roncarolnikko(at)hotmail. Guest
Posted: Thu Feb 02, 2006 8:58 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
I need to preserve my ribs befor covering and was wondering what has been
used by some who have gone before me. My manual says varnish in the
materials required section, but says polyurethane varnish in the chapter.
In the store I find Minwax polyurethane for indoor use and Minwax Helmsman
urethane for outdoor use. Neither say varnish anywhere and neither mention
spraying them. Do I need to find a bigger store? Can I spray these?
Sheesh! not a chemist Ron Nb Ore
vadert(at)telusplanet.net Guest
Posted: Thu Feb 02, 2006 9:35 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
Ron
I used a clear epoxy varnish. You are protecting the wood from moisture
entering it. It may be prudent to use something sandable and lightly sand
before covering so that the fabric adheres better to it. I think it is
important to pay special attention to the trailing edge nooks and crannys of
the ribs where moisture will gather. Your wings will have drain grommets
where air (moist or otherwise) will enter and exit depending on weather
conditions and leave moisture (humidity) inside the wing. The trailing edge
(lowest point) is where that moisture will pool as the aircraft sits.
Tim Vader
Ceashman(at)aol.com Guest
Posted: Fri Feb 03, 2006 3:54 am Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
| Quote: | >I need to preserve my ribs before covering and was wondering what has been
Hello Ron.
It is important to varnish the wood bits to keep moisture and decay out.
When varnishing, brush is better than spray because of all the tight corners,
90 degree angles and things the spray will just bounce back. Slop lots on to
penetrate the wood but avoid flooding and runs too much. Take your time and
enjoy, it is a no brainer but requires patience to make sure all angles are
covered.
When dry use a soft rubber sanding block and sand the areas that fabric will
contact. This smoothes any dirt or any wood fibers that spring out. If it
feels rough, it will look rough under the fabric. When lightly sanding, you break
through. re-coat these areas.
Important!!! Use the epoxy varnish that was supplied with the kit (Polyfiber)
and do not use anything from the hardware store.
If you look at the Polyfiber instruction manual (I think) The boat Spar
varnishes or polyurethane varnishes will not hold up to MEK or the Polybrush that
you will use to stick the fabric down with. It will soften and start to break
down the so called Spar and polyurethane varnishes and the tensile and peel
strength will be much lower.
There are a number of people on this list you can get the Polyfiber Epoxy
varnish from, or from Aircraft Spruce.
Do not use anything but this stuff. One day when flying along and going
through some bouncy sky, you look across the lower wings and see the slight
billowing of the fabric and then you craft drops again. You will think to yourself
"man, am I glad I used the correct epoxy and I am glad I stitched the wings" Not
only that, rib stitching looks very cool.
Happy brushing. Eric.
dan(at)azshowersolutions. Guest
Posted: Fri Feb 03, 2006 6:02 am Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
Hi Ron,
I had the same question a while back and I went to John McBean w/ the question. John's direction made sense...He said if I want to be ensured there won't be a problem in compatibility (chemically) with covering materials, I should go with proven varnish. I was directed to use EV-400 Epoxy Varnish which is a two part epoxy and comes in a kit you can get from Aircraft Spruce.
Hope that helps,
Dan B
Mesa, AZ
rkstevens(at)verizon.net Guest
Posted: Fri Feb 03, 2006 7:02 am Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
It's ** important ** to use an epoxy varnish (2 part epoxy - as sold by PolyFiber for example). Otherwise, the MEK in the fabric finishing steps will melt right through "standard" varnishes. The Poly Fiber finishing systems specify which varnishes are acceptable.
The best solution is to use an epoxy varnish - it's a little more expensive, but WAY better.
Ron
| Quote: | From: Tim Vader <vadert(at)telusplanet.net>
Date: Thu Feb 02 23:33:04 CST 2006
Subject: Re: Ribs: Varnish vs Urethane vs Polyurethane
Ron
Tim Vader
ddsyverson(at)comcast.net Guest
Posted: Fri Feb 03, 2006 11:07 am Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
Ron,
This is pretty straightforward. If you do not want problems, the decision is
easy.
Use only products which are known to be compatible.
If you are using the polyfiber covering, this means use the polyfiber epoxy
primer for any metal or fiberglass, use the polyfiber epoxy varnish for any
wood, use the chemicals for the fabric recommended by the fabric manufacturer
- if polyfiber - use polytack, polybrush and polyspray. When you are ready
for a top coat, use polytone or aerothane.
