olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Mon Nov 10, 2008 1:22 pm Post subject: Grounding the fuel tank |
If you remember, I installed a custom made aluminum tank this year in the Firestar. I set it on the tray with the piece of rubber underneath it just like the plastic tanks use. Then since I didn't get mounting tabs on the tank (mistake by builder) I had to strap the tank down with nylon straps.
Well it turns out my tank was not electrically attached to my airframe so even though I static ground the airframe when fueling up I wasn't grounding the tank itself. I got lucky that I didn't get a spark.
I fixed it yesterday.
Just something else to think about.
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
