Kit or Scratch?
BobCollins
PostPosted: Thu Oct 16, 2008 5:21 pm    Post subject: Kit or Scratch? Reply with quote
I have a question for everyone, but especially those of you like Chris
Lewis who are building from plans (scratch building).
What do you think the cost comparison is between the raw materials and
Zenith's kit? My workshop instructor felt that there might be little or
no savings over buying the kit. Considering my knowledge of how business
works, this might be true.
Again, for the scratch builders, where are you buying your metal? Are
you able to find it locally or do you have to order it from places such
are Aircraft Spruce or Wicks? Do the plans recommend the size and
quantity of raw stock to buy?
Third question. For those of you who have viewed it, what do you think
of the "Scratch Building Basics for Metal Aircraft" DVD from
HomebuiltHELP.com?
Bob Collins
Sunnyvale CA USA
CH750 (well, sitting here with a fine new 701/750 rudder)
John75142
PostPosted: Thu Oct 16, 2008 5:40 pm    Post subject: Kit or Scratch? Reply with quote
I personally have found all materials locally and by my best guess it should
cost about half of the kit price if not more. And with the fact that you are
going to screw up a few parts being able to make them over yourself even
adds up to more of a savings. That being said I am familiar with working
metal and have most of the equipment needed to cut and bend all the pieces
so it was not an option for me given a limited budget.
John (Scratch building 701)
Kaufman, Tx
John Short
bryanekholm
PostPosted: Fri Oct 17, 2008 4:12 am    Post subject: Re: Kit or Scratch? Reply with quote
For me I would say I will save about a quarter to a third of the cost of the airframe kit by building from plans. Of course I bought my aluminum about six or seven years ago. The prices were much lower back then. Many of the steel welded parts I have purchased from ZAC since I'm not a welder. I will be bending my own main gear leg (haven't done that yet, but the 8' aluminum bar I bought cost me $85 as opposed to $505 from ZAC). If you scratch build you will need to have access to a 6' bending brake for the longer parts and it's nice to have a smaller brake for the smaller parts.
Bryan Ekholm
Bryan Ekholm
John Bolding
PostPosted: Fri Oct 17, 2008 4:33 am    Post subject: Kit or Scratch? Reply with quote
A lot depends on if you have or don't mind buying the extra tools and how
close you are to materials sources for alum. I haven't priced alum lately
so can only comment on when I bought which was about 3 yrs ago. The "kit"
took me about 5 weeks of part time work to make and I saved about $7K plus
or minus a little. This is my 4 th homebuilt so have a full shop and all
the stuff to build it. Lots of guys say it doubles the time but I had all
the stuff built that comes in the kit in 5 weeks (still haven't bent the
gear yet) so that's what it added to my build time.
Another advantage is you read of parts that are ruined by the builder and
the time and expense it takes to replace, if you already have the form
blocks and material you can fab another from scrap material in the time it
takes for the kit builder to make out a check and walk it to the mailbox.
MOST of the tools needed are required either way, the driven rivets are
BEST driven with a rivet gun . I can't imagine not having compressed air but
a compressor can be bought used and resold (you won't sell it ) at the end
of the project to recoup if necessary.
Same for the welding equipment, you can farm those parts if you wish or buy
from Zenith.
It's really nice we have a choice.
John
randy(at)rjhebertassoc.co
PostPosted: Fri Oct 17, 2008 5:28 am    Post subject: Kit or Scratch? Reply with quote
Bob
For me it was more about how I spent the money than should I spend it.
I have found that buying only what I need for a particular phase allowed
me to get this far.
I am about to complete the rt wing, having completed the tail section
and left wing.
I think you will find a pride in building each component, as I have
found.
Yes, I had to build a shop that I did not have, and buy a lot of tools
The secondary benefit is that I am now able to tackle the honey-dos
around the house a lot better that before because of the accumulation of
tools and new knowledge.
