longg(at)pjm.com Guest
Posted: Fri Nov 07, 2008 8:34 am Post subject: Need 1,2 & 3 amp fuses |
Does anyone know of a place to purchase 1,2 & 3 amp fuses on the street?
I've tried a number of auto stores, Walmart etc, but cannot find
anything below 5 amp.
Glenn
Posted: Fri Nov 07, 2008 8:41 am Post subject: Need 1,2 & 3 amp fuses |
longg(at)pjm.com wrote:
Glenn
If you're talking about the old 1/4x 1 1/4 inch glass fuses, try an
electronics supply house. Blade type, you might have to resort to mail
order.
harley(at)AgelessWings.co Guest
Posted: Fri Nov 07, 2008 8:49 am Post subject: Need 1,2 & 3 amp fuses |
Not sure whether you want the newer blade fuses, or the old standard tubular type, but Radio shack carries them both. Just checked online and they do indeed have them both from 1 amp and up.
Harley
longg(at)pjm.com (longg(at)pjm.com) wrote: [quote] | Quote: | --> AeroElectric-List message posted by: <longg(at)pjm.com> (longg(at)pjm.com)
Glenn
Agelesswings certifies that no virus is in this incoming message.
Checked by AVG - http://www.avg.com
| [b]
mprather(at)spro.net Guest
Posted: Fri Nov 07, 2008 9:02 am Post subject: Need 1,2 & 3 amp fuses |
What size wire requires a fuse less than 5A? Or is this for another
application?
Matt-
Glenn
nuckolls.bob(at)cox.net Guest
Posted: Fri Nov 07, 2008 9:22 am Post subject: Need 1,2 & 3 amp fuses |
At 09:59 AM 11/7/2008 -0700, you wrote:
application?
Matt-
5A is certainly adequate for protection of 22AWG wire
which is the smallest practical feeder that should
be tied to a bus.
Having said that, it's useful to drop to still lower
protection levels to extend protection to the interior
of an appliance. This goes beyond the simple idea
of protecting the airframe. The smaller sizes are
not in common distribution. I used to stock 1, 2 and
3A sizes. B&C still does at:
http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?27X358218#S889-1
You won't find them in auto parts stores but lots
of folks offer them on the 'net. Do a Google on
"ATC-1". "ATC-2" etc.
( -Thomas Paine 1776- )
rv8builder(at)earthlink.n Guest
Posted: Fri Nov 07, 2008 9:28 am Post subject: Need 1,2 & 3 amp fuses |
B & C Electic has the blade type fuses in amp ratings below 5 amps
Dale
Posted: Fri Nov 07, 2008 11:04 am Post subject: Need 1,2 & 3 amp fuses |
Thanks for the suggestions. I am looking for the ATC blade type. The key term is "on the street". I need them tomorrow. I'll try the Radio Shanty.
Posted: Fri Nov 07, 2008 11:14 am Post subject: Need 1,2 & 3 amp fuses |
Matt,
You must have one of those 48' Bonanzas Many pieces of modern
equipment are now running well below 5 amps. My strobes, efis panels,
nav lights, trim, some radios, gauges, led lights and so on all run in
the 1-3 amp range. Pretty soon these things will run on batteries and
well just place a solar panel on the wind screen and fly above the
clouds.
Glenn
sportav8r(at)gmail.com Guest
Posted: Fri Nov 07, 2008 11:33 am Post subject: Need 1,2 & 3 amp fuses |
IIRC, fuses are sized to protect the wire, not the device. Where are you finding wire gauges light enough to need 1, 2, or 3 A protection? I've never encountered wire this small in experimental aviation except possibly a MAC trim servo, and for some reason never fused those wires. Minds that need examining want to know...
-Bill B
On Fri, Nov 7, 2008 at 2:12 PM, <longg(at)pjm.com (longg(at)pjm.com)> wrote:
[quote] --> AeroElectric-List message posted by: <longg(at)pjm.com (longg(at)pjm.com)>
Matt,
clouds.
Glenn
Posted: Fri Nov 07, 2008 12:10 pm Post subject: Need 1,2 & 3 amp fuses |
I am not an EE, as a matter of fact I’m a Civil Eng, but it seems to me that although fuses are designed to protect the wire, the current (which determines the fuse Amp) that runs through the wire depends on the device it serves.
For example, when installing the GPSx96 in the panel the instructions call for a 1A fuse or CB, and the AOA Cpu from Proprietary (now AFS) calls for 4A, and Flightcom 403 intercom call for AWG 20 or 22 wire and 1A breaker/fuse.
Am I missing something?
Carlos
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Boyd
Sent: sexta-feira, 7 de Novembro de 2008 19:30
Subject: Re: AeroElectric-List: Need 1,2 & 3 amp fuses
-Bill B
Matt,
clouds.
Glenn
Posted: Fri Nov 07, 2008 5:20 pm Post subject: Need 1,2 & 3 amp fuses |
Hi Glen,
I just purchased 2 Amp fuses from Home Depot, the electrical parts
department.
Glenn
Posted: Fri Nov 07, 2008 8:22 pm Post subject: Need 1,2 & 3 amp fuses |
At 08:08 PM 11/7/2008 +0000, you wrote:
| Quote: | Bill
I am not an EE, as a matter of fact I m a Civil Eng, but it seems to me
it serves.
