msm_9949(at)yahoo.com Guest
Posted: Tue Oct 07, 2008 9:22 am Post subject: EGT probe was 582 Oil Reservoir |
Bob:
It's been awhile since I put mine together and, in my case, the "Y" was pre-drilled to accept the probes, but as I recall, the probes do reach all the way across the exhaust opening. Also, I did nothing to seal around the probes and there does not appear to be any significant exhaust leakage there. In any event, the system has always performed as advertised with this installation.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1
--- On Mon, 10/6/08, Bob Brennan <matronics(at)bob.brennan.name> wrote:
| Quote: | From: Bob Brennan <matronics(at)bob.brennan.name>
Subject: RE: 582 Oil Reservoir
Date: Monday, October 6, 2008, 9:03 AM
#yiv277797447 .hmmessage P { PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TOP:0px;} #yiv277797447 { FONT-SIZE:10pt;FONT-FAMILY:Tahoma;} I can picture it Jim thanks, although I'm not sure that "sence" makes sense
I've had my head under the cowl trying to picture it and from what everyone has said it does make sense, although the smallest probe I can find has a 1" tip and I imagine that would pretty much touch the bottom of the manifold. Also I would think that some manifold sealer goop of some sort would be a good idea around the hole?
Bob Brennan - N717GB 1991 UK Model 2 ELSA Kitfox
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jim_and_Lucy Chuk
Sent: 06 October 2008 12:03 am
Sorry if someone beat me to the answer, but picture a Y The holes are in the two upper arms of the Y. The probe goes through a hole in the hoseclamp, into the hole in the Y and the clamp is tightened arould that arm of the Y. Same thing on the other upper arm of the Y pipe. Hope that makes sence. If you saw it it would be obvious immediatly. Jim Chuk 4 building MN
| Quote: | Date: Sun, 5 Oct 2008 19:15:23 -0700
--> Kitfox-List message posted by: Guy Buchanan <bnn(at)nethere.com>
At 06:46 PM 10/5/2008, you wrote:
>If you use the hoseclamp style EGT probes, all you have to do is
>drill two 3/16" holes in the Y pipe.
Yes, drilling the holes is easy. I can't picture the clamp,
though. How'd you do that?
Guy Buchanan
San Diego, CA
See how Windows Mobile brings your life together—at home20093182mrt/direct/01/' target='_new'>See Now | Quote: |
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
arget=_blank rel=nofollow>http://www.matronics.com/Navigator?Kitfox-List