I know the spending will increase as I get closer to the engine/panel
etc, but I still plan to phase these areas in.
I can truly say I would not have gotten this far without the Homebuilt
Help videos. I find that looking at the plans you don't know where to
start.
Following the path set out in the videos, and using the plans I can
build an airplane.
If you build form a kit, you still should invest in the videos.
Good luck deciding and building. This list has also been invaluable to
me personally. The guys here usually ask and answer questions I have or
will have and the knowledge speeds up my decisions and actions.
Randall J Hebert
Randall J Hebert & Associates, Inc
Consulting Engineers
Ph 337-261-1976 Fx 337-261-1977
Chris Lewis
PostPosted: Fri Oct 17, 2008 11:15 am    Post subject: Re: Kit or Scratch? Reply with quote
Bob - I'm a former toolbelt guy who's been flying a desk for 15+ years now. To say that I miss the pride in creating something from nearly nothing (or at least raw materials) is an understatement.
This basic need to create and my issues around size along with the new SP reg's made my decision simple (for me). It will certainly take longer and may or may not save a ton of $$, but it's been a great experience to date.
I did have to buy/make some tools, but there's a lot of help available there. I've ordered aluminum from Wick's to this point, but have had real shipping issues.
I was bolstered in my delusions by Chris Heintz's personal attention to my request for review and approval of my mods. I even travelled to the grand opening of Quality Sportsplanes in Cloverdale, just to meet him personally and deliver a small palm sized model of my plane that I made as a thank you. We spoke at length about the joys of scratch building and knowing that "I made this myself" at the end of the day. I plan to build a Corvair powerplant as well to keep the theme alive.
I have conversed with Mark from Can-Zac many times and have found him to be most helpful. I own the Scratch building and Sheet Metal 101 video's from Homebuilt Help and would highly recommend them. They are not Hollywood quality, rather homey and useful. Jon Croke has gone to a lot of effort to help demystify the process and many of his video's are worth owning.
The only wrinkle in my plans and approach was the actual arrival of the CH750. It is all of the things I was trying to achieve on my own and then some. I've shelved my project for now and am awaiting my set of 750 plans for review. I may choose to switch over to building the 750, or just take some of the high points and add them to my project.
I have the luxury of time. I'm in no hurry and likely never will be. I lead a busy life (like everyone) and am pleased to see the developments in the CH 7 series, the Corvair movement and the efforts from StolSpeed in continuing real-world experimenting with VG's.
For me, there's no other path. Each of you will need to weigh your own desires, skills and goals and go forth. I truly love that Zenith gives us all options to suit.
Chris in Seattle
750/ Zen-vair Semi-Scratch Builder
N750XT (reserved)
agibeaut
PostPosted: Fri Oct 17, 2008 12:05 pm    Post subject: Kit or Scratch? Reply with quote
This being my first attempt at building an aircraft with little or no metal experience I did not think I could handle scratch building in early 2007 when I decided to go forward with a CH 701. I also could not see buying all of the tools necessary to scratch build, and the added time was also an issue. I was actually a little intimidated by the thought of plans building and had nothing but respect for the people that had done it. It came down to time and money and the normal trade-offs of a busy life. So I went to the Rudder Class at Zenith and started buying components kits as I needed them. Zenith is absolutely top notch when it come to help for novice builders and I am glad I chose a 701.
So now, a year and four months later, I've ended up buying all of the tools including a brake, 3 air drills, an angle drill, various sheet metal hand tools, Olfa knives (note plural), a supply of 6061 T6 sheets in various thicknesses, and a dandy compressor which I will never sell. I have the wings, tail, rear fuselage, cabin, and firewall done and I'm not nearly as concerned with getting this project completed as fast as I once was. I spent the money to save the time, and now I don't care about the time. I look forward to the "escape" of building nearly everyday and I know I'm going to miss this when I have it done.
