Dennis Johnson
Posted: Mon Mar 13, 2006 5:00 pm Post subject: Resistor Instead of Fusible Link? |
Greetings,
I've been planning to use fusible links as Bob suggests to protect skinny wires leading to warning lights. For example, I'll have a "Starter Engaged" warning light connected to the starter relay and need something to protect the 22 AWG wire that goes to the warning light.
However, since the warning light will be an LED, and since the LED requires a dropping resistor, can I use the dropping resistor instead of the fusible link? I would install the resistor at the same location I would have installed the fusible link.
The resistors I would use have solid wire leads on both ends. How would I connect it to a starter relay without encountering problems from the vibration work-hardening the solid lead and causing it to break? A couple of layer of heat shrink? Put it a few inches downstream of the relay and secure it to nearby wires?
Dennis Johnson
Legacy (nearly finished with my wire book)
nuckollsr(at)cox.net Guest
Posted: Mon Mar 13, 2006 8:01 pm Post subject: Resistor Instead of Fusible Link? |
At 04:52 PM 3/13/2006 -0800, you wrote:
<pinetownd(at)volcano.net>
Greetings,
| Quote: | The resistors I would use have solid wire leads on both ends. How would I
Good thinking. It's commonly done . . .
See:
http://www.aeroelectric.com/articles/In_Line_Resistor/In_Line_Resistor_1.jpg
http://www.aeroelectric.com/articles/In_Line_Resistor/In_Line_Resistor_2.jpg
http://www.aeroelectric.com/articles/In_Line_Resistor/In_Line_Resistor_3.jpg
http://www.aeroelectric.com/articles/In_Line_Resistor/In_Line_Resistor_4.jpg
http://www.aeroelectric.com/articles/In_Line_Resistor/In_Line_Resistor_5.jpg
http://www.aeroelectric.com/articles/In_Line_Resistor/In_Line_Resistor_6.jpg
Note that LEDs are relatively fragile devices with respect
to short reverse voltage transients. Suggest you add a 1N4001
in parallel with an LED that's connected directly to high
power, somewhat inductive gizmo like a starter motor.
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon Mar 13, 2006 8:03 pm Post subject: Resistor Instead of Fusible Link? |
In a message dated 03/13/2006 7:02:23 PM Central Standard Time,
pinetownd(at)volcano.net writes:
the fusible link.
| Quote: | >>
Not to say this won't work, but just for kix&gigglz, why not take the
resistor/wire/LED circuit you propose, rig it up to a fully charged battery, then
short across the LED to simulate the feed wire going to ground. This would be
one way to test what you propose. Please take appropriate measures to ensure
personal safety and let us know the results...
Proof is hidden somewhere deep in the depths of pudding...
Mark do not archive
PS- I have a starter engaged LED on my annunciator, but chose to feed it with
18 ga wire using a 22 ga fuselink at the starter contactor-
_________________ From The PossumWorks... |
Dennis Johnson
Posted: Tue Mar 14, 2006 3:38 pm Post subject: Re: Resistor Instead of Fusible Link? |
See:
Bob . . .[/quote]
Hi Bob,
Thanks for such a thorough reply! That's what I'll do, plus I'll add the rectifier diode as you showed.
Dennis Johnson
