talew(at)bellsouth.net Guest
Posted: Wed Aug 20, 2008 4:43 am Post subject: Paintball tank? |
Hi.
That is very high pressure. Where do you have it filled?
Terry Lewis
Posted: Wed Aug 20, 2008 5:33 am Post subject: Paintball tank? |
Yes for other reasons than spar start air. The problem is getting them
filled. There are Scuba dealers in just about every large city and the fire
dept. will in some cases fill the SCBA tanks. The fittings were different
for the paintball tank (thread type) requiring the paintball dealer do the
refills.
I'm using my system for fresh air in the cockpit as well as spar start air.
Doc
N642K
Posted: Wed Aug 20, 2008 4:32 pm Post subject: Re: Paintball tank? |
What size paintball tanks are you using? My local paintball field will fill 3000 and 4500 tanks for $5.00. The 4500 tanks are pricey but thats a lot more air. Is a 48ci 3000 psi tank sufficient?
Thanks in advance.
Mike
Posted: Wed Aug 20, 2008 7:07 pm Post subject: Paintball tank? |
Mike,
I'm not using a paintball tank. I'm using a 3200 psi Scuba pony tank. I had
a high pressure line installed on the Stage I from Scuba Pro then I attached
a pressure gauge in series with the pressure line that connects to the
Schrader valve with a strut pump coupler from Aircraft Tool Supply.
Doc
ChangDriver
Posted: Thu Aug 21, 2008 10:11 am Post subject: Re: Paintball tank? |
SCUBA tanks are inexpensive, reliable and easy to fill. They also require VIPs and hydros. A nice safety check for putting a high pressure tank in your plane.
Craig
