jeffrey_davidson(at)earth Guest
Posted: Mon Oct 27, 2008 8:45 am Post subject: Dynon EFIS & EMS power on the main bus |
Background: I tried to start my Jabiru 3300A yesterday. It didn't start because of a lack of fuel. I can address that. At the same time, an electrical system question has come up. The battery is a 2-3 year old 17 Amp Hour motorcycle battery. It was charged up and eventually spun the engine fast enough to start under normal circumstances in my opinion. I intend to replace it soon. The ship's wiring diagram is a combination of Jabiru's design from their installation manual augmented with Aeroconnection techniques like the forest of ground tabs. As such, with the Permanent Magnet alternator, I followed Jabiru's advice that Over Voltage protection is not needed.
Question: My question here is about the wiring of the Dynon EMS and EFIS to the main bus. They are powered up when the Master Switch grounds the Battery Contactor. The starter contactor is downstream of the battery contactor. When the starter is engaged by grounding the starter contactor with the ignition switch, both Dynons lost ship's power and came up on the backup battery. When we had tried this several times, the Dynon backup battery was exhausted and the Dynons simply went off. Again, the engine never started so all this was happening while the starter was engaged. My question is whether or not the Dynons should be moved to the Avionics bus. Yes, I have an Avionics Master and understand the concern about it. The functional problem is that the tachometer and oil pressure are displayed on the EMS and nowhere else. In the certified planes with glass panels that I'm familiar with, the glass panels are similarly connected to the Master Switch and stay on when the engine is started. I need to be able to check oil pressure as soon as the engine starts.
Thanks for any light you can shed on this. Next time, I'll move the fuel selector from the Off position!
Jeff Davidson (still an electrical newbie)
CH601-HD w/Jabiru3300A
nuckolls.bob(at)cox.net Guest
Posted: Tue Oct 28, 2008 7:18 am Post subject: Dynon EFIS & EMS power on the main bus |
| Quote: | Question: My question here is about the wiring of the Dynon EMS and EFIS
the Master Switch and stay on when the e!
the engine starts.
The spirit and intent of avionics master switch
was to "protect sensitive avionics from hazardous
spikes generated during engine cranking."
In years since, it has been discovered that while
there was significant brown-out during the first
few milliseconds of starter operation similar to
that shown here:
http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1_2.gif
there were no high-voltage excursions that could
not be easily handled by simple components in the
potential victim's power input conditioning.
Further, the industry tapped a huge experience base
by forming RTCA and inviting all interested parties
in aviation to participate in quantifying and documenting
the magnitude and type of stresses a piece of avionics
should shrug off.
Based on our current knowledge and skill in crafting
airplanes and their accessories, there is no need
for an avionics master switch to "protect" anything.
I believe you stated that all batteries involved in
your test were of questionable condition either by
reason of age or state of charge. I'll suggest
then that what you experienced was not worthy
of generating concerns. You need to repeat the
experiment with a known-good ship's battery and
fully charged stand-by batteries.
It's doubtful that anything was damaged. Everything
you observed appears to be the byproduct of soggy
batteries.
Gig Giacona
Posted: Wed Oct 29, 2008 8:07 am Post subject: Re: Dynon EFIS & EMS power on the main bus |
| jeffrey_davidson(at)earth wrote: |
CH601-HD w/Jabiru3300A |
I'm not going to address the whole avionics master switch issue. What concerns me is what sounds like a limited life on the Dynon internal battery.
I've heard stories of people getting them, taking them out of the box or testing them during the building process and then not turning them off properly and when the plane's power is disconnected they think there is a power outage and just drain the internal battery.
601XL Under Construction
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Oct 29, 2008 9:23 am Post subject: Re: Dynon EFIS & EMS power on the main bus |
Yeah, I wonder if your Dynon battery was fully charged prior to this exercise. On a typical Jabiru start with a charged main battery, my Dynon D180 does not even see low enough main voltage to go on the internal battery. This is mainly due to the rapidity with which the Jabiru normally starts. Now that it is cold, and I did not richen up my idle mixture screw, it took me about 6 cranks to get started the other day. Towards the end, my Dynon told me that it was going on internal battery during the cranks. Even without an internal battery, Dynon emphatically says that it is no problem to have it hooked live to the main bus during cranking.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
longg(at)pjm.com Guest
Posted: Wed Oct 29, 2008 12:14 pm Post subject: Dynon EFIS & EMS power on the main bus |
My Dynon cable has 3 power leads which I assume is done in an effort to
alleviate this issue. Cable is from http://approachfaststack.com/
1. Main bus (DC primary power switch)
2. Essential bus (or alternate backup source)
3. Battery bus (or always on connection)
I have not experienced this behavior. If I start the Dynon while sitting
with the power off, I get the message, but If I add ship power I do not
get another message that it is on ship power. By pressing any button
then Next->Next->Info you can monitor the battery charge and the ships
battery level.
Did you connect the always on lead to your battery bus?
Posted: Thu Oct 30, 2008 6:31 am Post subject: Dynon EFIS & EMS power on the main bus |
I USE THE DIGEST VERSION OF THE LIST SO I’LL RESPON EN MASS. THE CAPITALS ARE NOT SHOUTING, JUST SO YOU CAN EASILY FIND MY RESPONSES. THANKS TO EVERYONE FOR THEIR INPUT.
Jeff
Gig wrote:
“I'm not going to address the whole avionics master switch issue. What concerns me is what sounds like a limited life on the Dynon internal battery. I've ….. just drain the internal battery.” NOT THE SITUATION HERE. THE DYNONS ARE FINE.
Dave wrote:
“Yeah, I wonder if your Dynon battery was fully charged prior to this exercise. On a typical Jabiru start ……., Dynon emphatically says that it is no problem to have it hooked live to the main bus during cranking.” THE DYNON BATTERY WAS NOT FULLY CHARGED.
Longg wrote:
“My Dynon cable has 3 power leads which I assume is done in an effort to alleviate this issue. Cable is …….. Did you connect the always on lead to your battery bus? THE DYNON KEEP ALIVE IS NOT CONNECTED SINCE I’M JUST FINISHING BUILDING AND NOT FLYING REGULARLY. THE MAIN IS ALSO NOT ON A LOT SO THE DYNON BATTERY IS ONLY CHARGING SPORADICALLY.
Bob Wrote:
“You need to repeat the experiment with a known-good ship's battery and fully charged stand-by batteries. It's doubtful that anything was damaged. Everything you observed appears to be the byproduct.” SOUND ADVICE. WITH A LITTLE FUEL I EXPECT IT TO RUN!
