kitfox555(at)sbcglobal.ne Guest
Posted: Mon Sep 15, 2008 6:07 pm Post subject: gsc three blade prop |
This is what GSC sent me what do you guys think ?
Jerry Evans
KitfoxII
Magalia Calif.
N582'er'
kitfox 555
--- On Mon, 9/15/08, GSC Systems (2004) Ltd. <info(at)ultralightprops.com> wrote:
| Quote: | From: GSC Systems (2004) Ltd. <info(at)ultralightprops.com>
Subject: RE: gsc three blade prop
To: kitfox555(at)sbcglobal.net
Date: Monday, September 15, 2008, 5:58 PM
Jerry,
If you have always torqued bolts to no more than 100 in/lbs, then you could mill down approximately 5-6 thou. from the hub faces to regain the gap. It would not be advisable to wrap the blade roots with any material.
Thank you,
Rick Peter
GSC Systems [2004] Ltd.
#8 - 2440B - 14th Avenue,
Vernon, BC, V1T 8C1
250-549-3772
From: jerry evans [mailto:kitfox555(at)sbcglobal.net]
Sent: September 13, 2008 1:27 PM
To: info(at)ultralightprops.com
Subject: gsc three blade prop
I have a 582 rotax and have about 20 hrs on it, it started to vibrate so I checked the pitch and one blade keeps moving after each flight I have always torqued it to 100IN but it seems that the gap is very small if any,What can I do , put the half on a lath to mill down a small amount or wrap the blades with something to get back some gap between the half's is there any thing I can do to stop the blades from changing pitch in flight? They are wood three blade GSC Please help me out of this problem Thanks Jerry
Jerry Evans
KitfoxII
Magalia Calif.
N582'er'
kitfox 555
| [quote][b]
