sidsel.svein(at)oslo.onli Guest
Posted: Tue Oct 21, 2008 10:38 pm Post subject: Aileron hinge wear |
On the two Europa XS's in Norway with more than 20 hours flying time, the outer hinge on both ailerons on both aircraft has developed noticeable wear. When the ailerons were mounted, no play was noticed - not-perfect alignment of the two hinges removed the play that exists in these MS-hinges even when new. The ailerons were carefully balanced after filling and painting, as per the BM.
No wear is noticed on the inner aileron hinges, nor on the rudder or trim tab hinges.
We have both monitored this carefully, without discovering any increased play over the roughly 50 + hours flown since first discovering this. However, this does not rule out that wear may continue at a low rate.
The outer hinge is fitted a fair distance from the tip. Even with tight outer hinge, the tip may be moved easily up or down without applying much force due to the flexibility of the aileron's structure.
Could the cause of this be small vibrations in the outer, unsupported part of the aileron when activating the aileron (i.e. not streamlined aft of the wing)?
Even if the outer hinges were tight, the flexibility "does not look right". I have not found any other aircraft design at my local field where the ailerons flex like this.
I have now fitted an additional, third hinge on each aileron, at the tip and of the same type and length as the original outer hinge (which I have left in place).
Anyone else with similar experience?
Svein
LN-SKJ
ward.t(at)xtra.co.nz Guest
Posted: Tue Oct 21, 2008 11:17 pm Post subject: Aileron hinge wear |
Svein,
Interesting to hear you concern. When I was building my 'Classic' about 9 years ago now I was with Kim Prout
in LA, USA looking at his finished aircraft. His father was there also, retired aerodynamicist with McDonnell Douglas, and
his comment regarding the aileron was there was a definite need for an extra middle hinge located slightly closer to the inner hinge.
I incorporated this straight away and there has been no flexibility you talk of, nor wear.
So your additional third hinge is needed and should solve your problem.
Cheers,
Tim Ward
12 Waiwetu Street
Fendalton,
Christchurch
NEW ZEALAND
PH 0064 3 3515166
MOB 021 0640221
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
lgds(at)post6.tele.dk Guest
Posted: Wed Oct 22, 2008 5:36 am Post subject: Aileron hinge wear |
Hi Svein
You take out the hinge-pin, form it as an "S" (app. 20 deg. on each bend), and tap it careful back in the hinge - after that you have solved the problem.
Regards Gert
OY-GDS
Den 22/10/2008 kl. 08.38 skrev Sidsel & Svein Johnsen:
Quote: | On the two Europa XS's in Norway with more than 20 hours flying time, the outer hinge on both ailerons on both aircraft has developed noticeable wear. When the ailerons were mounted, no play was noticed - not-perfect alignment of the two hinges removed the play that exists in these MS-hinges even when new. The ailerons were carefully balanced after filling and painting, as per the BM.
Svein
LN-SKJ
Posted: Wed Oct 22, 2008 6:28 am Post subject: Aileron hinge wear |
Hi! Gert
The most simple and lightest way!
Except close inspection should prevail to identify any actual oval holes later in life before the Aileron departs !
Bob Harrison
Do not archive.
Posted: Wed Oct 22, 2008 7:05 am Post subject: Aileron hinge wear |
Gert,
Thanks, but isn't that like taking paracetamol to reduce the fever without curing the illness?
Best regards,
Svein
Posted: Wed Oct 22, 2008 7:15 am Post subject: Aileron hinge wear |
Correct.A fix for that is to mount teflon-covered pins, but that is hell of a job ..
/Gert
OY-GDS
Den 22/10/2008 kl. 16.27 skrev Robert C Harrison:
Bob Harrison
Posted: Wed Oct 22, 2008 7:48 am Post subject: Aileron hinge wear |
No, because the wear comes due to vibrations - and that problem is fixed with the "S" thing./Gert
OY-GDS
Den 22/10/2008 kl. 17.02 skrev Sidsel & Svein Johnsen:
Best regards,
Svein
kevann(at)gotsky.com Guest
Posted: Wed Oct 22, 2008 7:51 am Post subject: Aileron hinge wear |
I thought installing stainless steel welding rod covered with teflon was
not too difficult, and my ailerons have a smooth, low friction feel.
Thanks Terry and Dave for the lead on that!
Kevin, back from summer work in AK and ready to resume flight testing N211KA
Lisbet og Gert Dalgaard wrote:
job ...
/Gert
OY-GDS
> Hi! Gert
> Regards
> Bob Harrison
s(at)vestuti.orangehome.c Guest
Posted: Wed Oct 22, 2008 11:33 am Post subject: Aileron hinge wear |
I'm fairly certain that you can buy over size hinge wire, i'll see if i
can find it listed and post back,
steve #573
Visit - www.EuropaOwners.org
air.guerner(at)orange.fr Guest
Posted: Wed Oct 22, 2008 11:43 am Post subject: Aileron hinge wear |
Svein,
My aircraft has flown 620 hours and yes there is some play due to hinge wear on ailerons and trim tabs. I know some other Europas with less than 200 hours which have developped the same problem.
