vmenkal(at)mac.com Guest
Posted: Sat Aug 30, 2008 4:19 pm Post subject: Increasing Registered Gross |
Thanx for the info Mark. Gives me a better idea of what increasing
the gross weight means in terms in real terms. Im really treading
softly with this until I can thoroughly understand what this change
means in terms of satety and performance
I have a newer kit with a gross of 1100lbs and ULF of +6 and -3. If
I am using Chris Heinz's formula correctly, I believe that an increase
to 1200lbs will decrease my ULF to +5.5 and -2.75. Based on my
(very limited) knowledge, this still seems quite decent.
My research into this has a practical application as flying up here
requires carrying full survival gear and folks generally dress in
heavy clothing when outside (gets a bit chilly at times). These
items quickly eat into useful load.
My next research topic is to how my proposed increased gross combined
with the extra weight of floats will impact on safety and performance.
If I may pose a question to float equipped 701 operators: what was
the net weight increase with floats (weight of floats less weight of
removed landing gear) and impact on performance with your specific
type of floats This information will be very helpful in deciding on
the type of floats to select for the plane, when that happy day arrives.
One last question (honest): as useful load is important to all
pilots, why wouldnt most builders register at the higher gross weight?
Thanx for all help folks and on an unrelated topic (apologies if this
is not allowed) my thoughts and prayers are with anyone who may be in
the way of Gustav. Please stay safe and if its really nasty well be
down with our little aid agency (aidrelief.org) to lend a hand.
Warmest Regards
Victor Menkal
Whitehorse Yukon
701 tail complete, wings being covered
Victor.
You can change the gross weight to what ever you want. You will need to
change the load factor in your POH. I have the old kit and have made
most of the changes to the SP, but not all. What I have done is, using
Chris's calculations on the drawings, I will be using an 1100 lbs gross
weight with a load factor of +3.5 and -1.7. Rather than the +4 and -2.
This will give me the same load on the aircraft.
Mark S.
701/912ULS
jetboy
Posted: Sat Aug 30, 2008 9:31 pm Post subject: Re: Increasing Registered Gross |
You also must change the POH and airspeed placard limits because vne, vfe, va are related to operations at design gross, will be lower for overgross, and what might be experienced in gust load conditions.
The fact that guidance is provided for these operations does not mean that the aircraft is legal or approved in all situations and juristictions and like practically any aircraft the 701 does not handle too well over gross and please remember the airfoil has not changed since the max gross was 880 lbs in '86 AFAIK
I also like to carry extra clothing and gear so what I did is not fit any cockpit stuff thats not required for the mission, no extra lights, drill holes in tools and safety gear to cut weight where posible, no axe - just folding saw Silky or Gerber instead, If I were doing it again I'd consider not painting the aircraft
Also if you read carefully the latest recommendation on controls limitations for the 601XL, the same cautions would apply to a 701 over gross. Because these "advanced ultralights" by definition had to be designed light, there is practically zero margin left, over time the skins will wrinle and get weaker, its entirely up to the operator to look after his arse
Ralph
_________________ Ralph - CH701 / 2200a |
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sun Aug 31, 2008 5:06 am Post subject: Re: Increasing Registered Gross |
That is good advise, though I doubt that the 701 is that close the the edge. The Savannah is an almost direct copy and the wing is a copy (though extended a bit) of the older 701. Yet it is rated at both a higher gross and a higher Vne. And they are not exactly falling out of the sky. Here are the upgrade instructions from ICP to increase the gross on the older model when the 701 went to 1100lbs. They are available on the yahoo Savannah site if your wondering where I got them. When you look at them, look also at your 701 SP plans, it is interesting to say the least.
Kevin
221.59 KB |
659 Time(s) |
 Download |
| Filename: |
Savannah 560kg upgrade.pdf |
179.06 KB |
| Downloaded: |
1025 Time(s) |
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
eightyknots
Posted: Mon Sep 01, 2008 10:15 pm Post subject: Re: Increasing Registered Gross |
When you registered the 701 at a higher gross weight, what was the new vne, vfe and va?
The Savannah has now come up in this thread. Has anyone ever seen an honest and reliable comparison between that aircraft and the CH 701?
Similarly, has anyone seen (or done) a comparison between the Aeroprakt A22 / Foxbat / Valor [take your pick - it has three names in different parts of the world], which is sold as a STOL kit plane?
_________________ Hank
I am looking for a STOL high-wing plane to build, starting some time during 2009. Will it be an ICP Savannah, a Zenith CH-701, an Aeroprakt Foxbat/A22/Valor, or X-Air H? |
graeme(at)coletoolcentre. Guest
Posted: Mon Sep 01, 2008 10:33 pm Post subject: Increasing Registered Gross |
| Quote: | From a friend who flys both reguarly
Both good aircraft.
