rowedenny
Posted: Tue Aug 19, 2008 2:47 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
I recently bought an unused pair of steel (high rise) gear legs from a fellow lister to replace my original aluminum legs.
Just spent the afternoon trying to set my alignment and get them both the same.
I have the plane hanging from the hanger roof and a center line string pulled from the tail wheel to the nose hoop.
Can't seem to figure out how to hold the legs in position while measuring alignment.
Any and all suggestions are appreciated.
Denny Rowe
lcottrell
Posted: Tue Aug 19, 2008 3:04 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
Hi,
Just finished doing the same thing with my Firestar. Take the wheels off the axels and put them in the fittings on the inside of the legs. ( to the middle) and then take a flat piece of steel and clamp the axles to the steel. This will give you a straight line across with no toe in. As it was explained to me the steel legs don't need to have windage built in as is needed in the alum legs. It is a bit more sensitive without the toe in, but not a problem after you get used to it and the plane accelerates a lot faster without the drag of the toe in.
As with all advice, it is worth what you paid for it, but I like mine that way. This was suggested to me by Terry Davis, and I appreciate it, and like it.
Larry C
Oregon Firestar 2, 427 hours
DAquaNut(at)aol.com Guest
Posted: Tue Aug 19, 2008 3:44 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
In a message dated 8/19/2008 5:47:32 P.M. Central Daylight Time, rowedenny(at)windstream.net writes:
| Quote: | Can't seem to figure out how to hold the legs in position while measuring alignment.
Denny,
If I understand your problem right and you are having trouble keeping the legs from sliding out you should be able to use a c-clamp or c-clamp vise grips. Place them over the steel gear leg socket and squeeze just enough to compress to contact the gear leg. This should make them stay put. If I dont understand what you are up against.........never mind .
Ed Diebel
It's only a deal if it's where you want to go. Find your travel deal here.
lcottrell
Posted: Tue Aug 19, 2008 4:02 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
If that is the case with them clamped in position, you can either lower them until they contact the floor, or tie them up with the clamped bar.
Larry C
bill_joe(at)bellsouth.net Guest
Posted: Tue Aug 19, 2008 4:50 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
Hi Denny.
Here is how I did mine. I jacked the plane up and put blocks under the cage just about where the gear legs go in. Pushed the new legs up to the mark that was put on them by Kolb , the marks tells you how far to push them up in the tube. I too two pieces of 5/8 rod about 12 inches each and pushed them on the axel holes.. I then took a piece of one inch angle iron that bought at tractor supply that was long enough to reach each axel.. Clamped that with C-clamps to the 5/8 rod and that will give you straight alignment with 0 toe in or toe out.. Worked great for me. You know we should take pictures when we do things like this so we can show others. I think I will from now on.
Bill Futrell
Posted: Tue Aug 19, 2008 5:47 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
As you probably know already, the steel legs provide a new angular perspective to deal with.The old straight legs could be adjusted at the axle only.
Coming from an inexperienced point of view, I would use some guesswork on the legs and
then adjust the axles at a happy midpoint for an initial setting.
All the above would have to be done under full load. -no hanging from supports, etc.
Let us know regarding progress as I may go the same route eventually.
BB, sorta straight alum legs, MkIII
On 19, Aug 2008, at 6:44 PM, Denny Rowe wrote:
| Quote: | I recently bought an unused pair of steel (high rise) gear legs from a fellow lister to replace my original aluminum legs.
Denny Rowe
| Quote: | http://www.matronics.com/Navigator?Kolb-List
rowedenny
Posted: Tue Aug 19, 2008 7:19 pm Post subject: Installing new steel gear legs on Mk-3 Classic ? |
Thanks to all for the help!!!
I'll be off to the local metal supplier in the morning for the 5/8" rod for alligning the axles, that is a great idea and as simple as it gets.
Denny, kicking myself for not thinking of this, Rowe
Dennis.Kirby(at)kirtland. Guest
Posted: Wed Aug 20, 2008 8:22 am Post subject: Installing new steel gear legs on Mk-3 Classic ? |
<< I'll be off to the local metal supplier in the morning for the 5/8"
rod
Denny >>
Hey Denny -
Here's the cheapest way to do it: Go to Home Depot and buy a "grounding
rod," like what electricians use for grounding a house. It's 5/8 inch
diameter, smooth, copper plated, and about 6 feet long. You can use it
to pass thru BOTH gear fittings at once, thus eliminating the need for
the angle iron and clamps.
Dennis Kirby
Mark-3
New Mexico
Posted: Wed Aug 20, 2008 11:32 am Post subject: Installing new steel gear legs on Mk-3 Classic ? |
Hey guys the angle of the axels will not allow a solid piece of 5.8 rod
to pass through them. I don't think they get that way even with full weight
on them unless you have a couple guys in the plane. If we are talking about
the new steel gear from Kolb, the hollow tubing.
Bill Futrell
