sam.marlow
Posted: Tue Mar 14, 2006 1:05 pm Post subject: Oil Filler |
I'm getting ready to build my IO540, and have a question as to which
part number Oil Filler to use. Lycoming has about four different P/N's
for the IO540, narrow deck. For those of you who have installed your
cowling, which one works best, or if you had it to do over again, would
you use? The choices are as follows, 4-1/2", 6-5/16", 2-11/16",or
2-3/16". Maybe someone could just measure theirs, it would be a big help!
Sam Marlow
Still working on the fuse!
Tim(at)MyRV10.com Guest
Posted: Wed Mar 15, 2006 4:19 am Post subject: Oil Filler |
I usually forget everything that I wanted to remember when I go to
the hanger, so I can't guarantee I'll get the measurement soon, but
what you may want to do is to call Bart at Aerosport and see he used
on mine. It fit nicely. My guess is that he would consistently
use the same one.
Sam Marlow wrote:
Sam Marlow
jesse(at)itecusa.org Guest
Posted: Wed Mar 15, 2006 4:58 pm Post subject: Oil Filler |
If you could get one that would go 90 degrees and leave the filter sticking
up vertically, that would be a good way to go. Other than that, I don't
know which one we have. The filter is a bit of a pain to get on and off,
and torque.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of
May. You may call me at 352-505-1899 and leave a message that I can check
from down here. Any I-TEC questions can be directed to the I-TEC office at
352-465-4545.