Savanna is faster.
Not as good in bumpy air not as good on marginal strips.
You can nail the 701 the savanna some times tends to float on.
In australia Savanna much cheaper to purchase airframe kit.
No plans Built Savanna!!
Graemecns CH701 and scratch building a second
vgstol(at)bigpond.net.au Guest
Posted: Tue Sep 02, 2008 1:42 pm Post subject: Increasing Registered Gross |
I have a lot of experience with both 701 and Savannah.
Yep, both are good aircraft.
I do lots of x-country, and the Savannah probably is a bit bumpier than the 701 due the larger wing, certainly not a problem. The Savannah is more directionally stable - I regularly cruise 3 hrs at a time without touching the stick, just a bit of rudder pressure to hold course. The Savannah VG is faster than a 701 with slats, but a 701 without slats is faster than a Savannah.
On marginal strips or off-field I'll match a Savannah with a 701 anytime - different but equal. Yes, the Savannah floats more, but this gives really gentle, easy landings with good hold-off control right to touch-down at idle speed. With 701 pretty much need to pull it on with power all the way - that can be good to nail a spot, but also can go wrong real quick if you get behind the drag/power curve.... To nail the spot in the Savannah, keep the short final speed to no more than 40kts and carry a full slip right into round-out. Just move the aiming point back a bit to allow for the float and nail the spot just as well. With such a slip approach you can see the touchdown point right to round-out, whereas dragging on with power can't see anything, so I much prefer it....
The Foxbat has sometimes been called, "...the rich man's Savannah..." Much better cruise speed, but still really good STOL for all practical purposes. Maybe not so suitable for really rough off-field... Big, roomy cockpit with excellent visibility. A very nice aircraft, but lots more costly than 701 or Savannah....
Tailwinds always,
JohnG
kmccune
Posted: Tue Sep 02, 2008 3:09 pm Post subject: Re: Increasing Registered Gross |
OK, there you did it John
Is the 701 in the below comparison a 701 VG? And is it a short or long wing 701? You mentioned a slip so I am of course wondering if apples and apples or 701 slat and non-slip apples and VG Savannah slip-apples?
Sorry for the humor, will the 701 long wing VG match the spot landings over obstacles,slip or not. of a 701 with slats and a short wing?
PS
Starting on my wings so I have a big decision to make in this regard, very soon.
Kevin
| apple(at)bigpond.net.au wrote: | | [b]On marginal strips or off-field I'll match a Savannah with a 701 anytime - different but equal. Yes, the Savannah floats more, but this gives really gentle, easy landings with good hold-off control right to touch-down at idle speed. With 701 pretty much need to pull it on with power all the way - that can be good to nail a spot, but also can go wrong real quick if you get behind the drag/power curve.... To nail the spot in the Savannah, keep the short final speed to no more than 40kts and carry a full slip right into round-out. Just move the aiming point back a bit to allow for the float and nail the spot just as well. With such a slip approach you can see the touchdown point right to round-out, whereas dragging on with power can't see anything, so I much prefer it... |
Dorothy McCune |
Posted: Tue Sep 02, 2008 4:16 pm Post subject: Increasing Registered Gross |
Gday Kevin,
In that comparison I was imagining the 701 to be short wing with slats, and the Savannah to be the VG model.
Yes, the 701 long wing with VGs will get down over an obstacle just as well as a short wing with slats - at least so close the same that we can't dependably measure any difference. The 701 long wing VG acts more like the Savannah, so the technique is similar, and similar benefit of a bit of float to make touchdown easier.
Slip is the key for a steep descent in any of them, and the 701 is superior to the Savannah in that regard due to that all-flying rudder that has heaps of power right down to nil airspeed. With that powerful rudder, offset by equally powerful ailrerons, and that slab side, the 701 is the very best slipping aircraft ever. Slipping is by far the best technique for a steeeep descent, even with slats on. Slipping without slats is more steady and controllable, probably due to the slats disrupting the airflow. Even with a 701 and slats I prefer a steep, idle power, slipping approach for spot landings rather than dragging on with power. You can see the touchdown point much better, and adjust the amount of slip to hit that point. With the drag of those slats this is a very steep approach and will lose speed instantly on roundout, so better be rounding out at just the right height..... A bit alarming to see the ground looming up like that, but very effective to get in really short over obstacles, and I feel more comfortable than hanging on the prop - no chance of getting behind the power curve, or falling short due to sink, just release the slip and extend. The long wing VG is just a whole lot easier to manage this maneuver.
Yes Kevin, I know I've long been promising some video to demonstrate this. The decent footage that I had got recorded over with junk, and need to do it over again....
JohnG
Will the 701 long wing VG match the spot landings over obstacles, of a 701 with slats and a short wing?
Kevin
Gday Kevin,
JohnG
kmccune
