue Aug 05, 2008 5:37 am Post subject: 51% Rule |
To Group,
Arion aircraft will post a longer more detailed read in the next news
letter, but here are a few thoughts. First the "approved" list is not a
prerequisite for and EAB inspection or certificate, it only makes the DARs
job easier in determining who did the major portion of the work. With this
in mind keep very detailed builders logs of what you are doing why and how
and you will not have a problem. This was discussed in length at several
forums at EAA (forgive me if I do not call it Airventure) and this was the
general consensus. There is nothing wrong with the current rule however
determining major portion and how to enforce it has loosened. This is the
focus and it was made clear that those building aircraft at home weather on
the list or not, if showing proof thru builders logs or photos and notes
would not have a problem showing that they did the work and would not have a
problem receiving there AWCs. The FAA has extended the comment period for
the proposed policy, This is key, it is a policy and not a rule, they do not
even have to show it to us if they want, but they are. So email
miguel.vasconcelos(at)faa.gov with your comments. Please do not send screamers.
They will not listen to them and they made that very clear. When sending a
comment make it clear what you think is wrong and than propose how it could
be fixed or adjusted this is what they want to see. It is our privilege to
build these aircraft at home and it is our job to help the FAA understand
that and keep it alive.
Nick Otterback
Arion Aircraft, LLC
pete(at)flylightning.net Guest
Posted: Tue Aug 05, 2008 10:30 am Post subject: 51% Rule |
The initial issue that caused the FAA to look at the Amateur built rule was
that some companies offering commercial assistance were way over the line.
There is a company that will complete a Glastar in two weeks. That is a
3500 hour build and there is no way that a builder can have enough input to
even come to a 10% involvement let alone 51%.
However, instead of shutting down the commercial operations the FAA has
focused on kit manufacturers and is trying to control the amount of
prefabrication in the kit. This approach will do nothing except encourage
more commercial assistance since there will be more to do to complete the
plane.
The message delivered in the two forums at OSH on the subject is that the
kits are not the problem but commercial assistance is and that the FAA
should focus on commercial assistance.
I believe the FAA people in attendance took that message to heart. As a
result of comments so far the FAA has extended the comment period until Sept
30. It is very important to make your voice heard by the FAA. I would
encourage everyone to comment on the proposal. I will be posting my
comments to the FAA on this list and I would hope that others will post here
as well.
Please be specific in your comments. Cite a paragraph from the proposal and
tell them if you agree or disagree and why. The offer an alternative
solution or approach.
Look for some additional info from Nick soon.
Pete Krotje
Arion Aircraft, LLC
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
