rd2(at)evenlink.com Guest
Posted: Sun Mar 12, 2006 6:33 am Post subject: CO kit / was B&C SSF-1 finally died |
Dan, this looks like a nice kit. Do you have any info about the CO
concentration threshold at which this kit triggers the alarm? Did any
calibration instructions come with the kit?
Rumen
_____________________Original message __________________________
(received from Dan Checkoway; Date: 07:13 PM 3/11/2006
-0800)
| Quote: | Which CO kit did you build? Where to get it? How much?
http://www.electronic-kits-and-projects.com/4055.htm
I did a group buy with a bunch of local RV builders, so we took advantage of
the 5+ discount and the int'l shipping ended up being essentially
negligible.
Soldered it up and tested it with my truck exhaust, acetone vapor, etc. It
seems to work as advertised, although I have to admit I haven't even
installed it in the plane yet! (doh!)
)_( Dan
RV-7 N714D
http://www.rvproject.com
dan(at)rvproject.com Guest
Posted: Sun Mar 12, 2006 9:55 am Post subject: CO kit / was B&C SSF-1 finally died |
| Quote: | Dan, this looks like a nice kit. Do you have any info about the CO
Rumen
No, it doesn't mention anything about the threshold, which is adjustable
anyway. A friend of mine who also bought one said at work he has access to
different gases in different concentrations and was going to run some tests.
I haven't heard from him.
To be honest, it looks more like a kid's educational kit than a robust
device for use in an airplane, but for me the price was right and it seemed
to serve the purpose. If it didn't end up working, I didn't throw much $$
away finding out.
Sorry I don't have more details for you.
)_( Dan
Posted: Sun Mar 12, 2006 11:56 am Post subject: CO kit / was B&C SSF-1 finally died |
Thanks.
The reason I asked is I've been looking for a reliable, safe, alarm device
and I like DIY projects.
Since CO has no smell I think I need something that indicates reliably CO
over a threshold under harmful levels. Also a test/calibration method
simple enough and a test frequency schedule.
Rumen
(received from Dan Checkoway; Date: 09:55 AM 3/12/2006
-0800)
Rumen
away finding out.
)_( Dan
BobsV35B(at)aol.com Guest
Posted: Sun Mar 12, 2006 3:22 pm Post subject: CO kit / was B&C SSF-1 finally died |
Good Evening Rumen,
This is going way off topic, but I thought I would mention it anyhow!
I believe having a Carbon Monoxide detector is a great idea, but you should
remember that one way to get rid of the CO danger is to operate on the lean
side of Peak Exhaust Gas Temperature. With a lean mixture, the CO level is so
low that there is no danger.
Consequently, if you do get a CO warning and you are operating on the rich
side, lean that hummer out!
Do Not Archive.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 3/12/2006 1:57:58 P.M. Central Standard Time,
rd2(at)evenlink.com writes:
Thanks.
Rumen
chaztuna(at)adelphia.net Guest
Posted: Sun Mar 12, 2006 4:04 pm Post subject: CO kit / was B&C SSF-1 finally died |
Rumen,
I did a group buy of these as well last year. I've built 3 of them. The sensitivity is adjustable. There is an adjustable potentiometer on the board. There is an LED for a visual warning as well as a relay. You can set the relay up to trigger an audio alarm, or any other alarm you want.
Charlie Kuss
---- rd2(at)evenlink.com wrote:
Rumen
-0800)
negligible.
)_( Dan
RV-7 N714D
frank.hinde(at)hp.com Guest
Posted: Mon Mar 13, 2006 7:41 am Post subject: CO kit / was B&C SSF-1 finally died |
Thanks, Bob.
Contacting you off-list on this.
Rumen
(received from BobsV35B(at)aol.com; Date: 06:21 PM 3/12/2006
EST)
Good Evening Rumen,
is so
Do Not Archive.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
klehman(at)albedo.net Guest