I am not a polyfiber sales rep, I don't have any particular feelings that one
covering system is necessarily better than another; but I know you need to
stick to the items which are known to be compatible if you want to avoid
problems.
Methyl Ethyl Ketone, which is used as a solvent in a lot of Polyfiber's
products, will pretty much make lutefisk out of anything underneath which is
not compatible and that may very well include minwax.
Sincerely,
Dave S (Chemist and autobody guy + model 7 trigear)
On Thursday 02 February 2006 10:54 pm, ron schick wrote:
Lynn Matteson
Posted: Fri Feb 03, 2006 1:27 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
Dave-
lutefisk?
Lynn
On Friday, February 3, 2006, at 01:57 PM, D& D Syverson wrote:
<ddsyverson(at)comcast.net>
which is
Sincerely,
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Michel
Posted: Fri Feb 03, 2006 2:20 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
On Feb 3, 2006, at 10:25 PM, Lynn Matteson wrote:
Lutefisk is Norwegian cod marinated in caustic soda. It becomes a jelly
mass that tastes nothing. Of course, you have to wash it a lot to
remove the caustic soda and it is served with bacon, beans and ... a
lot of aquavit, which is a strong alcohol made from potatoes.
Lutefisk is a traditional dish mostly eaten during Christmas time. Some
people nearly makes it a cult. It doesn't taste bad, it tastes ...
nothing.
Its origin is said to come from the big fire of the town of Bergen, a
few centuries ago. Bergen was the hanseatic center where ships came all
over Europe to buy stock-fish, the Norwegian dried cod. During the
fire, many warehouses on the quays were burnt down, with the fish still
inside. Later, poor people from the town, came to salvage what they
could from the ruins. But wood ashes and water was very basic and the
fish became jelly-like, pretty much the way it is done now with caustic
soda.
.. now, aren't we off-topic?
Michel
aldaniels(at)fmtc.com Guest
Posted: Fri Feb 03, 2006 4:03 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
I have sealed the wood with a good spray coat of polybrush. That way
everything is compatible. It seems to hold up better that the varnish.
Cost is about the same.
flier(at)sbcglobal.net Guest
Posted: Fri Feb 03, 2006 5:59 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
Polybrush won't seal wood. Polybrush is a structural adhesive only for
fabric. Epoxy varnish is the only recommended / approved wood sealer for
the Stits Polyfiber process.
Posted: Fri Feb 03, 2006 7:48 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
It might be, but wood I treated with Polyfiber epoxy varnish when left
in a harsh environment for several years went to heck and the stuff
sprayed with polybrush stayed like new. What I did on my plane that was
destine for a harsh environment was brush epoxy varnish and then when
dry spray everything on the wing before covering with polybrush. It
sealed everything very well. Rivets and metal structural joints now can
not hold moisture as they are sealed. It is the same vinyl base as the
polytone paint.
Posted: Sat Feb 04, 2006 12:31 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
I misunderstood Alan. Sorry. The only issue with Polybrush is that it
doesn't adhere well to things other than fabric and itself. If sprayed
thick enough over hard surfaces you can peel it like a film from the
surface. My understanding is that it was formulated to fill weave, provide
bulk/level, and act as a base for the other coatings (MEK based) in the
system. Properly applied epoxy primer & epoxy varnish are the best ways to
go for weather proofing.
Ted
Posted: Sat Feb 04, 2006 12:41 pm Post subject: Ribs: Varnish vs Urethane vs Polyurethane |
-->It might be, but wood I treated with Polyfiber epoxy varnish when left
-->in a harsh environment for several years went to heck and the stuff
-->sprayed with polybrush stayed like new.
Hi Alan.
I think you are correct by saying an epoxy varnish when left in a harsh
environment goes to heck.
2 component epoxy paints do not like sunlight, ultra violet will break down
the paint structure. Normally you will start to notice powdering (chalky).
Then later the paint film will start to show fine cracks. After that water /
moisture creeps through the micro cracks and the wood absorbs this like a wick.
Not long before the epoxy varnish starts crumbling off the rotting wood.
But I think if the wood has adequate film thickness of epoxy and never left
exposed to sun, it should be a sound system.
Eric.
jlfernan
Posted: Tue Oct 07, 2008 6:08 pm Post subject: Re: Ribs: Varnish vs Urethane vs Polyurethane |
I used two part epoxy varnish, very tedious. How many coats is recommended for wing ribs?
_________________ Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/ |