I bought the tools and the exta sheets of alum a little at a time as I screwed up small parts and was too embarrassed to admit it so I could quietly remake them. Fact is, that is again part of the fun. You are going to get into jams from time to time and it is great having the tools and extra aluminum around to figure out the solution and move on.
Would I do it the same way again? Not sure! But the next time I won't be so naive as to think it is all about the time and the money. Oh it is still about those two items, but I had them in the wrong order. I think I'll plans build the next one.
bobkat
PostPosted: Fri Oct 17, 2008 1:42 pm    Post subject: Kit or Scratch? Reply with quote
I had built a Starduster, or arther I finished a partly built one a few
years ago and enjoyed doing it. Then rebuilt a kitfox, then one day got the
itch to try something in metal. Maybe composite next???
I had some temporary health problems a few years ago and while I got my
medical back I wanted to build a low and slow sport pilot airplane to fly
from our grass strip behind the house.
So I was lucky to find a guy selling a never started kit for much less than
Zenith would have charged for a new one. So I called a couple of retired
buddies and off we went with a horse trailer to Oklahoma!
Now that I have 20 hours on it, I'm enjoying every second of it, more with
each flight if that's even possible! Once you find it handles a bit
different from anything I had flown before it turned out to be very docile
and really FUN aircraft!
No blazing speed, but that isn't what the 701 is all about! I still have
yet to hit 3 digits on the airspeed indicator even in a dive, but it reads
low by about 10 mph, not that it matters.....! No matter what it says I
won't get there any faster!
So if there is anyone out there getting discouraged, keep nibbling away at
it and you'll be done before you know it and you'll really have fun flying
it! Guaranteed!
I really respect you scratch builders out there. I also can really
recommend the Homebuilt Help Series of Videos, which unfortunately I didn't
find out till I was 80% done. They are invaluable and if I'd had them
earlier I'd saved myself several goof ups and many hours of head scratching.
larry(at)macsmachine.com
PostPosted: Fri Oct 17, 2008 5:16 pm    Post subject: Kit or Scratch? Reply with quote
Hi Bokat,
If you're possibly interested in composite, our chapter has a donated
Glasair RG for sale. Owner was T-boned on the highway and lost his medical.
The Glasair has over $100,000.00 materials in it, and is ready for the
engine. Here's nearly 200 mph and 24 mpg with retractible gear for an asking
of $50K OBO. I think it's a beautiful aircraft. Pictures on site see link,
*www.eaa75.com/Glassair.pdf*
few years ago and enjoyed doing it. Then rebuilt a kitfox, then one
day got the itch to try something in metal. Maybe composite next???
kmccune
PostPosted: Sat Oct 18, 2008 4:13 am    Post subject: Re: Kit or Scratch? Reply with quote
I figure the cost at about 1/3 , but the big factor is that you can buy a sheet or two at a time and your in business. That said, mine will cost more then my estimate as I am going to purchase all the welded parts and main gear ect... There is a material list at http://www.ch701.com/ and there is one in the Zenith builders site too. Add it up for your self. Or buy the plans and make yourself a Daves sheet metal brake and build a rudder. Add up the costs and get a rudder quote for the the rudder at Zenith builders site. I have scrapped one rudder tip, two rudder main spars( build the brake, you can not form this part) 3 stabilizer ribs, one elevator rib and one front stabilizer spar, so call the scrap 1/2 sheet of $80.00 per sheet material. Try to find a local source as shipping will eat you alive, compared to the material price, if ordered in small manageable "batches".
Ok now I see that I have written one long run on paragraph again, so I guess I'll go have another cup of coffee.... Shocked Smile
Kevin
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
ifly4fun2(at)sbcglobal.ne
PostPosted: Sun Oct 19, 2008 4:31 am    Post subject: Kit or Scratch? Reply with quote
Bob,
Depending on several variables, raw materials cost could be approximately 30-40% of the current 701 kit price. I'm in the Aviation Capital so I have no issues finding aircraft grade materials, but Yarde Metal online is a good resource if you need have it shipped in. No, disappointingly the plans do not include material quantites, this is left up to the builder to determine. If your debating of whether or not to scratchbuild, the DVD is priceless overview of what you could anticipate.
