rvbuilder(at)sausen.net Guest
Posted: Mon Mar 13, 2006 8:00 am Post subject: RV-10 propeller test? |
Jim,
Did you ever get some comparison data around this?
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com
Sent: Sunday, October 02, 2005 10:51 PM
To: rv10-list(at)matronics.com; RV10(at)yahoogroups.com
Subject: RV-10 propeller test?
Hi All,
Is anyone willing to test both the RV-10 MT Propeller and the RV-10 Hartzell propeller on their flying RV-10?
Please contact me directly at jim(at)lessdrag.com (jim(at)lessdrag.com), or call me at (805) 795-5377.
Van's Aircraft hasn't had time available with their RV-10 to test the RV-10 MT Propeller.
The Hartzell propeller Van's Aircraft sells to RV-10 builders, model number C2YR-1BFP/F8068D, is unique to the RV-10.
In talking with Hartzell, apparently the C2YR-1BFP/F8068D propeller can only be purchased from Van's Aircraft.
And Van's Aircraft can only sell one Hartzell propeller to each builder.
Do you see were this is going?
The Hartzell builders are the only ones with the RV-10 Hartzell propellers.
It looks like it is up to someone with a flying RV-10 using a Hartzell propeller to step forward, if both propellers are to be tested on a common airframe.
Jim Ayers
