Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sat Sep 06, 2008 11:52 am Post subject: Horizontal Stabilizer Setting |
Hi Folks;
I am about to install the horizontal stabilizer on my KF II. Can anybody advise which hole to use to set the initial incidence??
Thanks in advance
Ken
henrysfork1(at)msn.com Guest
Posted: Sat Sep 06, 2008 12:25 pm Post subject: Horizontal Stabilizer Setting |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I used the center hole. It seemed to work ok.
Dee Young
Model II
N345DY
Glenn Horne
Posted: Sat Sep 06, 2008 3:41 pm Post subject: Horizontal Stabilizer Setting |
TOP!
GLENN HORNE
Kitfox Model II
Tom Jones
Posted: Sat Sep 06, 2008 6:23 pm Post subject: Re: Horizontal Stabilizer Setting |
ken, the most efficient rigging for the horizontal stab is where you need to hold just a little forward pressure on the stick for level cruise. If you need to hold back pressure with the mount in the top hole, drop it to the next hole down. When you find the spot that requires slight forward pressure for level flight, trim the nose down with the flaps.
A well rigged kitfox is a joy to fly.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Sat Sep 06, 2008 7:48 pm Post subject: Horizontal Stabilizer Setting |
I checked my model II and it's set in the top hole, but I don't know how
it flys as it's not repaired yet . I suspect Tom Jones is right and you
may find you it could be different for your airplane.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Ken Potter wrote:
Hi Folks;
Thanks in advance
Ken
http://forums.matronics.com/viewtopic.php?p 2925#202925
_________________ Rex
N740GP - M2/582
Colorado |
Ken Potter
Posted: Sun Sep 07, 2008 3:47 am Post subject: Re: Horizontal Stabilizer Setting |
Thanks everyone;
Test flying will not be till late fall or early spring so I have installed it in the centre hole for now.
Cheers
Ken Potter
KF II, No. 483
Rotax 582 C Box
pwmac(at)sisna.com Guest
Posted: Sun Sep 07, 2008 7:16 am Post subject: Horizontal Stabilizer Setting |
Tip: Drill some extra holes in the fwd attach to allow for fine
tuning. They are tough to add after the build.
Paul
At 08:24 PM 9/6/2008, you wrote:
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 2984#202984