Art Olechowski
750 Plans/701 Rudder
--- On Thu, 10/16/08, Bob Collins <bobcollins42(at)gmail.com> wrote:
[quote]From: Bob Collins <bobcollins42(at)gmail.com>
Subject: Kit or Scratch?
Date: Thursday, October 16, 2008, 8:21 PM
[quote]--> Zenith701801-List message posted by: Bob Collins
of the "Scratch Building Basics for [quote][b]
PostPosted: Sun Oct 19, 2008 8:07 am    Post subject: Kit or Scratch? Reply with quote
Art and Bob
CH701.com under Builders Resources has a couple of good spreadsheets listing all or maybe 99.99% of the materials
It is user supplied.
Randall J Hebert
Bob,
PostPosted: Sun Oct 19, 2008 11:31 am    Post subject: Kit or Scratch? Reply with quote
Randall,
You absolutely correct, and I'm aware of them but they don't (currently) work for scratching the 750, only the 701. Ideally, Zenith should include a list of raw materials as part of the plans since they know exact quantities, of course you would have to add in waste and rework percentages of your own. Just seems weird that they don't list quantities since its already a known for them.
Art
--- On Sun, 10/19/08, Randall J. Hebert <randy(at)rjhebertassoc.com> wrote:
[quote]From: Randall J. Hebert <randy(at)rjhebertassoc.com>
Subject: RE: Kit or Scratch?
Date: Sunday, October 19, 2008, 11:06 AM
Art and Bob
Randall J Hebert
Bob,
PostPosted: Sun Oct 19, 2008 1:12 pm    Post subject: Kit or Scratch? Reply with quote
Sorry
I didn’t see you guys were talking 750
But Yes I agree A Bill of Materials should accompany the plans
Randall J Hebert
Randall,
keystone(at)gci.net
PostPosted: Mon Oct 20, 2008 7:29 am    Post subject: Kit or Scratch? Reply with quote
Bob
From my perspective the question is do you enjoy building airplanes or
flying more? I enjoyed building my plane but I really enjoy flying! I
suspect more kits are finished just because they are a lot less work.
Bill Wilcox
N801BW
Valdez, AK
405 hrs
A couple more hunting trips before I put in the preservation oil for the
winter.
blarson(at)meridianhouse.
PostPosted: Tue Oct 21, 2008 3:18 am    Post subject: Kit or Scratch? Reply with quote
The problems with material lists:
1. The efficiencies of various people in their "nesting" aptitude will
greatly effect the amount of material required. The amount of waste is
rather unpredictable in this regard.
2. If Zenith does specify a quantity people will jump on them because
they ordered short or long on their quantity which in turn costs the
builder money (didn't order enough and incurred additional shipping
costs or has to order too much and extra material they don't want/need).
I do agree there should be a list of materials with approximate
quantities with the stipulation that "your mileage may GREATLY vary."
Art Olechowski wrote:
Randall,
Art
--- On *Sun, 10/19/08, Randall J. Hebert /<randy(at)rjhebertassoc.com>/*
Art and Bob
Randall J Hebert
Bob,
rwehba(at)yahoo.com
PostPosted: Tue Oct 21, 2008 1:32 pm    Post subject: Kit or Scratch? Reply with quote
on the ch701.com site there is a pdf and dxf file that has a breakdown of the materials needed it is drawn onto the sheets as to how to cut for best use.
ronnie wehba
--- On Tue, 10/21/08, Brad Larson <blarson(at)meridianhouse.com> wrote:
Subject: Re: Kit or Scratch?
Date: Tuesday, October 21, 2008, 6:19 AM
--> Zenith701801-List message posted by: Brad Larson
will
Randall,
Art
Art and Bob
Randall J Hebert
Bob,