I am not too much concerned about the play due to aileron hinge wear because in flight the load is causing both the wing and the aileron to flex and therefore the play is annihilated. You can (at least partially) reproduce this on the ground: just lift the wingtip upwards and move the aileron.
However I am concerned about the play in the trim tab hinges as it cumulates with the play which has developped at the fork connecting the T bar to the bellcrank TS03. Any suggestion (other than replacing all those parts every 100 hours) would be welcome.
Remi Guerner
F-PGKL
""On the two Europa XS's in Norway with more than 20 hours flying time,
trim tab hinges.
aft of the wing)?
have left in place)."""
Posted: Wed Oct 22, 2008 12:39 pm Post subject: Aileron hinge wear |
solved the problem.
Regards Gert
OY-GDS
This used to happen with the EZs. Some aircraft had their ailerons
"buzz" vibrate within the boundary layer. Putting a Flettner strip on
cured it but most of them fixed it by using a Teflon tube same OD as the
original hinge wire and filling that with a stainless hinge pin. Andy
Draper did research it but had trouble fining the right wire.
You could try emailing Gary Hall,
http://www.uslan.com/hinge-kit.html
AFAIK he still sells the kits.
Bill Theeringer used to do kits too,
The teflon sleeving is 14 gauge electrical, has an OD of 0.125, a wall
thickness of 0.010, an ID of 0.105,
and uses a 0.094 302 SS welding rod pin. This results in a 0.011 slop
around the pin. I recomend cutting the teflon at each hinge juncture so
the teflon is captivated and rotates aroind the pin. Mine has over 1000
hours on it and shows no sign of wear. You can put a warp in the pin to
eliminate the slight slop, but I think this will result in pressure
points that will facilitate wear. My personal opinion only.
Graham
Posted: Wed Oct 22, 2008 1:09 pm Post subject: Aileron hinge wear |
Thank you very much, Graham - I always appreciate your views and
suggestions.
For now, I will closely monitor the new third hinges (as well as all the
others, of course!) and see whether the slop appears also on these.
Best regards,
Svein
Posted: Wed Oct 22, 2008 8:17 pm Post subject: Aileron hinge wear |
Taht is not the way to go.
You have to bend the wire as an "S" and tap it back in the hinge.
/GDS
OY-GDS
Den 22/10/2008 kl. 21.30 skrev steve v:
Quote: | I'm fairly certain that you can buy over size hinge wire, i'll see
if i
steve #573
jan_de_jong(at)casema.nl Guest
Posted: Thu Oct 23, 2008 5:05 am Post subject: Aileron hinge wear |
Email address of Gary Hall does not work.
From the Cozy list archive I understand that the parts can be procured
from McMasterCarr:
teflon sleeve: 5335K17, ID 0.066" (1.6764 mm), wall 0.012", OD 0.090"
(2.286 mm), $2.30 per 10 feet
pin: 7972A261, 1/16" (1.5875 mm), $17.60 forr 32 lengths of 3 feet
McMasterCarr does not ship overseas anymore so a US builder might
intermediate.
The diameters are smaller than the ones you mention Graham, but more
likely to be correct?
Could it be that you have larger hinges than MS20001?
I measure hinge ID of MS20001 at about 1.8 or 1.9 mm, regular pin OD at
about 1.5 or 1.6 mm.
Inserting the teflon sleeve proposed above will be a stretch already.
A question also arises concerning the pin proposed above - diameter
seems rather similar to that of the regular pin.
Jan de Jong
Graham Singleton wrote:
Quote: |
<grahamsingleton(at)btinternet.com>
> Hi Svein
> solved the problem.
> Regards Gert
> OY-GDS
the original hinge wire and filling that with a stainless hinge pin.
Andy Draper did research it but had trouble fining the right wire.
1000 hours on it and shows no sign of wear. You can put a warp in the
pin to
Graham
terrys(at)cisco.com Guest
Posted: Mon Nov 03, 2008 9:51 am Post subject: Aileron hinge wear |
We added the third hinge, per Kim Prout's suggestion, and installed teflon tubing on our hinge pins, as described in the following URL. With over 600 hours now on the plane, we have had no problems with the aileron hinges. Still tight hinges and no need to lube. We also did this mod recently on our motor glider wings, which was not that difficult, once you get the hang of if.
http://terryseaver.home.comcast.net/~terryseaver/N135TD_mods.htm#Teflon_sleeving_for_hinge_pins
regards,
Terry Seaver
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Lisbet og Gert Dalgaard
Sent: Wednesday, October 22, 2008 8:13 AM
Subject: Re: Aileron hinge wear
Correct. A fix for that is to mount teflon-covered pins, but that is hell of a job ..
/Gert
OY-GDS
[quote] Hi! Gert
Bob Harrison
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