It's a matter of perspective. Folks who sell you an
electro-whizzy would appreciate it if you did not
power their 100 milliampere device with a 14AWG
wire and 15A breaker. The flight safety guys wouldn't
care, their job is to see that faults on the feeder
don't unnecessarily increase risk to the airframe.
But if the electro-whizzy shorts a 15-cent capacitor
and burns a trace on a board, the repairs may be
costly if not impossible. As a practical matter, you
(as system integrator, owner and operator) can choose
to run 14AWG wire for very low voltage drop and protect
with a 1A fuse for ECB protection without insulting
the bureaucrat or warranty service manager's sensibilities.
In the final analysis, you're the one who does the
implementation and is required to shoulder consequences.
This is one feature of Greg Richter's one-size-fits-all
philosophy of populating the power distribution with
one value of protection and routing power all over the
airplane on one size of wire. While it relieves the
installer of having to make any decisions it
keeps the thoughtful builder from tailoring system
components to satisfy a variety of design goals.
Posted: Sat Nov 08, 2008 5:41 am Post subject: Need 1,2 & 3 amp fuses |
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)cox.net>
> Bill
It seems worth mentioning that in the situations mentioned & others like
them, the manufacturer is saving himself the expense of building
protection into his device and shifting responsibility for protection to
the installer. Now, if something burns, he can blame *you* instead of
accepting responsibility for his design.
Posted: Sun Nov 09, 2008 6:29 am Post subject: Need 1,2 & 3 amp fuses |
them, the manufacturer is saving himself the expense of building protection
into his device and shifting responsibility for protection to the
installer. Now, if something burns, he can blame *you* instead of accepting
That's a pretty broad brush my friend. Where is it
written that the installer should not have to consider
design limitations for an appliance's integration
into the system? Is it not a good idea to put say
40A of protection on a 20A landing gear pump with
the notion that a stalled motor will pop the breaker
as opposed to burning wires in the motor? Should I
decide to hang hang the 20A motor on a feeder
protected at 100 amps, is it reasonable to demand
or expect the motor supplier to include optimized
protection inside the motor?
While it is not the duty of the system integrator
to discover and make adjustments for limitations
imposed by a product's design, it IS A DUTY
of designers to make those limitations known
before the customer buys the product.
Example. See . . .
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf
I've called out 2A fuses that will open before
traces internal to my product will burn. The risks
for raising those to 5A are not great . . . but should
I get one back for repairs and have to deal with
a burned trace, am I ethically bound to "eat" those
costs of repair because my design does not incorporate
protection suited to 5A feeders (or Richter's 10A
feeders)?
That way, there are no surprises in what should be
an honorable free-market exchange of value. The
buyer has the option of deciding whether or not
he will go to the effort to supply a 2A fuse
before he buys my product. I've designed many
products where there were fusible components
within that prevented component failures
from escalating repair costs. In this case it
was attractive to use 2A protection OUTSIDE as
opposed to INSIDE the box. I'll suggest there is
no dishonor in expecting a customer to comply
with installation recommendations as long as I make
him aware of it before he hands me money and I
hand him hardware.
echristley(at)nc.rr.com Guest
Posted: Sun Nov 09, 2008 12:28 pm Post subject: Need 1,2 & 3 amp fuses |
Carlos Trigo wrote:
| Quote: | Bill
I am not an EE, as a matter of fact I'm a Civil Eng, but it seems to me that
serves.
breaker/fuse.
Not really.
The device needs a certain amount of current. This sets the lower limit
of what size fuse you can use. You can use a smaller fuse, but it's not
much fun swapping blown fuses.
The wire can only carry a certain amount of current, determined by its
diameter and length. This sets the upper size of fuse that you can
safely use. You can use a larger fuse, but then you're really making
your wire the fuse.
Between those limits is the headroom you have for making fuse rating
choices.
Choose to the low side if the device has a stable current draw, and you
think a blown fuse might actually do something to save the device.
Motors and lamps have high inrush currents, so aren't stable loads. A
fuse might do something to save a stalled motor, but it isn't going to
do anything to save a lamp.
Choose to the high side for loads with high momentary currents, and
loads that you willing to let sacrifice themselves for your safety or
comfort.
http://www.ernest.isa-geek.org
Posted: Mon Nov 10, 2008 7:48 am Post subject: Need 1,2 & 3 amp fuses |
I am not an EE either, but I read directions pretty well (that makes me sound smart J). If Dynon says to use a 1 or 3 amp fuse, that’s what I use. With respect to the wire size, who cares, I am protecting the equipment first and the wire second. Remember, the wire size is max rating, not min rating.
We are not talking about 550 kv lines here. I’m not worried about voltage drop across five feet of #22 wire. Just because a wire can handle 10 amps, doesn’t mean one should subject a Dynon to 10 amps of unprotected power.
If ones takes the approach of just throwing fuses at wire sizes you will become good friends with the radio shop attending to smoking radios.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Friday, November 07, 2008 3:09 PM
Subject: RE: Need 1,2 & 3 amp fuses
Carlos
Subject: Re: Need 1,2 & 3 amp fuses
-Bill B
Matt,
clouds.
Glenn
