keithmckinley
Posted: Fri Aug 15, 2008 6:08 am Post subject: No sidetone driving me insane! |
Hi,
I've got an Icom a200 radio connected through a pm 1200 intercom.
When I got the plane it had no side tone at all. Pulled the radio and tried to adjust the sidetone pot to no avail. Turned off intercom and still no side tone.
I've tried numerous different headsets. I did notice what seems to be a disconnected wire(s) at the molex connector but don't no if that's an issue. The wiring job is shoddy to begin with but I'd hate to rip it out and start new if it's actually a radio issue.
radio transmits and receives just fine and the intercom is awesome at canceling out noise in my very loud warbird.
Just hoping for some last chance advice before I send the radio out for a bench test.
Keith
nuckolls.bob(at)cox.net Guest
Posted: Fri Aug 15, 2008 4:44 pm Post subject: No sidetone driving me insane! |
At 07:08 AM 8/15/2008 -0700, you wrote:
<keith.mckinley(at)townisp.com>
Hi,
still no side tone.
bench test.
Sidetone is not subject to variations in headsets.
If you can hear anything else in the headsets and
no sidetone, then it's not the headsets.
I looked at the installation manual and didn't spot
any mention of sidetone . . . are you sure this
radio supports it?
( -Thomas Paine 1776- )
rampil
Posted: Sat Aug 16, 2008 5:54 am Post subject: Re: No sidetone driving me insane! |
Assuming that the hardware supports sidetone(and I think all intercoms
do), then lessee:
shoddy amateur wiring with obvious failed connectors vs. solid state
radio.....
In all of aircraft, it's not what you want to do, you do what needs to
be done.
Take your time, get it right, and if you can't replace the crappy
molex connectors, at least solder them after crimping
keithmckinley
Posted: Sat Aug 16, 2008 6:32 am Post subject: Re: No sidetone driving me insane! |
sidetone is supported by intercom and radio.
I think I'll pull the radio for a bench test....had enough
Keith
Bruce(at)glasair.org Guest
Posted: Sat Aug 16, 2008 6:58 am Post subject: No sidetone driving me insane! |
A good crimp with the proper tool is just as good as a solder joint. Now
when you solder a crimped joint you create a single stress joint at the
solder point. Unless you provide some stress/flex relief (shrink wrap tube),
you're asking for trouble down the road.
Bruce
www.Glasair.org
jgarner(at)dslextreme.com Guest
Posted: Sat Aug 16, 2008 8:03 am Post subject: No sidetone driving me insane! |
One thing you might check is where the headset is
wired to. Most radios have a headset AND a
speaker output, they are not the same. Speaker is
muted with transmit and headset has sidetone.
This bit me when I installed a SL30! Still have
to go under the panel and move that pin...
HTH, Joe
keithmckinley wrote:
"keithmckinley" <keith.mckinley(at)townisp.com>
Hi,
pm 1200 intercom.
Keith
-------- Wizard
keithmckinley
Posted: Sat Aug 23, 2008 6:05 am Post subject: Re: No sidetone driving me insane! |
THANK YOU JOE GARNER!
You were absolutely right. The person who wired this system used the speaker out terminal to the headsets instead of the headset jack out.
Problem solved, life is good!
Next beers are on me!
Keith
