		rubber314chicken
				 Posted: Mon Jun 23, 2008 12:04 pm    Post subject: best fuel economy |
				If you were to to choose a kit/plans based on the best fuel economy, what would you choose?  The KR-2S looks like it has the best at 30ish miles per gallon in cruise.  Are there any more fuel economic choices out there?
  |  | - The Matronics Homebuilt-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Homebuilt-List |
		nwolfe(at)stealthturtle.c Guest
				 Posted: Mon Jun 23, 2008 1:07 pm    Post subject: best fuel economy |
				The Cozy IV is pretty good and quick to boot.
 -Nate
 On Mon, Jun 23, 2008 at 4:04 PM, rubber314chicken <rubber314chicken(at)gmail.com (rubber314chicken(at)gmail.com)> wrote:
   	  | Quote: | 	 		  --> Homebuilt-List message posted by: "rubber314chicken" <rubber314chicken(at)gmail.com (rubber314chicken(at)gmail.com)>
  If you were to to choose a kit/plans based of the best fuel economy, what would you choose?  The KR-2S looks like it has the best at 30ish miles per gallon in cruise.  Are there any more fuel economic choices out there?
  http://forums.matronics.com/viewtopic.php?p=189404#189404
 Nathan Wolfe
 Building an Experimental Airplane
 http://www.stealthturtle.com  [quote][b]
		franz(at)lastfrontierheli Guest
				 Posted: Mon Jun 23, 2008 1:57 pm    Post subject: best fuel economy |
				There are many parameters that needs to be considered before a question like that can be answered. For instance: what would the application for the plane be, are ypou going to use for travel or recriation, how many seats do you need and so on and so fort,
  Franz
  On 23/06/08 2:04 PM, "Nathan Wolfe" <[url=nwolfe(at)stealthturtle.com]nwolfe(at)stealthturtle.com[/url]> wrote:
   	  | Quote: | 	 		  The Cozy IV is pretty good and quick to boot.
  -Nate
  On Mon, Jun 23, 2008 at 4:04 PM, rubber314chicken <[url=rubber314chicken(at)gmail.com]rubber314chicken(at)gmail.com[/url]> wrote:
   	  | Quote: | 	 		  --> Homebuilt-List message posted by: "rubber314chicken" <[url=rubber314chicken(at)gmail.com]rubber314chicken(at)gmail.com[/url]>
   Franz Fux
  Director of Operations
  Last Frontier Heliskiing
  TLH  Heliskiing
  Box 1118 Vernon, BC, V1T 6N4
  www.lastfrontierheli.com
  www.tlhheli.com
  Ph: 250 558-7980
  cell: 250 260-0433
		gregoryf.flyboy(at)comcas Guest
				 Posted: Mon Jun 23, 2008 2:57 pm    Post subject: best fuel economy |
				 	  | Quote: | 	 		  If you were to to choose a kit/plans based of the best fuel economy, what
 The Europa and the Long-EZ can compete easily with that number. The Europa
 uses either the Rotax 912,912s, or 914 engine combo's. With the 912, it will
 do 50mph in economy mode. Not sure which engine the Long-EZ's use.
				 Posted: Mon Jun 23, 2008 5:08 pm    Post subject: best fuel economy |
				Greg Fuchs (FB) wrote:
 Most of the Van's RV-x line will do close to 30 statute miles per gallon
 if you fly them at the lift/drag intersection, somewhere around 140 mph.
 They will do it even with the big engines. You never hear about it
 because most owners can't make themselves fly that slow when the plane
 will cruise at close to 200 (where they get 18-20 mpg if you're up at
 10-11k feet).
 They will probably cost a bit more to build than a KR, but have a lot
 more room, short/grass field capability & much stronger resale market if
 you ever have to part with one.
		mlas(at)cox.net Guest
				 Posted: Mon Jun 23, 2008 5:15 pm    Post subject: best fuel economy |
				Here are the Lancair Legacy numbers
 Low Speed
 nm/hr
 fuel rate
 fuel total
 rangenm
 range sm
 mpg nm
 mpg sm
 200
 8
 67
 1675.0
 1926.3
 25.0
 28.8
 Normal cruse
 225
 10.5
 67
 1435.7
 1651.1
 21.4
 24.6
 High Speed
 250
 18
 67
 930.6
 1070.1
 13.9
 16.0
		aerofabco(at)juno.com Guest
				 Posted: Mon Jun 23, 2008 7:23 pm    Post subject: best fuel economy |
				Yes, there are plenty of  choices that get far better mpg figures than
 "...30ish...":
   They are called =sailplanes=  and they get virtually infinite mpg.
   <sigh>  Sorry, I couldn't resist:   but seriously, the Moni
 self-launching
   (motor-glider)  is a case-in-point that sips fuel while the small KFM
 or
   similar engine is running for takeoff and initial climb, then burns
 nothing
   at all  ( infinite mpg )  while soaring cross-country with the engine
 turned off.
   It's one solution to the question, given that the question imposed no
 restraints
   such as "...more than 150-mph cruise speed with seating for  four
 275-lb. each
   adult males plus their golf clubs..."    If one wants to go flying with
 minimal fuel
   expenses, the motor-gliders deserve a closer look.
   ....and,  FWIW, the Rand-Robinson folks even proposed a motor-glider
 variant
   of  their KR-1....
   art
 On Mon, 23 Jun 2008 13:04:06 -0700 "rubber314chicken"
 <rubber314chicken(at)gmail.com> writes:
  choices out there?
 ____________________________________________________________
 Comfort your feet with a new pair of slippers. Click here!
 http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3lwW2vq0CYXkXlIXjdXLHX0yKNZ28p7lTZIoKwgVrb1amVTJ/
