gholland(at)gemini-resour Guest
Posted: Sun Mar 12, 2006 4:06 am Post subject: SL70 Transponder with serial encoding from Rocky Mountain E |
Hi!
| Quote: | I'm doing a bench shakedown on my Panel prior to fit in Aircraft.
Results not too bad but SL70 Transponder encoding from Rocky Mountain
Encoder not functioning.
I may have had an oversight!
It appears that I may have assumed a serial output for Transponder and
that's not possible but may need to revisit and go parallel.
Still interested in any comments on this combination.
Gerry
Posted: Sun Mar 12, 2006 9:05 am Post subject: SL70 Transponder with serial encoding from Rocky Mountain E |
Hi all. Panic over.
SL70 working well with Rocky Mountain Encoder in Gray Format.
One last glitch...... Strobe (pin 15) and Com (Pin 14) needed connecting
together for handshake to work.
The SL70 seems a neat unit with Altitude readout and an Altitude hold
function for notification of loss or gain of altitude. Can drive a warning
lamp if required.
Many thanks to Ralph Capen for a near instant response!
Another task closer to first flight. Not long now.
Gerry in UK
